Question about Garden
Chainsaw carb adjustment on a TB4218cc it will not idle and will not rev up a friend of mine turned the high and low screws...can you please help me...what are the adjustments to get it to idle and rev up
dennisgladx
  • 52 Answers
SOURCE: high geared chainsaw
Hi 1tgriffin,
My name is Dennis and I hope that will serve your needs.
IDLE ADJUSTMENTS:
There are three adjustment screws on the carburetor labeled
H (for High speed MIXTURE)
L (for low speed MIXTURE)
T (for idle SPEED SETTING)
They are located just above the primer bulb. If your saw floods so soon in the starting process the idle mixture setting can be set too rich and the speed may be set too slow. Remember the chain will not move when the idle speed is set correctly with a WARM ENGINE!
Adjust the idle speed to just below chain movement WITH A WARM ENGINE this is just below the activation RPM of the centrifugal clutch. Let the engine run at a higher speed than idle until it is warm -- 3 min -- you may have to keep goosing it until then.
Please don't exceed the limits of the plastic limiters when making adjustments.
If you haven't adjusted the mixture screws you may just have to adjust the idle speed and that can start my turning that screw all the way in to the stop and then back out 4-1/2 turns for a good place to start. FAST IDLE -- Adjust the speed until the engine runs with out the chain moving. Adjust clockwise to increase speed. C clockwise to decrease engine speed.
Accelerate the engine and if it stumbles and makes too much smoke it's too rich turn the
LOW SPEED MIXTURE (in) clockwise in 1/16 a turn increments NO MORE at a time because a two cycle needs to run at a setting for a short time to really prove the setting. don’t run it wide open to warm it up but it should be at a fast idle. Nothing you do will be proven correct until the engine is warm.
Good Luck
Glad to be of assistance - please rate the solution because I will learn from your rating. Thank you
Posted on Nov 09, 2008
  • 16 Answers
SOURCE: craftsman 16'' chainsaw, start with very high rpm, how to adjust ?
The H is for when your cutting,it keeps the saw from stalling. The L, is for the saw when at Idle. When the L ,is adjusted right, the saw should stay running ,and the chain should not move ,that is with the break in the off position. The H screw,should be adjusted if the saw bogs down when rev ed up. A good starting point for theses screws would be a turn and one half out.
Posted on Jan 21, 2009
  • 149 Answers
SOURCE: need initial carb adjustments for both high and low adj.
start at 1turn out on both that should grt it running from there..
Posted on Jan 31, 2009
  • 583 Answers
SOURCE: I have a Mcculloch chain saw. Mac 3216.
hi terry, here we go ---screw the H srew right in till it stops then back it out 1 1/8th of a turn do the same to theL screw but only back it out 1 turn.screw the idle screw in i turn. it is abit difficult adjusting things by holding them with one hand while you screwthings with the other,so if need be clamp the chain bar in a vice making sure the chain is not touching any thing.start the motor ,hold it at a high idle a minute or so to warm up, the n take it up to top revsand hold it there whilst screwing the H screw slowly in and out until it runs the sweetest then back it out 1/8 th of a ,turn, donot take it in past 7/8 ths of a turn . now release the throttle and let it idle do the same thing with the L screw in and out to where it idles best then set your idle speed with the idle screw so that the chain just holds from turning (that is not so important so long as it idles nicely with out cutting out) and there you have it . just watch your hands onthat chain .
Posted on Aug 27, 2009
SOURCE: Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Posted on Sep 11, 2009
Adjusting the tickover and mixture
The carb is factory set you need to remove carb you will then see two screws one marked L and the other H with a small hacksaw cut a slot across both screws don't worry about cutting into carb body this can't be helped screw both screws fully in then back them off 1 and 1/4 turns this rough sets high and low running start saw set low speed first adjust screw in or out to get best low running then rev saw to max.and adjust max revs do the same as you did with the low speed screw to obtain max revs this should solve your problem.
Mar 07, 2015 | Ryobi Garden
Saw wont rev up or idle
First thing, try new gas.
If that doesn't do it, you need to adjust the low and high speed circuits on the carb. A good starting point is 1.5 turns out from fully seated. On that saw I'm not positive if you will have access to the adjustment screws unless you pull off the plastic caps that may be covering them.
Feb 01, 2014 | Stihl Garden
Poulan chainsaw, I rebuilt the carb with all new everything. Now it will start with choke all the way out. Idles really high. If I push choke in, it dies instantly. The hi-lo and Idle is off I know for...
get it running on idle,adjust the idle down till it runs hairy,then adjust low speed mixture screw till you get it highest revs,then keep repeating that till you get it idling normal.rev saw up max revs,adjust high speed jet, in or out till you get max revs,then screw out one quater of a turn.That lets enough fuel thru to cool the sparkplug tip..If thats no good,redo the carbi.Check the tiny filter under the needlevalve hole.Check the needlevalve diaphragm height.recheck gaskets are right way round
Nov 03, 2013 | Husqvarna Chain Saw 20" Bar
42cc 18 inch craftsman chainsaw model 358-351910-18. Saw runs great at idle or while not cutting wood, when starting to cut wood just after the entire bar gets into the wood engine bogs down and chain...
Generally this is a fuel / air ratio problem. Usually it can be solved by a carb adjustment. On the carb there are usually two screws, one marked low or L , the other marked high or H. Low is your adjustment for idle mixture, high is for mixture at full throttle. The saw should Always be adjusted to run well during the cut. Make adjustments a little at a time, then try The saw. Continue small adjustments untill the saw is performing well at full throttle while Cutting.
Aug 09, 2011 | Poulan Pro Chain Saw 46cc 20"
Troybilt chainsaw 20'' bar. will only run until primer fuel is burnt. Replaced gas filter, and soaked carb,and installed a carb.kit.Can`t find any vaccum leads, flywheel and key ok .Help thanks
The idle screw may be turned all the way in on the carb adjuster which should be a very small screw in a 3/16 hole through the plastic cover on the side between the starter rope and the trigger on most saws. Bottom it out and then turn it back 1 and 1/2 turns. Have the saw on a low bench, so you can control it when she starts up - if the revs are too high the chain will spin up which can be dangerous. Now screw the idle down until the chain stops and the motor starts to stall, screw it out a little to get a running idle which will not stall but never starts the chain spinning up. Some have two screws, one for air during idle, the other for the gas during idle. They both should be out about one and a half turns which is industry standard and then you can fine tune from there, but usually only a half turn cw or ccw would be way too much difference from the standard positions.
Apr 10, 2011 | Troy-Bilt Mtd Troy Bilt TB4218CC 42cc 2...
I Have a McCulloch 335 which screw do i use to turn up revs on carb?
The right hand screw is for high, the left for low. Adjust by small amounts at a time.
Hope this helps. If it does, I'd appreciate a vote. Thanks,
Handie Andie
Apr 05, 2011 | McCulloch Garden
Engine dies upon acceleration after starting and idling
turn the high speed and low speed mixture screws right in[gently]then out 2.5 turns.start it up,screw the idle screw up till it will idle,then adjust low speed mixture screw in or out so you get the highest idle.keep lowering the idle so as you adjust the screw,it wont get it any higher in revs.so by now it should idle.next,open the throttle wide,and adjust the high speed screw until you get maximum revs..then,turn screw 1/4 turn out.that makes it slightly richer,cooling the plug with droplets of petrol.you dont want it lean.if it wont rev fully,check the fuel filter.they get dirty quite often
Jul 02, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
Apr 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Cannot adjust carburator on husqvarna chainsaw 435
the screws are on the side of the carb very small heads flat screw driver is needed as they have a cover on them it has to fit inside the cover H (high) and L (low) tighten them all the way in tight but not forcing them turn anti clockwize 1 1/4 turns try to start the saw pull the trigger and adjust the H (high) till it runs smooth then  let it idle then pull the trigger again saw should rev without loss of revs if it does turn the L (low) small amount either way till it does  hope this helps
Oct 19, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Base adjust. on carb high and low needles on carb polen 42 18" thanks
The standard setting on needles is to screw them in all the way and then back them out 1 and a half turns.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. turn the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn. You may need to readjust the idle speed so the chain doesn't turn during idle. Do the same for the high adjustment screw.
Oct 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
