Question about Brother LS-2125 Mechanical Sewing Machine
E6 error code comes up on my Project Runway Limited Edition Sewing Machine
Thread gets stuck on the bottom
3 Suggested Answers
  • 255 Answers
SOURCE: My upper needle will not grasp my bobbin thread
Hi! This is almost always caused by the needle inserted incorrectly. There is a flat side on the needle shank and if this flat side isn't facing the right way, the top thread won't pick up the bobbin thread. (Bent or broken needles can also cause this, but you would have noticed a broken needle. :-) ). Check your manual to see which way the flat side of the need is supposed to go. (It seems to me that most machines have the flat side facing the rear of the machine--but please don't assume that's true for your machine.) I have machines on which the flat side faces to the lef and, faces to the right, but most of my machines (and certainly the more modern ones), the flat side faces to the rear.
Hope this helps!
Robbie
Posted on Feb 25, 2010
Testimonial: "thanx so much "
hazelgrace
  • 340 Answers
SOURCE: I need a manual for the Brother CE5000PRW project
This is from the Brother website
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CE_5000PRW_EN_1444.PDF
Hope it helps!
Posted on Dec 22, 2010
When I start to sew, the thread gets bunched up around the hook race unit
adjust the upper thread tension as this indicates the thread is not pulling the bottom thread up tight
Apr 27, 2015 | Sewing Machines
Needle sticks on sewing machine and motor won't move it forward
Copy & paste into your browser: http://fixsewingmachine.com You need the free diagrams & details provided on their web site. Jimmy
Apr 05, 2012 | Montgomery Ward Sewing Machines
While sewing, I am getting skip stiches from the top and lot of thread is accumulating at the bottom, as a result it's getting stuck. Please advice. Thanks
I suspect the thread has not passed through the tension discs correctly. Try re-threading and remember to raise the pressure foot when you thread. Or try cleaning the tension discs as there may be stray bits of thread stuck there.
Apr 03, 2011 | Brother Sewing Machines
I have two problems the first is that as i sew sometimes the fabric on the back side gets stuck and there are many pieces of thread coming up from the bobbin and get stuck the second question is everytime...
Check the bobbin tension and that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder.
Feb 22, 2011 | Necchi 6011
Thread knots up on bottom of material and won't sew and gets stuck needle will not move up or down
try a new needle & check to see if the thread has come off the thread take up lever,, that will make the machine jam up
Oct 26, 2010 | Singer Sewing Machines
Top thread gets stuck around bottom bobbin and jams machine
have you tried oiling it after you clean out all the dust and thread ends, you can take the feed dog plate off and clean under there as well. hope it helps
Jul 22, 2017 | Euro-Pro Shark 80 - 7133
Thread getting caught in bobbin area
If you are seeing the needle thread in loops and birdnests then its the needle thread you need to check. The main reason is it is not threaded through the takeup spring(the one that moves) This action is critical as it is how the thread is pulled up tight. Also make sure the needle thread is between the discs and that it has sufficient tension that you do not see it on the bottom of the material. Try this: Use two different color threads for needle and bobbin. If you see the needle color on the bottom then the needle thread is not tight enough (or in 5% of the cases the bobbin is too tight or hung up). Let me know how it does. Jay
May 28, 2009 | Sewing Machines
Thread tension for regular seam sewing
oil the shaft for the presser bar and keep moving it up and down(it may take a while) until it moves freely. Always use Sewing machine oil Not 3N1 oil.
Tension:
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on top and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension). If you have loose thread on top your top tension is probably too tight and your bobbin thread too loose
Mar 23, 2009 | Sewing Machines
CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Jan 18, 2009 | Euro-Pro 8260 Mechanical Sewing Machine
Brother LS-2125 Mechanical Sewing Machine Logo
134 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
