Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
Code ul whirlpool cabrio wtw6800
Unbalanced load when machine is empty
SOURCE: unbalanced load cabrio top loader
i am on line now- we checked with a level and its right on... i have been washing on the normal cycle and then using the drain/spin cycle to spin out as much water as i can..that cycle even displays the ul code...its always displayed somewhere between 12 mins left and 7 mins left...i dont know if that has something to do with it??
Posted on Jan 13, 2008
  • 18 Answers
SOURCE: Unbalanced load
If your washer goes severely off balance you need part # W10112113 to fix it.
Posted on May 10, 2008
canbruce75
  • 1776 Answers
SOURCE: f1 code on whirlpool cabrio top load
This is from a service bulletin. This may be of interest to you. There have been many problems with these machines in this area. Anyway, I sympathize and hope this helps. Best wishes.
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 – CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
with the air pressure system.
Posted on Aug 09, 2009
  • 410 Answers
SOURCE: i have a ul error code on my washing machine it is
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. The ul error code means unbalanced load. I can suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on washing machines and other appliances. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Posted on Nov 26, 2009
SOURCE: My whirlpool cabrio washer will not stay balanced
the repair man says i need to replace the inner tub for 299 dollars with a total price of 424 and its only 4 years old
Posted on Jan 19, 2010
Whirlpool cabrio top load washer ul on final spin
It senses that the lid is unlocked, even if it isn't. Could be a defective interlock.
Feb 24, 2018 | Whirlpool Washing Machines
LG WaveForce top load washing machine flashes unbalanced on every single load. Even when run completely empty. a single load can take up to 6 hours to complete.Manufacturer nonresponsive. Solutions?
LG issued a recall on certain waveforce washers due to the unbalanced error codes. You may have a washer that is affected. Contact LG at 855-400-4639, and have you model number and serial number at hand to see if you need a software update.
Jan 25, 2016 | LG Washing Machines
Bravos XL. Why is it displaying code ul even if empty?
The machine thinks the empty machine has an unbalanced load. This may be a control board malfunction.
Sep 11, 2015 | Maytag Washing Machines
How do i troubleshoot for a ball sensor,switch on a LG laundry washer?
machine needs to be level.so it cant rock side to side or front to back adj feet .when u load machine put half in and rotate drum half turn and put the rest of load in.that should balance load.dont overload.try running empty if it still showing ua
Aug 09, 2014 | LG WM Washing Machines
Ul is displayed what does this mean
UL Stand for unbalanced load
probably the balance rods washer has 4 of them and they work like shocks for the tub and if they go bad than they allow the drum to spin wildly.
Jun 03, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Ul code on empty machine
Sounds like you need to replace the bearings... not a difficult task. http://appliancejunk.com/forums/index.php?topic=8960.0
Mar 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a WTW6600SW1 Whirlpool washer that stays unbalanced even when empty. How do I fix it?
A memo was issued by service matters to remove the counterweight on the base of the machine and add springs to stabilize lateral movement.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 21, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio spins off center and stop with ul code
Ul-Unbalanced Load
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute
the load.
May 28, 2012 | Whirlpool Washing Machines
Whirlpool awoe 8761
Is it always loud or just when it is a full load. If the load is unbalanced it will be loud. Most F/L washers today have some kind of unbalanced load detection, but they are not all that great. If it spins quietly when empty it is just an unbalanced load. Don't over load and don't mix rugs with clothes, pillows, etc...
May 19, 2012 | Whirlpool Washing Machines
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
20 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
