Question about Vizio Televison & Video
Vizio S3820w-CO38 sound bar was working fine. In moving it accidentally hit one of the buttons on back side (Bluetooth I think) and the sound stopped. Can't get it back. All settings are correct. Wondering if the Bluetooth is causing this. Is there a way to disable it? Do not want to use Bluetooth
SOURCE: No picture, have sound ( think husband hit some X button)
Did you find the problem I have the same
Posted on Apr 25, 2009
SOURCE: LG RU-42PX11 42 plasma TV has black bar
it seems to be a bad connection somewhere but I disconnected the ribbon cable and got a verticle line of snow instead of a blank line. the line is about 34 mm wide and starts 285 mm from the left edge starts on the Blue and goes to the Red pixels. so if they are 1mm wide that would be 34 bands of color.
I would sure like to figure out the solution to this one or I got a TV I need to throw away cause the o'lady is gonna bust my balls if I can't fix this!
Posted on Sep 28, 2009
  • 4 Answers
SOURCE: I have a Vizio 37 inch lcd tv. It works fine from
Well It depends on what you mean by fade out, Fades out completely or just darkens enough to be annoying? I just bought this exact tv and mine also fades, I changed the preset picture function to "game" mode and the fading stoped.
Posted on Feb 17, 2010
  • 63 Answers
SOURCE: I get sound on my tv but no picture. not even volume bar or menu
check to see if there is an image on the screen by putting a light close to it if ther is an image replace the backlight inverter
Posted on Jul 09, 2010
  • 8457 Answers
SOURCE: Vizio model VW42LFHDTV10A 42'' LCD
This problems are those 2 long LCD inverter boards to it left and to it right.These 2 long LCD inverter boards help the LCD picture screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those refurbishes 2 long LCD inverter boards for the replacement.
Posted on Nov 26, 2010
We are trying to hook up a VIZIO sound bar model#S3820w-Co to our Vizio TV we also have Directv and a dvd player hook to this tv which wire do we hook from sound bar to Tv
If the TV and sound bar have an optical connector, then get the optical cable to connect the two. If not then use the audio out jacks on the TV and don't forget to change the audio set up to switch the sound to the sound bar.
Oct 29, 2014 | Televison & Video
Vizio sound bar 2.0 remote control not working
After only three days I would take it back, or at least take the remote back and try it on a different sound bar.
Jun 14, 2014 | Vizio VO47L 47 in. LCD TV
My 210 visio sound bar keeps losing volume then come back on then goes back off
You will need to take the following steps to ensure that the Vizio wireless subwoofer is working properly:1) You will want to make sure that the subwoofer is in the line of sight of the Vizio sound bar.
2) Ensure the Vizio wireless subwoofer is not beyond 60 ft. away from the sound bar.3) Unplug both the Vizio sound bar and the Vizio wireless subwoofer for 30 seconds and then plug back in.4) Try re-pairing the devices. Pairing works best when you have the devices facing each other about a foot apart during initial pairing, once they are paired you can move them to your desired location.
Sep 12, 2011 | Televison & Video
Need 3 digit code for vizio vsb200 audio bar for a clikr-5 UR5U-8780L-TWM remote
There is no listed 3 digit code. You will have to do a code search. Press and hold the Ok and Aux button for 3 seconds. You will have to press the CH+ or CH- (does not matter which) for upwards of 400 times but the code is in there somewhere between 290 and higher, I lost count. Here are two tips. Move the cable box out of site of the remote and expect the TV to turn off when it hits its code. This will make you think you have found the code as the sound will go off. Don't fall for it. Look at the light on the sound bar only. Once the TV turns off you will need to have it;s remote handy to turn it back on so you will hear the sound again.
Once you pass 290 or so go slow and don't miss the light going out on the sound bar or you will have to do it all over again.
Once you turn the sound bar off press the AUX button again to lock in the code.
It's a pain but the code for Vizio sound bars is in there, don't let them tell you it's not. Took me about 7 tries to find the sequence and make the mistakes but my Vizio bar is now Programmed to the Cliker-5 and works fine. Good Luck.
May 19, 2011 | Televison & Video
The sound suddenlly stopped working on our vizo tv, what do we do
Check ya haven't accidentally pressed the "MUTE" button, just an idea?
Jan 19, 2010 | Vizio L37 Television
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
No video/audio when pressing remote control or on the TV set
Moved my TV to another satellite receiver.
I received picture & audio.
Then I moved the TV back to its original position.
Now it works OK.
I probably hit a button that shut off my picture & sound.
I am mystified.
Thanks anyway.
Gerry............................;-))
Apr 13, 2009 | Westinghouse 26" LCD Flat-Panel HDTV
Televison & Video Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
