Motorola Flash Mode Bootloader Version BOOT_C_03.08.00R.MPAP Please connect the USB CABLE I got this message in the morning after charging it over night. It's stuck here.
Hmm - that kind of message is most likely the basic boot loader in the unit getting activated, this would normally be used in manufacturing to get the 'product firmware' (the programme that makes the product do what it does) into the unit on the production line.
For this to be appearing in customer hands I'd suggest that the product firmware has gotten corrupted. Being unable to run the product firmware the unit is entering it's bootloader and expecting new firmware to be put into it.
Unless your product manufacturer's support webpages have firmware downloadable for the product, along with details of how to do it, then i'd suggest that your unit probably needs the attention of an approved service centre or manufacturer service department.
If the product is still under warranty then the warranty may cover fixing this fault - check terms and conditions and/or contact the manufacturer or the store you bought it from - you may get it fixed free or replaced under warranty by the manufacturer or the retailer.
If it is out of warranty then it may likely cost something to get your product repaired, but it's probably worth making enquiries - a repair may be worthwhile but you'd need to find out cost. It may be worth contacting the manufacturer and asking if this is a known common issue with this product - if it is then they may have put a mitigation plan in place to support users that experience it and if so this may be available even if the unit is out of warranty.
Hope this helps y'all to understand the message you're seeing on the display. Would be interested to hear if you get it sorted.
Cheers,
BB
Thanks boola boola.....for the common sense that anyone with a brain already knows. what a waste.
I think you should take back to the store and see what they can do
I brought it to the store this morning and the technician there re-flashed the system. Since no hardware damage, they did not charge me. Hope this helps. Last time I got it replaced. If you are told you no way to figure it out but replacement, it should be the technician's incapability.
I had This Same Problem
Bola-Bola is spot on, you are SOL when you see this message. When Charging over night make sure you have a good connection in the USB port or else this will happen again.
my battery on my Q was running low last night and then it died. i charged it last night and this was the message:
Motorola Flash Mode
Bootloader Version
BOOT_C_03.08.00R_MPAP
My phone will not turn on, i have taken the battery out and put it back in after 5 min. and it still does not work.
same problem
I have the exact same problem. This happend to me after I let my battery run all the way out. I charged it up and when I tried to turn it on and got the following message:
Motorola Flash Mode
Bootloader Version:
and after about 2 seconds the phone goes right back off!!! I had this phone less than three months!! And now I have to pay to get a new phone!
CARGED IT UP AND IS NOW SAYIN BOOT LAOGER
boot_c_03.08.00r_mpap
its noy turning on
exact same problem stuck in boatloader flash mode
Boot Loader
OC.70.
SW Version:
Not Found
OK to Program
Connect USB
Data Cable
bought the phone for my bf less than 3 weeks ago. it started just shutting itself off a few days ago and we'd have to take the battery out to restart it. then last night it wouoldn't go back on. the message showed up this morning. we read the manual we plugged it in the charger we plugged it in the computer we took the battery out and replaced it. what next?
Am having the same problem
Motorola Flash Mode
Bootloader Version
My phone is stuck in motorola flash mode
This phone really sucks.
I got this problem and went to the store, they just replaced me a new one. After using it for 8 months it fucked me again by the same problem. It seems the average life of moto Q is 8-9 months.
so how do i go about fixing this problem
BS...........
I have the same problem but a number changes it says
otorola Flah mode
boot-c-03.05.oor-mpap
please connect the usb cable
