Question about Comtrend CT-507 Router
Loading comtrend modem ct-5374
Need help loading
5 Suggested Answers
  • 193 Answers
SOURCE: how can I install comtrend ct-507 adsl without a disk
no issues go to command window which is 1 make sure ur pc connected directly to the modem and once wen to the command screen like
click-->start-->run-->type--cmd-->ok-->black window  in there type-->ipconfig-->enter and u can see ip address and sub net mask and default gate way note down the default gate way and close the black window
open inter net explorer and in address bar type the default gate way with out www.>and http>like and hit enter u can see a login screen
probally user name-->admin (lower case)
password --> admin (lower case)> rate me solved if its helps
Posted on Oct 18, 2007
SOURCE: comtrend ct 507 problem
user name and paswerd
Posted on Sep 11, 2008
  • 12 Answers
SOURCE: i need to download the driver
If you need to configure something on the router, hook to it via ethernet wire to configure it. the default ip address for the router is 192.168.1.1 You will need to assign a static IP address to your wired network card in the range of 192.168.1.x, I would static it to 192.168.1.10 Then after you have staticed your IP address, use a browser to navigate to 192.168.1.1 the default user/password for the router is: username:root
password:12345
You should be able to change any settings then that you need to. Also, any firmware updates you would need should be provided by your ISP.
Posted on Apr 30, 2010
NowItWorks
  • 63 Answers
SOURCE: Every time my power goes
With changing the IP and all that business it may have messed it up a little bit.
This may not be the most sophisticated way of fixing it, but this is what I personally would recommend. THIS WILL ERASE YOUR ROUTER CONFIGURATION, but at this point that should be a good thing.
On both the Comtrend modem and the Linksys router, there should be a "reset" button. Grab a pencil or something long and skinny to press the reset button. Press on the reset button for 5 seconds on both the Modem and the Router.
Then make sure all of your wires are plugged in correctly. Go into your Router's web configuration by opening up Internet Explorer, Firefox, Chrome, etc. and typing "192.168.1.1". The username should be "Admin" and the password should be "password".
After you log in, change the Wireless settings and setup a password for your network and a name for your network.
Unless your Router is truly is faulty, then it may still reset on a power outage, but it should retain all of these settings.
Hope this helps.
Thanks for using FixYa.
Posted on Aug 07, 2011
Internet will not go through my comtrend CT-5072T modem
Need a bit more background on this.
Did you just go out and buy this device and hook it up to the phone line ?
Are you using ADSL line Filters ?
Did you ring your internet service provider to guide you through setting up the account settings in the modem ?
How are you connecting to the device to your P.C ?
Jan 25, 2015 | Comtrend Adsl2 Ethernet Router Model:...
No ip on comtrend ar-5381u, will not connect to internet
DO NOT INSERT A PAPER CLIP TO RESET THE MODEM! unless you know how to reprogram the router, this includes having complete knowledge of ALL the settings required by the ISP AND having your username and modem password (modem authentication passwords are not usually provided to the customer) Doing a "hard boot" will only return your modem to factory settings
Dec 21, 2012 | Comtrend CT-507 Router
Drivers for comtrend ct-5611t
Check out this link:
http://www.comtrend.com/links/13$snd.htm
Oct 15, 2012 | Comtrend Adsl Usb Modem (ct-351)
Modem will not cnnect through router but only direct to PC. two different wireless routers, same issue.
The issue is that your modem and router(s) have an IP conflict. Contact either your router support, or Internet Service provider. They should be able to help you without a hitch!
Jan 03, 2010 | Comtrend CT 300 (CT-300) Modem
Installation of the modem Comtrend CT-361 under Windows Vista
This appears to be an old model. Their website isn't very user friendly and they list no kind of tech support available. You can contact them here.
http://www.comtrend.com/na/contact.htm
They might be able to help you out if you call them but there is nothing available on their website or anywhere else that I see on the web. The product appears to be older then Vista and might have never had a Vista driver made for the product.
Oct 01, 2009 | Comtrend Adsl Usb Modem (ct-351)
MTU settings
where do i go to change the mtu settin on a comtrend ct-5364a
Sep 11, 2009 | Computers & Internet
A can not find the driver for comtrend ct 361 modem
If you are using windows xp then use this site to fix the issue
www.update.microsoft.com
Jul 25, 2009 | Comtrend Adsl Usb Modem (ct-351)
Ip router and login name / password
yea but that backdoor got hack so wtf do i do when : user name root psw RM6008 dont working. ?
and wft a Backdoor on a router Who`s so stupid to make that
Mar 01, 2008 | Comtrend CT 300 (CT-300) Modem
Comtrend CT-507 Router Logo
48 people viewed this question
Top Comtrend Computers & Internet Experts
Julie Endres
mathur_1
Advaith Ganesan
Are you a Comtrend Computer and Internet Expert? Answer questions, earn points and help others
