Question about Amana PTC093B50AJ Electric Heat Air Conditioner
PTC073D35ARDA electric heat and air need to know how to reset manual heater
Enerzen customer Service address ... website phone number anything. I can find a remote?
New Enerzen 2000 Sq Ft Infrared Quartz Electric ... - eBay
www.ebay.com > ... > Heating, Cooling & Air > Space Heaters
eBayNew Enerzen 2000 Sq Ft Infrared Quartz Electric Portable Watts Heater in Home & Garden, Home Improvement, Heating, Cooling ... Duraflame Colby 1000 Sq Ft 1500WInfrared Quartz Electric Portable Heater Cherry ..... (1) Owner's Manual ...
Enerzen pro heater manual - Fixya
Nov 29, 2015 | Heating & Cooling
I have a Dimplex Heater model no DS5629BR Can't get any heat I have unpluged it & and still can't get any heat. Dont see anything in manual about thermostat being bad or changing it all it said w
Have an electrician check it out.
The heating comes from coils of wire which glow red heat. Air from the fan passes over these coils and keep them from burning out.
If the unit has overheated, it is very likely that one of the coils has burned out and there is no electrical circuit, hence no heat.
An electrical repair shop will be able to verify this for you and fit replacement coils.
Jan 06, 2015 | Dimplex Heating & Cooling
Where is the Manual Heater Reset Switch on an Amana A/C and Heater Unit Model number PTH093B35AJ? The unit has several stickers that state it has a "Manual Heater Reset Switch".
Almost certainly it is a bad relay on the circuit board. Sometimes you can slap the side of the unit by the control box to temporarily unstick the relay, after which the heat will come on for a cycle or two. There are two relays on the circuit board marked "heater 1" and "heater 2". You can order a new circuit board for about $100 or replace the relays at $4 apiece (order online from Digi-Key, requires solder connections). Part number JTN1a-PA-F-DC5V.
Jul 18, 2014 | Amana PTH093B35AJ 9100 BTU ThruWallWindow...
Heat surge amish heater turns off and trips reset button
Do NOT use this unit as is!.
My experience is you have to pay to ship it for repairs and if out of warranty you should buy another heater. All electric heaters use the same power for the same heat unless its a heat pump, so save money and buy $30 WalMart heaters.
Nov 17, 2012 | Heating & Cooling
I would like to know location of reset button on hot water heater
If you have tank-type electric water heater, ECO reset is located on upper thermostat which is behind panel on side of water heater.
Be sure to put insulation back in place when finished so thermostat not exposed to cool air that will cause temperature misread.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
If you have gas water heater, call service technician, and/or read manual.
ECO reset requires gas control valve replacement in many cases.
FV lockout requires replacement parts.
Some tanks have resettable thermal switch located behind gas door panel.
http://waterheatertimer.org/How-to-replace-gas-water-heater.html
If you have tankless, call service technician, and/or read manual.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Apr 21, 2011 | Water Heaters
Heater won't heat up. Anything we can do to reset it?
repost what kind of heater gas or electric.... reset breakers to it and let start over...regardless gas or electric...jump out the "r" terminal and the "w" terminal at thermostat by removing cover this is power and heat circuit does it work this way....
Jan 12, 2011 | Heating & Cooling
I live in a rented home and my heat is not coming up through the registers, could the filters be clogged, we know nothing about heat pumps. Should we check the filter first, before calling our landlord in...
If it is forced air heat then you should change the filters. Also check to make sure the heater is kicking on. The main heat trunk line should feel warm right by the heater.
Jan 22, 2010 | Ruud UBHC Air Conditioner
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model http://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
My (Rheem)electrical heater is not heating the
Check all your manual reset limits. There are two wires that go to a small disk about the size of a penny. In between those wires is a small button. Press the button firmly. You will have between 2 to 5 of these. There is also a limit switch located on the back wall of the unit that enters in the heat exchanger but it is not resetable that could be bad. You will need to check all of these. They can be jumped temporarily by removing the wires and adding a small wire.
Apr 06, 2009 | Heating & Cooling
Unit blows cold air instead of warm (burrrr)
FAULTS ARE STORED WITHIN THE CIRCUIT BOARDS MEMORIE TRY UNPLUGGING IT FOR 2 MINUTES AND PLUGGING IT BACK IN
Nov 23, 2007 | Amana PTC153B50AJ Electric Heat Air...
Amana PTC093B50AJ Electric Heat Air Conditioner Logo
27 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
