Aiwa Manual need manual for AIWA CA-DW700M
CD player will accept disc but will not play it, no sound comes from speakers
  • 275 Answers
SOURCE: Aiwa HV-MX100 multiformat VCR won't power on...
Too little information to give any information / help / opinion. What actually happens? Does the Display come on properly? Do you hear any mechanical Noises? Like a motor whirring? Are you able to load a cassette into the machine? Does it get ejected automatically? As you say that the machine switches ON, I assume tyhat the Power supply cicuits are Ok, and this leaves us with the possibility that there is a mechanical problem.Is it that the machine was not used for a long operiod of months or years? If that is the case, in all probability the belts are damaged / broken / loose. I really need more info, please.
Posted on Mar 07, 2007
fairlane
  • 50 Answers
SOURCE: tape decks playig too fast
Hi I can probably tell you what is wrong, but there is usually not much you can do except take it to a shop and have the motor replaced. I most cases there is a hole in the back of the cassette capstan drive motor, or on a small circuit board close to the motor where the speed is adjusted at the factory. You could possibly adjust the speed by ear until it sounded right playing a factory recorded tape with a song you know well, but I recommend these adjustments be left to a tech with a frequency counter. Also, these adjustments normally never need to be touched unless replacing a motor, so it is likely something internal has gone wrong with the motor, and it should be replaced under most circumstances. Hope this helps, Good Luck.
Posted on Sep 27, 2007
SOURCE: NO VCR MANUAL
I have no solution, but have the same problem: NO Manual for my /hv-BR 5000 BH VCR. Can anybody help?
Posted on Sep 26, 2008
  • 120 Answers
SOURCE: AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
Posted on Jan 15, 2009
welcomejee
  • 10594 Answers
SOURCE: I NEED A MANUAL FOR AN AIWA STEREO BOOKSHELF SURROUND SOUND SYSTEM CX_NHMA86
Click Sony-Aiwa Support to download instruction manual of NSX-HMA86 (CX-NHMA86) stereo system.
Posted on Apr 28, 2009
The in dash CD player accepts a disc but does not play. It will show track number but it's stuck on 00:00 then it sim0ply ejects the disc. What could be wrong?
i know this may sound dumb but did you check the cd for scratches or fingerprints?
is this a cd that you burned from the computer? if so is it the correct type and in the correct format..
Sometimes when burning cd's on the computer depending on what software you are using if the bitrate is set to high (above 128Kbps) then the cd will not play on normal cd player
Also when burning cds on the computer the session must be closed completely before it can be played on a regular cd player
Try a brand new store bought type cd and see if it works if it still does not play then it is possible that the laser has somehow become "out of alignment" and that is too difficult to fix and better to be replaced
But by your description it sounds more like the cd is dirty or scratched
It is also possible that the stereo is wore out or malfunctioning
hope this info helps
May 20, 2011 | Car Audio & Video
Hi i have a sony car stereo that plays the radio only!
what is happening on the display is the laser reading the disc if its not reading the disc your cd player is faulty more than likely the laser is either dirty or had its day,make sure there is compatible music data on the disc,also check all the sound options on the stereo.
Aug 25, 2009 | Audio Players & Recorders
Left front and rear speakers sound muffled when playing cd's
after you play a cd while the cd is playing go into your audio settings and adjust theres settings foe each part on a stereo if u set the audio for AM//FM then play a cd the stereo changes to the cd settings
Jun 01, 2009 | Jensen Car Audio & Video
Jensen car 6cd player does not play
is it an original cd or a copy? some cd players doesn't accept rewriteables cds. or or wrong format (mp3, mp4 etc)
Dec 24, 2008 | Jensen XCH6RF 6-Disc CD Changer
Sharp cd-dp2400 suitable remote contols
i have a sharp cd player and the speakers hook up to the cd player and they light up but when i plug in the speakers to play they wont play what should i do
Sep 03, 2008 | Audio Players & Recorders
M&S Systems MC602 Master Unit and M&S MCD6 6-disc CD Player
mc 602 system---volume stuck on 32 and not playing main speaker
Mar 05, 2008 | Audio Players & Recorders
JVC 5-Disc Player XL-F115
You won't get any sound unless you connect your CD player to an appropriate input on your amplifier (any but phono or tape/md) and connect your speakers to this amp.
Shout if you need more help.
Dec 30, 2007 | Audio Players & Recorders
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
