Question about Radio Communications
Cobra 29gtl Cobra no trans or resive
    Genius:
  • Radio Commun... Master
  • 1,795 Answers
Do you have power to the unit? check with a multimeter to see if you have power to the board.If you do then flex the board to see if the radio recieve comes on.If it does then take it to a tech to have him trace it down as to what it is.
Posted on Sep 17, 2014
3 Suggested Answers
  • 19 Answers
SOURCE: Cobra 29GTL Won't Transmit
if the red ant light comes on this means that you have antenna trouble either in the antenna itself or the coax but this should not have anything to do with the radio not transmitting. it sounds to me that you have a bad audio chip or a bad power output transistor. in either case you should really take it to a cb shop and let the professionals solve your problem, good luck!!
Posted on Aug 17, 2007
  • 37 Answers
SOURCE: cobra 29gtl
go to cbtricks.com and youll find all the info you want.easy to get 25 to 30 watts if you know what you are doing Thanks...Dean
Posted on Mar 16, 2008
Cobra 29 ltd hooked up dackwards replaced protector diode and out put trans. but still only key 1/2 watt and mod. 1 1/2 watt/ do you have any sug. thanks
Check transistor TR 15 and TR 16. They are the driver and the buffer. Adjust L 16 and L 17 if no change check L17 L20.
Jan 24, 2018 | Cobra Radio Communications
Cobra 29gtl.no tx no rx on am
only has AM but could be a number of things.First,turn radio on,make sure its on CB not PA,turn squelch all the way to the left and RF gain all the way to the right. You should at least hear something by now. If not look on the front of radio and see if any lights are lit.If the tx light and the awi light are lit its because you have a bad match on your radio.Make sure your antenna is grounded so your signal can be picked up. take a piece of wire and touch the antenna bracket and a ground at the same time.You should hear something. this is as far as you can go without more knowledge of the radio.
May 08, 2014 | Radio Communications
I have a 99 mustang cobra and changing the clutch. I am stuck on taking the bolts out of the bellhousing. How many is there and what is the best way to get them out?
there is six bolts holding the trans. the best way to get the the bolts out is to go ahead remove the drive shaft and than the cross member to the trans. you will have to remove the starter because it is attached to the trans with two 5/16 bolts or 1/2 socket. let the trans hang down so you can see all the bellhousing bolts. remove them but be sure you have a jack under the trans. this is about the easiest way make sure you let the trans hang.
Jun 13, 2010 | 1999 Ford Mustang Cobra
Is the motor from a 2004 Cobra an easy swap into a 1996 Cobra?
no you will need to change the exhaust, engine mounts, transmission mounts, tail shaft, trans cross member, wiring loom and computer if not more stuff i am shore it can be done but the expense will be huge
Oct 01, 2009 | 1996 Ford Mustang
Upper engine knock
PULL VALVE COVER INSPECT ROCKER ARMS AT REAR OF MOTOR FOR LOOSE OR BROKE SPRINGS OR ROCKER
Mar 23, 2009 | 1999 Ford Mustang Cobra
Cobra 29 is one channel off, ch 7 is on ch 6 and so on
The radio needs to be tuned.  This should only be done by a licensed repair shop.  You will spend less money taking it to a shop than you will buying testing and tuning equipment needed to do it yourself, which would void the warranty.
Dec 11, 2008 | Cobra 29 LTD CB Radio
Cobra 29
To my knowledge and depending on what board your Cobra 29GTL used, R46 is 47ohms dropping resistor after the switched 12V. Its output is then filtered by C20, 100uF/16V. While it is true that a shorted C20 would burnout R46, the issue is most likely a shorted FET2 (P/N 2SK104H). Should FET2 proved to be shorted, then it is very possible also that inductor/coil near FET2 is defective (LT-A108?).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 15, 2008 | Cobra 29 LTD CB Radio
Cobra 29gtl
Mar 15, 2008 | Radio Communications
Aug 16, 2007 | Cobra 148 GTL 120-Channels Base CB Radio
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
