Question about Sony 32 KDL32BX320 32 LCD TV
Sony Bravia tv KDL32BX320 has no power
TV made pop sound and has no power
SOURCE: Cannot remove tv guide banner from Sony bravia 52'
Click on the display button (upper left corner) as a short term fix - it will turn it off immediately - not sure of how to permanently solve this though.
Posted on Nov 07, 2009
  • 630 Answers
SOURCE: my sony bravia has no audio when used as cable tv
Check the connections between the cable box and the TV. If you are using scart check the connector is in squarely if using rgb or composite you need a separate audio connection using the red and white phon sockets.
Posted on Nov 08, 2009
  • 148 Answers
SOURCE: Red Flashing power light on Sony Bravia 40 in tv
Hi there, your problem is that your powerboard is overheating due to poor capacitors. When you shut it off it cools and lets itself turn back on a few minutes later. Your post has been a while, so you might have lost the unit already. If you place a fan (any type house fan) as close as possible to the back of the tv and turn it on medium (at least) it might keep the tv cool enough to funtion indefinitly....If my advise is to late already then follow this guide I wrote on how to diagnose and repari your tv..Good luck and if this post helped you (or not ) then please rate, thank you!
The caps (capacitors) in the powerboard are going out. This is a very common problem in all class and price ranges of modern lcd and plasma tv's/ monitor's. I don't know if this problem has been like this for awhile or it just started, but either way, if the tv takes an abnormal amount of time to "warm" up then it most likely will go out all the way sometime in the (near) future. If you have a tiny bit of will and knowledge ypou can open the unit and get to the print board. Examine this for "popped" capacitors, they will have a buldging top instead of a flat one. Im gonna try to include a pic of them here, if i can get it this time, I've tried bfore lol. But you can google image a "popped" or "bad" capacitor and you would be able, with ease, to diagnose if you have any of these. Usually only one or two. Radioshack sells capacitors (couple anyway) for $1.59 each. MAKE SURE the replacement is of the SAME voltage or HIGHER, or you will be right back replacing those 2. Every capacitor has a negative pole marked with an (-) on the side of the capacitor(by one of the "legs", always puit the negative (-) "leg" of the new capacitor in the same hole in the printboard as where the previous negative (-) "leg" of the capacitor was ( a capacitor with the negative and positive "legs" put in backwards will result in the new piece "popping" as sson as you turn it on!!) make sure the "uf" rating (for example the most common popped capacitor is the 1000 uf) is the same as the one you are replacing. I needed 1000 uf, 105 c and 26v (volt) ratings for the 1 capacitor I needed to replace to fix my LG 19" lcd panel monitor I found by the trash that the light came on off, but it didn't come on. I replaced that capacitor with ; 1000uf, 85 c and 36 v (volts0...It works fine eventhough the volts and the temperature rating (36v and 85c) was not the same as the (26v(volt) and 105c ) capacitor I removed !! Further, I've replaced capacitors that had the celcius rating of 105 with the only ones Radioshack had, namely 85 c(celsius) they have been working great, but I'm not sure about any effect, nor have I heard or read (yet?) about that making an urgent difference. Many threads that I've read people have done the same, so we should be ok (my stuff has been running good for a while longer then most brand new ones!.............(all these ratings ; 'uf ' and 'c' etc are on the side of the capacitor you are replacing and on the side of the ones you are replacing them with)...For all this all you need is the cheapest solder gun u can find (I bought one for $7.99 at Radioshack), a camera (to take pictures as you go to remember how to reassemble the unit) and, once you have your materials, 20 minutes to replace 2 or 3 capacitors and you are good to go...Most monitors and tvs (lcd/plasma) I've seen you have to lay flat on the ground/bed/blanket etc, to work on (screen side down). Usually there are 2 or 3 screws (or a few more) to remove, then you will have to carefully (its comes off easily most times)insert a flat screwdriver inbetween the casing and gently pry it up as you go around the whole frame. Sometimes you have to remove the little washer arouind the cable input orso, just be gentle and you cant go wrong. Once insidet here will be a box with wires running to the sides etc...unplug, gently, these wires and open the box. Inside you will find 2 or 3 circuitboards, check them all for "popped" capacitors, replace, reassemble and plug it in....Have fun becoming an overnight tv mechanic lol!
Posted on Feb 03, 2010
SOURCE: Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Posted on May 30, 2010
SOURCE: i have a 46 inch
i have a 40" model aas well - the only way to turn it off i have found is to restore to factory settings and set the tv up again.
Posted on Sep 19, 2010
I have a Sony 52 inch kdl-52v4100.had a power surge.now tv will not power up
Tv might be fried.Or one of the circuit breakers Is popped. Maybe try a different electrical outlet.
Apr 20, 2015 | Sony BRAVIA KDL-52V4100 52" LCD TV
What causes my sony bravia dlp tv not to come on?
Sounds like it needs a new power supply board.
Here's one: http://www.shopjimmy.com/sony-a-1310-234-a-be-board.htm $69.32 USD
Easy to replace, just open the TV up, unplug and unscrew the old one, pop in the new one!
Jul 26, 2014 | Sony Bravia 50 INCH LED/LCD/Plasma...
After a short power outage, my new Sony Bravia KDL32BX320 (I bought it month ago) shows only a black screen, saying 'selected service is coded OR can not be decoded'. What can I do about...
Tries tv and those Cables,Satalites or Telicoms pay boxes unplug,replug it back like about an hour later.Ur tv now should do a resetting itself back to the factory setting.Those pay boxes will reboot and updated it softwares.Ur tv should have incomming broadcasting tv chanels signal know.If u still have the same problems call ur tv Cables,Satalites or Telicoms compannies for a fix.
Sep 14, 2011 | Sony KDL32BX300 32 in. TV
I have a sony bravia flat screen tv. Often i hear a "pop up" sound from back of tv. What could cause this?
I quite certain that this is the Back Light Lamp Ballast power supply that may be causing this pop. If it's still under warranty. Best to call the local Sony Service shop and see if they can look at this to alleviate future major issues.
Blessings always,
A/V Media Tech Guy
Dec 03, 2009 | Televison & Video
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
FullHD KDL46XBR2 Bravia: No pic, no sound
call a tv place and order a lamp for it if your not old to lift it
May 19, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
Audio issue with Sony Bravia tv
Each time our TV starts the snapping sound we reboot the cable box. Problem solved.
Oct 09, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony 32 KDL32BX320 32 LCD TV Logo
29 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
