Question about Whirlpool Washing Machines
Cabrio washing machine wtw6800, ul before final spin
Unbalanced load, no final spin
  • 641 Answers
SOURCE: Washer makes loud thumping after finished spin cycle
Remove washer cabinet (easy to remove)and check that "base pads" (there are 3 pads, located under the main tub)are not worn. In case they are worn (even one of them), you should replce them all. Good luck !!
Posted on Jun 07, 2006
SOURCE: unbalanced load cabrio top loader
i am on line now- we checked with a level and its right on... i have been washing on the normal cycle and then using the drain/spin cycle to spin out as much water as i can..that cycle even displays the ul code...its always displayed somewhere between 12 mins left and 7 mins left...i dont know if that has something to do with it??
Posted on Jan 13, 2008
  • 18 Answers
SOURCE: Unbalanced load
If your washer goes severely off balance you need part # W10112113 to fix it.
Posted on May 10, 2008
  • 2976 Answers
SOURCE: Washing Machine Moves in Spin Cycle
There are 2 things you can do.
All washing machines have an off balance shut off, some are touchy, some let it run around the house. With wht machine empty, lean it towards you, on the 2 front feet, about 2 or 3 inches and let it drop. The self leveling feet in the rear must BOTH make good floor gontact and sometimes, just the weight of the machine will not adjust them. The other thing is, make sure the load is evenly distributed. Coats, blankets, small rugs etc. are very heavy when wet and they tend to throw all of the weight to one side.
There is no screw holding the yub in place. It hangs on the center post, where the agitator goes. There is however, what's called a snubber. It is a rubber device that looks like a flattened suction cup, that comes in contact with the tub. It helps keep the tub from jumping around too much.
Posted on Feb 02, 2009
SOURCE: Asea (Asko) Cylinda 12000 Washing Machine Spin Problem
No reset. Carbon brushes are worrn out. Consider changing the bearings while you have the motor apart. Se http://www.nettoparts.co.uk/shop/frontpage.html for spares.
Best regards, Dag Gulbrandsen, Norway
Posted on May 16, 2009
Whirlpool Cabrio gets unbalanced load at 7 minutes
Make sure load is properly sorted with like materials and paired up, do not mix things like towels with pants or shirts all together as different items absorb more water then others and can create unbalance when trying to enter final spin. If issue continues, it is very possible and item of clothing may have found itself stuck between spin basket and outer tub. This is very likely scenario due to design of this washer. If that is the case, spin basket must be removed then remove clothing to resolve issues.
Jun 02, 2014 | Whirlpool WTW6400SW Cabrio Washer
When the washer displays uL when spinning?
'Unbalanced Load' occurs when the machine detects that one side of the tub is heavier than the other.
This most often happens when heavy and/or large items become pushed to one side of the tub during the wash and become much heavier when the spin cycle engages.
This is more often seen in 'tub' style machines rather than front loaders.
Usually the machine has a safety system which shuts down the spin cycle and 'buzzes' to alert you to reach in and move things around in order to rebalance the load.
Jun 04, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Ul is displayed what does this mean
UL Stand for unbalanced load
probably the balance rods washer has 4 of them and they work like shocks for the tub and if they go bad than they allow the drum to spin wildly.
Jun 03, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing machine out of balance
Unbalanced load. I read somewhere the cure from the manufacturers is to remove the counterweight at the base of the machine and add springs to stabilize lateral movement. You could see the actual service matters bulletin if you paid the $500 subscription fee. LOL
Service manual anyone?
Bravos/Cabrio washer breakdown
Jul 23, 2012 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Whirlpool Cabrio spins off center and stop with ul code
Ul-Unbalanced Load
uL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
Display clears if mini-cycle successfully rebalanced the load.
If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute
the load.
May 28, 2012 | Whirlpool Washing Machines
Have a Whirlpool Cabrio top loader washing machine, keep getting code F1 during beginning of cycle. Got code uL for the first time today. What do these codes mean.
Have a Whirlpool Cabrio top loader washing machine, keep getting UL code when spin on high speed and the machine bangs all over the place.. Model num wtw6300sw0 Type 581
Aug 23, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Wtw6600 washer has UL code and has trouble agitating and spinning.
The UL code means Unbalanced Load. Open the lid and move your clothes around so they are distributed evenly. Your spin cycle will then work normally.
Apr 07, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I receive a UL code on my Cabrio and it the clothes are very wet after spin cycle...
The ul error code means unbalanced load.If the load in the drier is much more than it can take, the system will not perform its operation. I can suggest you go to www.applianceaid.com where they have very good trouble shooting and repair information on washing machines and other appliances. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad.
thanks for rating good luck
Feb 04, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
UL keeps coming on the screen, will spin for 1 or 2 minutes and then UL shows up again
Hi, UL means Unbalanced load in Whirlpool Cabrio....
UL is displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load. Display clears if mini-cycle successfully rebalanced the load. If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load....
Oct 05, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Noisy when trying to spin. display uL instead of time remaining. Stopped, opened lid and redistributed load. Started up again. cycle continued but still displaying uL. Not sure if load still unbalanced?...
REPLACE YOUR SUSPENSION RODS. You can get them at a discount applicance parts store online for about $60. Our washer is about 8 years old and has been getting unbalanced on every load. I replaced the suspension rods tonight and and it solved the problem.
Jan 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
