Question about Sony VAIO NS Series Notebook
Vgn-ns38e do not power on - no power led - cmos varta 0.1V - laptop batt discharged
2 Suggested Answers
Paeroa
  • 457 Answers
SOURCE: Cmos battery
You must enter the laptop internally that is.  In some laptops it is soldered to the motherboard be prepared to find that.  Did you know it takes a long time for the battery to be stuffed because.  Are you certain that the problem is the battery?.  If it is stuffed your bios would have resetted itself to the default settings and will not hold your settings.
Posted on Oct 10, 2007
How to remove power on password HP Pavilion dv7-1245dx
another method I have used that works is to remove CMOS batt as you have done before - do not replace it yet though.Power on the dv7 without the battery in then off by holding down the button until it switches off.Remove AC power hold down power button 5 secs to dissipate power and replace CMOS batt,plug in AC and test.Hopefully it clears the bios settings for you
May 26, 2014 | HP Pavilion dv7-1245dx Notebook
Bio password
Here is a complete guide to disassembly of the VGN-SZ laptop.
http://home.comcast.net/~nw_systems/vgnSZ.pdf
The trick here is to get to the CMOS/BIOS (referred in the manual as the 'reserve') battery. Remove this battery and leave the unit with no battery, A/C power or CMOS battery for an hour or so. Then replace the CMOS battery and reassemble. Power it up. Its going to 'yell' a lot since the BIOS was flushed and all information will have to be put back in. However after you do this, you should be all set.
Hope this helps!
Jun 21, 2011 | Sony VAIO VGN-SZ440 Notebook
How to do a step by step removing battery from cmos or bios to reset the password
u will hve to take out the cmos batt.from the down bord assembly and restart it with fan working .
miro cell is inserted into it's bay
Apr 23, 2011 | Sony VAIO VGN-FZ340E Notebook
Need to disable cmos password protection (ex-girlfriend issue!). Does it need to have a jumper disabled or is there another way? Thanks
After a quick read-through of the user manual for the P505-S8950, the only way to discharge the CMOS memory seems to be removal of main battery and power cord for and extended period of time in order to cause the CMOS battery to discharge.
There may be a way to open the laptop and remove the CMOS battery to speed-up this process; however, my previous experience with taking apart a Toshiba laptop led me to the realization that they are not designed to be easily disassembled -- I had a heck of a time reconnecting the display data cable (I had to use a chopstick and have a lot of luck to get it back together).
I would suggest opening each of the access doors on the bottom of the computer in order to determine whether or not you can get at the CMOS battery that way; otherwise, I think your stuck with waiting a LONG time for the CMOS battery to discharge or VERY carefully disassembling the laptop.
Dec 29, 2010 | Toshiba Satellite P505-S8950 Notebook
Need one time bios password for sony vaio laptop, electrical storm jacked up the operating system lost bios password, need to run diagnostics model numbe vgn nr140e can you help
in order to reset the bios password you will need to remove the cmos battery and leave it out for about 15 minutes. This allows the stored up charge in the capacitors to dissapate, and after they discharge is should be reset back to original factory bios setting.
once into your bios, make any changes needed for specific hardware before you reboot computer and go into diagnostic testing mode.
Dec 17, 2010 | Sony VGN-NR140E/S Notebook
Time and date stop when laptop powered off.
it sounds like the cmos batt had the same problem with my desk top once changed cmos batt all was fine .the batt is located on the under side of the laptop you will see some removeable panels just check under these,but be carefull the batt might be soldered in, some are some are not. if soldered in you might want to get a professional to change it as the heat could damage your computer.
hope this helps.
Apr 25, 2010 | Computers & Internet
DIP SWITCH BIOS RESET POSITIONS SONY VAIO VGN-fs660
There are 2 ways you can reset your bios2_bing.gif.
1. On the motherboard there is a small watch battery. Remove this battery along with the power cable from the power supply. Hold down the power button to fully discharge the system. Wait 2-3 minutes then reinstall the battery and plug in2_bing.gif your system. Your reset is now complete
2. Some motherboards have a 3 pin jumper by the battery. Lets say that the jumper is on pins 2 and 3. Remove the jumper while the machine is OFF and place onto pins 1 and 2. Power on your machine for a minute. (Note: Your system will not POST). Shutdown your machine and put the jumper back to pins 2 and 3. Your reset is now complete
This is a great troubleshooting2_bing.gif step for those of you having POST issues or no POSTing at all. Like other troubleshooting steps, this will not always work but usually will depending on the problem.
Please let me know if you have any further questions or concerns.
Thanks.
Sep 30, 2009 | Sony VAIO VGN-FS660/W Notebook
Sony vaio power up issue
hi
u carry out your laptop battery and then restart and if you find still problem, and want technician help contact http://tinyurl.com/msfzw7
Jun 20, 2009 | Sony VAIO VGN-NR160ET Notebook
Power problem
Hi Odek, You have to short the CMOS reset pins on the motherboard. You can find the location of these 2 or 3 pins on the motherboard manual. For Enisco's problem the monitor power cable is not properly earthed. You can either earthed it by connecting a wire from any conductive part of the monitor to a earth pin on the wall plug or something conductive near the monitor like a will sill. I would probable change the wall plug or the faulty power board. regards
Jun 07, 2008 | Dell Inspiron 5160 Notebook
LX7 Mouse False Low Battery Reading
I have found that sometime these Rodents seem to have a "Taste" for a certain "Type" of AA or AAA cell, one needs to get the Highest Discharge rate one can get. Often the "Brand" of Batts supplied are the "Only" ones that seem to work 100% alla time? I have had similar problems with customers B4, and I find the Varta series of battery to be great. & remember just because you bought them "New" don't mean the Batts are always "Fresh", get batts from a place that has a high turnover.
Aug 10, 2007 | Logitech LX7 Cordless Optical Mouse
Sony VAIO NS Series Notebook Logo
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
