Question about Microwave Ovens
Panasonic microwave nn-sn960s replace internal thermal fuse
5 Suggested Answers
SOURCE: PANASONIC MICROWAVE NN-S960BC/WC
i had same problen, i changed the fuse inside the microwave, works good now
Posted on Mar 28, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Internal ceramic fuse repeatly blown.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead several seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount. See: http://www.microwavedisplay.com/doorsw.txt in this case.
If this unit has an inverter some parts are difficult for the average do it yourselfer to replace, such as parts which are spot welded, not using removable connectors.
In such cases, it's best to replace the entire inverter.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on them.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
You can order Panasonic parts from
Encompass or by calling 866-779-5835.
Posted on Jan 10, 2010
  • 5370 Answers
SOURCE: My Panasonic NN SN960S just
If there is no power at all, then its a fuse problem, or the power cord shorted issue or the board issue.------ The power to board has to be checked by meter.Also the power to the power supply cord has to be checked by meter.As you mentioned that fuse is replaced, then other 2 possibilities are to be checked.This problems are not very common and occurs very rarely.But in most of the cases its fuse or main board.But directly before replacing main board .I suggest get the power checked to the power cord wire and main board with meter.This will help, to confirm the issue.------ Thanks.Helpmech.
Posted on Jul 08, 2011
ercupa190
  • 12223 Answers
SOURCE: panasonic microwave nn a554w
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Rewmember use the DVOM
Posted on Apr 02, 2013
Where can I get an internal thermal fuse for my Panasonic Microwave NN s335wf
Any local appliance repair shop will have this fuse, but you need the old one to match it to the new part. Check your Yellow pages phone book.
Aug 19, 2016 | Panasonic Microwave Ovens
It just beeps when plugged in cannot press anything to start it timer menu does light up model # nn-sn960s panoasonic micro wave
Panasonic Microwave - ConsumerAffairs.com
www.consumeraffairs.com > Homeowners > Microwaves
Rating: 2.6 - ‎53 votes
After looking, door was starting to arc and burn around the edges in three places, ...You can't leave this oven unattended for a minute or you could be calling 911! ... In October 2014 I purchased a Panasonic microwave model NN-SA661S. ... The timeremits "4 beeps" when the time is up; other microwaves, continue to beep ...
[PDF]operating instructions - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/microwaveoven/.../nn-sn651_nn-sn661...
PanasonicModels no. nn-sn651b ... nn-sn661s .... Use this appliance only for its intended use as described in this manual. do ... Thank you for purchasing a Panasonic MicrowaveOven. ... you press Start. note: The Glass Tray can turn in either direction. ..... If a pad is pressed and no beep is heard, the unit did not or cannot accept the
Jan 19, 2016 | In Microwave Ovens
Panasonic Microwave NN-CT552W has no power - plug fuse ok - Has it got a thermal cut out or internal fuse? - Unit was ok after cooking some jacket potatoes
All microwaves has both internal thermal cut out and internal fuse, Yours problem sounds like an open 9 volts transformer that power up the front panel
Nov 07, 2014 | Microwave Ovens
Panasonic NN-SN960S, turntable won't stop spinning. Have to unplug after every use. What kind of repair does it need and how much would it cost?
May be a door switch problem, or may be a control board problem. You might even have a shorted wire that goes to the turntable motor. (I have seen 1 of the wires get pinched and cut by metal guards or guides that were meant to keep the wires in place.) You can remove the screws from the bottom of the microwave oven, and drop the bottom panel down to checked for pinched wires. Unplug the microwave first before you do that.
Oct 18, 2014 | Panasonic NN-SN960S Prestige Stainless...
Microwave won't start
If your microwave has been worked on then possibly the nuts securing the magnetron has not been properly tightened
Dec 08, 2013 | Panasonic Microwave Ovens
Where is the high voltage capacitor at on panasonic microwave model nn-sn960s
behind the control panel,while your checking the h.v. cap check the h.v. diode for a shorted condition as this will also blow the 20 amp fuse too
Jan 06, 2013 | Panasonic NN-H275 Microwave Oven
Where is the second fuse in my panasonic nn-s963bf the one for the heating and what does it look like?
There is no second fuse. Look for a thermal cutoff there are a few of those. Test it for open circuit and replace.
Aug 11, 2010 | Panasonic NN-S963BF Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
