Question about Thermador Kitchen Ranges
Termostat for tharmador 48 range - Thermador Kitchen Ranges
I have 48 " 6 burner stove natural gas.Stove is
the glass in the ovens should not crack when self clean is used. it could be that there was a minut crack in the glass or a build up of moisture in between to door windows that expanded at the extra heat but this should be brought up with the manufacturer for replacement.
I hope this was useful.
Jan 05, 2011 | Viking 48" 6 Burner, Griddle Professional...
Where can I locate the model number on my viking range? (48")
Mine was located to the left of the top burners. Remove the grates covering the burners, remove the 'spill' pans, lift up the surface that held the spill pans and then on the LHS you should see a plate with your units details.
Jan 20, 2010 | Viking 48" 6 Burner, Griddle Professional...
My GE Spectra heating element caught on fire today and completely disintergrated. Is this common?
IT CAN BE IF THE ELEMENT HAS NOT BEEN REPLACED FOR A LONG TIME AND IT SOUNDS LIKE THE TERMOSTATS HAVE FAILD SO REPLACE ELEMENTS AND TERMOSTATS AND YOUR OVEN WILL HAVE A NEW LIFE .
Nov 11, 2009 | GE Spectra JBP78 Electric Kitchen Range
Burner comes on for about an hour then shuts off and cant be turned back on till range cools down
SOUNDS LIKE THE TERMOSTATS HAVE HAVE BLOWN AND ARE STOPING YOUR RANGE HEATING UP .
Nov 05, 2009 | Cooktops
Oven does'nt stay on.
SOUNDS LIKE TERMOSTAT REPLACE THIS AND OVEN SHOULD WORK.
Oct 13, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Converting to propane
Call Dynasty / Jade ph # 800-884-5233 order convert kit from Nat to LP. Flip the cap on the gas regulator from Nat to LP, talk with Brad @ Dynasty if you needed help. Have fun.
Mar 22, 2009 | Dynasty DGRSC 48-4GCB Gas Kitchen Range
Viking stove
no the termostat but the ignitor that's the part that's nest to the broiler burner. the part that ignite the flame. when you turn on the broiler the ignitor becomes red like a glow.
Nov 25, 2008 | Viking VGIC305-4B Gas Kitchen Range
Kitchen Ranges Logo
16 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
