Question about Xantrex Technology Electronics - Others
Xantrex freedom sw 3012 dc over voltage
The inverter received over 16 volts and now the charger won't work
SOURCE: Xantrex Freedom 458 Combi inverter/charger 2000 watt
OK my 2000 Discovery does the same thing. Try and hit the inverter charger with your fist 3-4 times, then listen and see if the charger fan starts up. I will be bringing my inverter to Portland this week to have the tech look at it. The other thing is it could be the transfer switch. Will let you know.
Posted on Sep 08, 2009
  • 3 Answers
SOURCE: I have an old Heart Freedom 20 charger/ inverter.
I have had a Heart Freedom 10 for over 10 years and have found it to be very reliable though slightly lacking in power if th a/c (just plugged in to fwd AC breaker)is on and I lose shore power or gen..
As MT1 says apply AC power to your main input then check the cooresponding pop up circut breaker for pwr in and through. your should get a transformer hum if power is getting to it and a depleted battery is hooked up. If you have a charged battery and a link you should get a led light and or a fault code of either a sequenced blinking light or a readout on the better remotes.
If this is not avilable just check all of the installed breakers for continuity before sending it in for repair as the shipping alone to and backwill be approx.$100.
Good luck. I am looking to upgrade to a freedom 20 now. There is a sell price on the net of $864.
Rick
Posted on Dec 09, 2009
SOURCE: Trace / Xantrex SW5548 inverter (one of two in a
hi i have trace sw5548 and the power keep turning off and i have to go in P G and E power, why would it keep turning off thanks
Posted on Dec 11, 2009
SOURCE: inverter won't charge
The problem is the batteries. 1) Check the age of them to assure they are not near warranty limit. If so change them. 2) They must be topped off. I recommend using distilled water within every 30-60 days. Summary: After doing item 2 above charge them with an external charger; while connected to inverter is ok. Does this help?
Posted on May 21, 2010
kel1guy2002
  • 3740 Answers
SOURCE: I got an error of ER 05. What does that mean?
Hi and welcome to FixYa, I am Kelly.
E05: Flashing Fault LED: Flashing Alarm: Beeping = Output on inverter is shortcircuit
- Disconnect your output terminals and see if you still have the code. This is telling you there is an external short.
- If you still have the error with the output terminals disconnected start looking for internal inverter shorts to the output connector. (Chaffed wire / hot wire signs / internal + lead ground)
- If you have Circuit Breakers / fuses on your output side open all the CB/s or remove all fuses then turn on the CB's / install fuses one at a time until you note the Er05 error. Then troubleshoot the shorted circuit with an Ohm Meter.
Thanks for choosing FixYa,
Kelly
Posted on Mar 19, 2011
I have a customer that recently replaced his generator, problem is , he got a 120 VAC output. He has 2 SW 4024 for 240 VAC output. Can I hookup the 120VAC to the master inverter, or should I get a...
I will accept the second option which is getting transformer.
Go ahead and get a transformer in order to step up the voltage. This is better than hooking up the 120V AC to the master inverter.
In summary, get a transformer to step up the voltage.
I hope this is clear now....
Good luck.
Apr 01, 2011 | Xantrex Technology Xantrex SW Series...
I am trying to fix my xantrex freedom 10 inverter/charger but I need the internal wiring diagram. Is there I way that I can get it?
Unfortunately, to protect their proprietary designs, Xantrex does not provide parts or schematics except to their factory authorized service network. Assuming it is not still under warranty that would be voided by removing the cover, you might be able to see any obvious damage and procure the necessary repair parts from a third party, but that might be a lot of trouble to track down without any guarantee that it would actually fix the problem. If the unit cannot be uninstalled and/or brought to a service center, some reps do make "house calls", albeit for a fee.
Jun 10, 2010 | Xantrex Technology Xantrex 458 10 12...
Inverting side working fine but charger is not
I had a similar problem at work yesterday.when your charger switches of it assumes that the battery is fully charged, while it is not.this is the solution , switch on you inverter machine and allow it to run, while it is running use a direct current "dc" multi meter a test the voltages of the batteries any one that drops like 3 volts below the normal voltage is bad. Change it and you will notice that the problem will stop. Note that when a battery is bad it takes little time to get it charged than when it is in a good condition .
May 26, 2010 | Xantrex Technology Xantrex Trace Series...
Xantrex 458 freedom....has stopped charging house batteries off of engine alternator. Alternator is showing that it works (dash gauge). It does charge while on shore power or generator....but not charging...
Fis\rst of all is the inverter supplying 120 VAC? when turned on?. If so the inverter seems to be working.I think your problem is in the truck alternator/charging system. The inverter is independent of this charger..
Mar 23, 2010 | Xantrex Technology Xantrex 458 10 12...
Inverter won't charge
check if the inverter has a fuse for the charger, if it does test it if it is still ok if not change it
Mar 09, 2009 | Xantrex Technology Heart Freedom 20 12...
Electronics - Others Logo
76 people viewed this question
Top Xantrex Technology Electronics - Others Experts
Jimmer_9
Level 1 Expert
richie46
Jay Plesset
Are you a Xantrex Technology Electronics - Other Expert? Answer questions, earn points and help others
