Question about Hilti TE 70 Hammer Drill Performance Package
Where is oil reservoir for hilti TE-72 - Hilti TE 70 Hammer Drill Performance Package
  • 123 Answers
SOURCE: hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Posted on Oct 09, 2009
  • 61 Answers
SOURCE: parts for my hilti te 76
If you send me an email i will send you the parts diagram. parts are available from me but I am in Gibraltar. but I can give you a quote if you like.
paul@wysehire.gi
www.wysehire.gi
Posted on Oct 11, 2009
SRF518
  • 232 Answers
SOURCE: grease for hilti te 24
any liquidy grease like lubriplate or milwaukee type Y grease part no. 49-08-5270
Posted on Oct 20, 2009
Testimonial: "thanks doc"
  • 165 Answers
SOURCE: Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Posted on Feb 27, 2010
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
Hilti te 72 manual
call them at 1-800-879-8000 or try their site at hilti.com
Jan 23, 2012 | Drills
Hilti TE 74 not hammering
It takes 70 cc of oil in the gear casing. Too much oil will snap the connecting rod. If it did not have oil in it there might be a leak somewhere
Nov 06, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
I have hilti te 72 it works but will not hammer
More than likely the con rod is broken. To check remove the shift lever on top by removing the center phillips head screw. then with internal snap ring pliers remove the snap ring.put your phillips screw back in with out the shift lever. Take a pair of pliers and grab the screw and pull the shift boss out. You then can see if the con rod is broken or not. The bad news is those parts are hard to come by.
Dec 15, 2010 | Hilti Drills
Amount of oil
Around 50cc's if it is still wet. 70cc if dry inside
Aug 02, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
I need brushes for a hilti te-72 where can i buy parts
go to Hilti.com and you can use their locator to try and find local suppliers or order them direct. You can also call them at 1-800-879-8000
Mar 14, 2010 | Hilti Drills
HILTI TE 72 STOPPED HAMMERING BUT STILL WILL DRILL
It could be that your connecting rod is broken. You can check by taking your shift lever off of the top of the gear housing and then removing the snap ring to remove the shift boss. That will allow you to look at the crankshaft and connecting rod. If it is broken I would check with Hilti to see if they still carry parts for the TE 72.
Mar 07, 2010 | Drills
Where can I find a switch for my Hilti TE 72 drill?
If you go to the German e-bay and search for hilti TE 72 , you will find answers to all your needs.
Rgds Egil
Oct 28, 2009 | Drills
TE-72 sporadic hammer
You should have no more than 70cc of oil in the housing. AW46 Hydraulic fluid will work.
Aug 12, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti te-72 hammer failure
Jul 20, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 70 Hammer Drill Performance Package Logo
88 people viewed this question
Top Hilti Drills Experts
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
