Question about Samsung Dishwashers
Our Dishwasher DMT610RHS don't wash at 1h50, until 1h09. At this time, it drain but don't wash again and the soap is always is his open cup.
  • 126 Answers
SOURCE: Dishwasher fills and drains at the same time
your water is syphoning out make sure your drin hose is up
Posted on Dec 13, 2007
  • 1314 Answers
SOURCE: Dishwasher soap dispenser won't open during cycle
both have a wax motor on them that needs to be replaced you just remove the panel and replace the wax motor is what its called
Posted on Feb 16, 2008
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Posted on Dec 13, 2008
heatman101
  • 43501 Answers
SOURCE: Dishwasher soap cup lid will not open during a wash cycle
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
jj
Posted on Sep 30, 2010
heatman101
  • 43501 Answers
SOURCE: Soap does not dispense from cup.
heatman101
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
My office's GE QuietPower 3 dishwasher detergent
heatman101
Jul 29, 2011 | Maytag Dishwasher
The gizmo that keeps the soap dispenser shut until it needs to pop open the dispenser lid during washing has fallen out and will not stay in .
heatman101 ,../,
Mar 22, 2011 | KitchenAid KUDK03ITBK Built-in Dishwasher
My soap dispenser is not opening during the wash cycle,so the there is no soap being dispensed during the wash. This has always worked before, then one day it just stopped opening. What's the problem?
heatman101
Oct 26, 2010 | Frigidaire Professional Series 24 in....
Soap dispenser door not opening up
there could be many solutions from not enough water in the dishwasher
to the piece on black backing in between the door and inner linning has warmed up and slide down restricting the soap door from opening
the lack of water could be from a defective water fill valve or a restriction in the drain line holdingf the drain valve open alowing water to escape
when the machine fills open the door see how much water is in it close the door wait 2 min open the door again if water went down the problem is arestrictioninthe drain valve (water should fill to touch the element in the bottom i hope this helps
Oct 17, 2009 | GE 24 in. GSD6600G Built-In Dishwasher
heatman101
Sep 07, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Dishwasher runs but does not get dishes clean
1.) Confirm that the holes of the spray arms are not blocked with debris.
2.) Run a short cycle with an empty dishwasher and no dishwasher soap. Run the dishwasher until you hear it finish filling with water and begins the wash cycle. Add up to two cups of white vinegar to the water and allow to wash and drain. Feel free to do the same when the dishwasher fills again.
3.) Only use a brand name powder detergent (e.g. Electrosol or Cascade) in any dishwasher. Do not use a gel or tablet in any dishwasher. Do not fill the dispenser fully.
Test your dishwasher with a standard load of dirty dishes.
If problems continue, confirm that the heating element is working properly. The heating element is vital to getting clean dishes with modern dishwashers and DW detergent.
Please report back what you find.
Apr 08, 2009 | KitchenAid 24 in. KUDP01IL Stainless Steel...
heatman101
jj
Dec 31, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
FRIGIDAIRE DISHWASHER FDB1050REC0 LEAKS UNDERNEATH
There are a couple reasons water may be leaking out the door of a dishwasher.
1. The water is most likely coming out the bottom of the door where there is no rubber seal.
2. The rubber seal is around the door jam on top and both sides and not on the bottom. This means if the dishwasher has to much detergent in it the soap suds push only the water higher than the front edge of the wash basin and out the bottom of the door where there is no seal!
3. Fill only the soap cup that can close for the secondary wash. The open cup is a pre-wash and mostly not needed unless the food is baked on.This just wastes money to fill both of them every time.
4. And if you are using liquid detergent you only need half the amount from the powdered soap!
try less soap. Remember to much soap too can cause the water overflow.
5. And the last would be that the drain is clogged and caused a back up large or small and then the overflow!
is there water in the bottom when the wash is done?
Soap is usually the culprit, not that there can't be a leak in an old drain or water supply hose!
Go with the soap idea first!
Let me know how you are!
How old is the washer ?
Please remember to leave a rating before you go!
Thank You ,Huuum
Sep 27, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Soap remains in soap cup after complete cycle is run
I had the same problem. The door on the cup does not open all the way. Here is what I did. On the back of the dishwasher door are 7 phillip head screws. Take those out and the door inner cover comes off. There are 2 pieces of black insulation that are glued to the cover. The smaller one had slid down to where it was blocking the cup door from opening all the way. Pull this black insulation off and put it back in the right place. I even put a little hot glue under to keep it from sliding again. Hope this works.
Nov 18, 2007 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwashers Logo
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
