Question about Hitachi 57G500 57" TV
No picture When I hit the Power button, I can hear it click like it's turning on, but I get no sound and no picture.
  • Anonymous May 29, 2008
    MY PICTURE ISN'T WORKING AND NO SOUND. I TOOK THE BACK OFF AND 2 LIGHT ARE BLINKING A GREEN ON AND A RED ONE.
  • slvrlf8706 Jun 16, 2008
    push power button clincking sound but no picture and no sound
    Genius:
  • 1,153 Answers
You have to check in back of set to see which LED's are lit? This tell what is wrong with set.
Posted on Oct 09, 2007
SOURCE:
Set is getting power, but no sound or picture. we purchased it black friday
Power supply issue such as bad caps etc. But need the model number of the set in order to assist further.
Feb 08, 2012 | Hisense Televison & Video
Constant clicking sound when turned on....no picture....looks like TV isn't on. You only hear the constant clicking. You have to cut power to stop it.....hitting the power button on the TV doesn't...
Sounds like bulb is burnt out. Have replaced its the cheapest way to go. It may be a power board but if its out of its warrenty, then you may just want to buy a new set.
Aug 02, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
TV turns on sometimes
Maybe they got an electhrolitic capacitor near the horizontal side of the tv maybe about 250 volt to 1 mf or more
Apr 12, 2010 | Zenith B27A11Z 27" TV
Plasma Hyundai 42'' TV ,NO SOUND OR PICTURE
most times then not it's the capacitors on your power board that blew there for not supplying the tv with enough power if you open it up and check the capacitors it should be leaking some kind of liquid or the tops have bubbled up. its an easy fix cost>>2 dollars each
May 21, 2009 | Televison & Video
No picture, no sound?!?!
This could be a number of things. Your lamp could be bad or it needs to be reseated to the ballast. The lamp is trying to light and it will make the ballast flicker (that is the clicking sound) or your ballast is bad and it needs replaced (it will flicker and click too). Or your color wheel is broken and it will make a clicking sound when turning. If the color wheel is not spinning or broken it will not light the lamp. No lamp no picture.
Dec 12, 2007 | Samsung PCN5425R 54" Rear Projection...
Multiple issue,power light flashes
Sounds like first loose connection on circuit board. I would first look around the relay this is what clicks. Then also the low voltage transformers. These problems are always concerns when set is moved or bumped hard. Try this first. Or it could be a heated issue.
Nov 26, 2007 | Philips 50P8341 50" Rear Projection...
Hitachi 57G500 57" TV Logo
128 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
