Question about Dual XDVD8181 Car Video Player
How do i by pass the parking brake no video
How do i get pass the parking brake safety feature on a dual xdvd8181?
  • 3 more comments
  • Anonymous Dec 07, 2007
    I do not have a remote to my dual xdvd8181 can i still by pass the parking brake so it can play video
  • dblevs Dec 11, 2007
    i have just did two method and they both did not work. Method one I inserted an audio cd then pressed play. Then pressed stop twice and entered 26604 and pressed enter. Then i ejected my cd and put in a dvd and it didnt work. The next method i tried was with the dvd. I let it play untill the sound came on and then pressed stop twice. Then i entered 26604 and then pressed enter. How do i by pass the parking break
  • Anonymous Mar 15, 2014
    Dual XDVD8181 Car Video Player forgot password need unlock coad
  • Anonymous Mar 30, 2014
    no remote code
  • Dale J Wolfe Jun 22, 2018
    How do I get the blue screen off of a dualxdvd256bt. Car stereo and hook up parking brake wire??
1. AUDIO CD METHOD (Permanent)
** Insert Audio CD
** Press PLAY
** Press STOP twice on remote
** Enter 26604 on remote
** Press ENTER
** Take out Audio CD and Insert a DVD
Credit: Myself via a DUAL Tech
2. DVD METHOD (Permanent)
** Insert a DVD
** Let it play until you hear sound
** Enter 26604
** Press ENTER
Credit: Adam P.
The blue warning screen should immediately go away after pressing the last digit of "26604." Still press ENTER as a precaution.
From here:
http://forum.ecoustics.com/bbs/messages/4/302701.html
Posted on Oct 12, 2007
  • 4 Answers
OK PEOPLE, I HAVE THE DUAL XDVD8181 just installed, you don't need to do any kind of code to get the video to bypass. this is what you have to do
Get a toggle switch, one that flips one way for ON, and the other way for OFF. connect parking brake wire (yellow/blue) to one end of the switch and the other end to the ground of the radio (Black wire) leave the switch in off position, turn on radio and insert dvd, when you get the blue screen, flip switch ON OFF ON wait 5 seconds and video will come on. That it fellas.
Posted on Dec 12, 2007
Yo i cant get my xdvd8181 to play dvds iv tryd it all well i thought im a try wat you guys said ill post my results
Posted on Sep 07, 2008
Ok people on the dual xdvd700 yo bypass the brake wire it must hane its own ground simply ground it out
Posted on Dec 30, 2007
For the dual dvd players the way to perminantly disable the lockout is to ground the yellow blue wire. then put a dvd in and wait for the audio to start. press stop twice on the remote and then enter the code 26604. this really works i just did it on mine.
Posted on Dec 29, 2007
SOURCE:
I need to unlock my dual xdvd8181 i need password
Put a dvd into the player, when you hear sound hit the STOP button twice on your remote. Enter the code 26604 and hit enter. That will do it. Make sure your parking brake wire is grounded.
Feb 12, 2010 | Dual XDVD8181 Car Video Player
How to by pass the e brake wire
at this time there isn't a code bypass for this model. the easiest thing to do so that you can play video while in motion. is to put a toggle switch on the parking brake wire of the dual screen. then do the ebrake pattern on the switch instead of the ebrake in the car
1. disconnect the parking brake wire of the dual from ur ebrake wire in your car.
2. take your 2 wire toggle switch and connect one wire to Ground(metal)
3. take the other wire and connect it to the parking brake wire of the dual screen.
if i remember correctly, the pattern for the dual screens is.
1. starting in the off position.
2. on for 2 secs
3. off for 2 secs.
4. then on .. the the video will show.
hope this helps
Oct 04, 2009 | Dual XDVD8181 Car Video Player
Is there a code for the dual xdvd8181
on the back of the unit you will see a yellow/blue wire probably has a tag that says parking brake(-) tie that wire in with your main ground wire- black wire. no more video block. so i dont get in trouble remember that in most states it is illegal to watch videos while driving so dont watch them while driving this is only used as a reference only and do this at your own risk.
Feb 17, 2009 | Dual XDVD8181 Car Video Player
Well on the eclipse unit you just ground the wire for the parking brake
Jan 09, 2009 | Dual XDVD8181 Car Video Player
DUAL XDVD8181
I need the bypass code for a xdvd8181
Nov 02, 2008 | Dual XDVD8181 Car Video Player
Dual problems
Ground the parking brake wire to any bare metal area on the van this should allow you to watch well in motion.
then do the following.
** Insert Audio CD
** Press Play
** Hit Stop Twice
** Use remote to enter 26604
** Hit OK
Aug 26, 2008 | Dual XDVD8181 Car Video Player
How do i bypass the e-brake wire on this cd player
The principle is to ground the yellow/blue wire of the Dual XDVD8181 but with certain sequence and a few other actions. It is better explained with illustrations here while a pdf "how to" is available fro download here. User discretion with a consideration for safety pls.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jul 21, 2008 | Dual XDVD8181 Car Video Player
Parking brake bypass
make sure you ground the e-brake wire (yellow with blue stripe) then turn the power on, insert a dvd, let it play until you hear a sound, then on the remote press: stop, stop, 2, 6, 6, 0, 4, enter.
Mar 21, 2008 | Dual XDVD8181 Car Video Player
Dual Parking Brake Code HELP!!
the esiest way to solve these problem is to make a switch connecting the blue/white with the brown cable it would work just find i had the same problem.
Mar 10, 2008 | Dual XDVD8181 Car Video Player
Dec 11, 2007 | Dual XDVD8181 Car Video Player
Dual XDVD8181 Car Video Player Logo
1,490 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
