Question about Belkin F1DK102U 2-port KVM Switch
My Keyboard only works on one PC but the monitor and mouse works on both?
My KVM switch is set up and the mouse works on both computers and i can hit scroll lock twice and jump to the other computer, the keyboard work on one of the computers but it wont work on the other computer? Any help please???
  • Adski01 Apr 16, 2009
    Same problem, One machine will not recognise the montior keyboard or mouse.  Tried the above and none of it works
Plug the key board and mouse directly into the computer that doesn't work, let it recognize the hardware and then reboot. After reboot, plug the keyboard and mouse back into the KVM and reboot again. That solved the problem for me. Most likely, the computer that doesn't work has never loaded the driver for that key board and does not recognize the input sent from the KVM.
Posted on Mar 13, 2009
    Habit-Forming:
  • 188 Answers
MAY BE HARDWARE DONT SUPPORT......
OR MAY BE PROBLEM IN KVM SWITCH...
dont forget to tell me u r problem solved or not
best regards & best of luck..
even u can mail me at my mailing add- sigma_shiva1@yahoo.co.in
Posted on Oct 13, 2007
  • SHIVAJI YADAV
    SHIVAJI YADAV Nov 06, 2007
    hey dude.....u did not make any repley....for u r problem solution ...
    hope it is solved.......
    Was this solution helpful? Show your Appreciation by rating it:
    pls vote for me man..& IF U R PROBLEM IS SOLVED RATE MY SOLUTION AS SOLVED
What is the best way to connect 2 computers to this monitor
If you have two separate computers for different purposes, such as personal and work use, you may find it convenient and necessary to connect both to a single monitor. Many monitors have dual inputs, making such a connection simple. However, you might need a keyboard, video and monitor switch to accomplish this task if the monitor lacks a second input. Dual Inputs
Step 1 Examine the back of your monitor for the presence of dual video inputs, such as a single VGA and DVI or HDMI output.
Step 2 Connect the VGA cable to one computer. Plug the other end of the cable to the matching input on the monitor. Rotate the retaining screws until tight at both ends of the cable.
Step 3 Plug the DVI or HDMI cable into the back of the second computer. Insert the other end into the monitor's digital video input. Screw down the retaining screws if you're using DVI.
Using a KVM Switch
Step 1 Ensure both computers are turned off. Place the KVM switch on your desk where it is within convenient reach.
Step 2 Locate the video output port on the back of the KVM switch. Plug a VGA cable into this port. Plug the other end of the VGA cable into the monitor.
Step 3 Plug the VGA monitor outputs from each computer into the inputs on the back of the KVM switch. Tighten the retaining screws down for each connected VGA cable on the computers and the KVM switch.
Step 4 Plug the keyboard and mouse cables into their respective outputs on the KVM switch. Plug each set of keyboard and mouse cables from their ports on each computer into the matching inputs on the KVM switch. Plug each cable in sequentially to avoid mixing them up between machines.
Step 5 Double-check that the mouse, keyboard and monitor cables leading from each computer all correspond to the right machine. Plug the KVM switch's power cord into a nearby AC outlet or power strip.
Step 6 Turn the computers and monitor on to verify the connections are correct.
Required Items
  • VGA cable
  • DVI or HDMI cable
  • KVM switch
  • Power strip (optional)
I’m happy to help further over the phone at https://www.6ya.com/expert/arturo_82cd53a2264b6f81
Jun 13, 2014 | Acer 22" X223w LCD Monitor
Hi, the CS62U is connected with an HP8750 (win2000) and a MSI WIND NETTOP 120 (win XP home). It works perfectly with the HP desktop but the mouse is not responding anymore.
Try this:
1. Disconnect your HP computer, so that only the MSI Wind is connected.
2. On the keyboard, hit [Numlock]+[-] then press [A] (this will auto-search for the computer that's connected, and connect both keyboard and mouse to that port).
Give XP a minute to detect new hardware. If XP does not detect the mouse, try plugging the mouse into a port directly on your netbook. If XP still does not detect the mouse, it's XP that's not detecting your mouse properly, not the kvm switch. :) If it does detect it, you should be able to then plug it back into your kvm switch and it should work at that point.
Note: if you get stuck with lights flashing on your keyboard, just hit [Esc] on the keyboard. That will reset the KVM switch.
Hope this helps!
Sep 24, 2009 | Altusen Aten CS62U-2 Port USB KVM Switch
Using KVM-121 with 2 monitors
the way the kvm switches works is you have your mouse/keyboard and monitor plugged into the switch then you have the cables connecting to where you would have your mouse/keyboard on your pc, youll be using the same keyboard/mouse and monitor to run 2 pc's. there will be rather a switch to move between the pc's or like the 1 i use i have tp press ctrl the number 2 twice.
Sep 07, 2008 | D-Link DKVM-2K 2-port KVM Switch
I'm currently having to manually switch between my PC and Mac. When I unplug the Dynex Model DX-WKBD keyboard and mouse (both wired) and service cable from the Mac and plus them into the PC, the Number,...
Rather the switching them, you need a KVM (Keyboard/Video/Mouse).
This will allow you to connect the 2 computers to 1 keyboard an mouse. These can be found at any office supply chain that has computer hardware (Like Staples or Office Depot) or online.
To connect it, power off both computers, connect the KVM to each, and then plug your Monitor, keyboard and mouse into the KVM. Power on the systems (one at a time).
Sep 01, 2008 | Computers & Internet
Mouse and keyboard not recognized on second computer
Solution for the mouse. I have 8 KVM's. Most of my computers work with the KVMs. On 1 inland KVM the logitect and Microsoft optical mice do not work on one computer (but work with the other computers). They both are USB. I hook them up with a USB to PS2 adapter. If I use a ps2 ball mouse connected to the KVM the mouse works. All the Mice work if I directly connect them. Since I do not want a ball mouse I got a Frisby optical PS2 mouse. It works with all the computers on the KVM's.
I do not have a solution for the Keyboard yet. 1 computer (ASUS MB) on my trendnet or belkin 4 postion KVM does not recognize the keyboard.
Aug 25, 2008 | D-Link DKVM 2K (DKVM-2K) 2-port KVM Switch
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
Hyundai monitor connects two computers .how do i switch between them?
Use a KVM (keyboard,video, mouse) switch to connect your 2 computers to this monitor. Then you can also have only one keyboard and one mouse. Connecting to the VGA header with one computer and the digital with another is probably not a good idea and the only way that can work is if your monitor has a built in video switch that can be controlled with software. If that is the case they would boast about it in the user manual and tell you how to activate the switch. VGA KVM switches are relatively in-expensive. Some high end KVM switches will exceed the cost of your monitor.
Jan 18, 2008 | Hyundai L90D+ 19" LCD Monitor
Hotkey mode
This just worked for me. Using your PC keyboard, boot up to the PC first and then power up your mac. Hit the scroll lock twice and IMMEDIATELY hit enter. You have to go fast- click-click-click with no hesitation and it works great. I still can't toggle the hot keys to set up my mac keyboard, which I prefer using, but I'm assuming it takes the "right" timing on the keys. I'll keep trying.
Oct 23, 2007 | IOGear GCS632U 2-port KVM Switch
Belkin 2-port kvm switch
If you have the PS2 mouse and keyboard (round plug-in) instead of USB this is an easy install. however if you have USB you will need adapters to make this work, but I do not recommend it since more problems could occur. If you have the PS2 ends first shutdown both computers. remove your monitor, mouse, and keyboard from your computer and attach them to the single end of the switch. Mouse goes to Green, Keyboard to Purple. Take the other ends and connect the first group to your first computer mouse, keyboard, and monitor (same colors as above) and repeat for 2nd group of wires on 2nd computer. turn the computers on. you should get display, keyboard, and mouse for 1st computer. after both boot hit scroll lock 2 times within 2 seconds and then arrow up or down key to change between computers.
Oct 18, 2007 | Belkin F1DK102P 2-port KVM Switch
Belkin F1DK102U 2-port KVM Switch Logo
535 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
