Question about Toro Lawn Mower With Toro Power Tools
I have a 2006 toro lx 500 battery wont charge while mowing only starts a few times then battery dies
5 Suggested Answers
buffalonyman
  • 1865 Answers
SOURCE: toro lawn tractor
There is a switch on the seat and one on the brake pedal
Posted on May 31, 2009
  • 33 Answers
SOURCE: battery draw down
Disconnect the battery. Charge the battery. Then let it sit idle for whatever period of time that it has been taking for it to go dead. Reconnect the battery & try to start it. If it is dead then the battery is bad, If it cranks OK then you have something drawing the current from the battery.
Posted on Sep 10, 2009
mowerman1857
  • 389 Answers
SOURCE: My toro groundmaster 225 wont start.
Check for a loose ground on your battery and for a blown fuse in the electrical system
Posted on Sep 16, 2009
mirandamccoy
SOURCE: toro model 20331
I have a toro mower and it has same problem,my husband replaced some parts&it worked but then started same thing again,he hasn't had time to mess with it again seeings hes been working reg. job&every other spare minute been spent trying to fix our truck! Id love to see an answer for mower to help this person&us also!!
Posted on Aug 17, 2012
Why does my toro model 74301 keeps dieing
There are many reason a lawn mower dies in gear. Buildup of grass on the underside of the deck, mowing in too deep or thick lawn causing too much load on the blade, or the air filter needs cleaning.
Jul 19, 2014 | Toro Garden
Toro lx 420
sounds like short to groung earth check wire back its possably chaffing on metalwork some were
May 25, 2014 | Garden
Toro lx 500 riding lawn mower
check the connections from the battery to starter-check the fuses -and relays than start with the safety switches --seat-clutch-and cutter deck the safety switches are a kill switch
May 24, 2013 | Garden
Toro wheel horse 14 38 hxl
check your wiers that go to you solinoid but first try to jump your mower usind jumper cables put the red cable on the bottom bolt of your solinoid and find a good ground for the black cable then let you car warm up then trun the key on your mower to start and it will start
May 12, 2013 | Toro Garden
Battery draw down
Sep 10, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Tractor won't start, engine turns
best guess , blocked main jet or water in the carby
an overhaul would be in order
Oct 24, 2017 | Toro Lawn Mower With Toro Power Tools
Oil causing a problem?
Sound as if you have too much oil in the machine. Anytime you see white or lite gray smoke it is a sign of too much oil. Before you go through the routine of cleaning the oil out of every nook and cranny, try unscrewing the spark plug and clean it with a soft rag. It would have oil on it preventing the machine from starting. If this does work and there isn't a lot of oil in the gas tank now, just continue running the engine until the smoke clears. It won't hurt anything. But if cleaning the plug doesn't help you will have to empty all gas and oil from the gas tank, refill with new gas, squirt a little gum out carb cleaner in your carb to remove any oil there (this can be done when you try to restart the engine). Remember, when you are mowing grass if you are mowing on a hill) of any knd, make sure to turn the mower so the gas tank is on a higher level than the oil.
Jun 18, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
62 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
