Screen says signal cannot be decoded
It is a BRAVIA tv no picture no sound a message in lower corner reads no signal select another input using the input button or connect an R F cable This happened over night. Checked antenna all is good. Thankyou.
SOURCE: I Just connect My pc via 15 pin RGB cable to LG
You probably need a audio cable that runs from the pc audio out to the TV audio in. Radio shack has them so do a lot of hardware store and best buy.
Posted on Aug 18, 2009
rylee_smith
  • 8619 Answers
SOURCE: HDMI input does not work
Hi
Thanks for using FixYa. Two things may cause the “No Signal” message to come up are - no data available for closed captioning and a weak signal input. Your TV is in the Closed Captioning Mode. To turn it off simply bring up the on screen menu and scroll down to the part that says closed captioning and turn this function off! With the closed captioning block displayed and the program being viewed is not sending out closed captioning signals the TV will display, No signal!
I’ll suggest you to run the HDMI from the PVR (personal video recorder) directly to the TV (mute the TV), and then run the optical audio from the PVR directly into the receiver's optical in. The closed captioning is something that is addressed in analog broadcasts, but not necessarily digital broadcasts. Try using Component cables if this doesn’t make a difference. After using components cables the issue will be resolved. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 12, 2010
SOURCE: Sony Bravia does not recognize my Dell Inspiron 1525
I have the 1525 and you have to do extra steps each time you want the HDMI to be recognized by the Bravia - too bad it is not automatic as it is with some. Anyway what you have to do is have the HDMI cable connected from laptop to TV then go to your desktop - right click on an open area (away from icons), a menu will appear, let the cursor hover over Graphics Options - you'll then see Output To...then you'll see Intel Dual Display Clone...hover over that and you'll then see Notebook + Digital Television...left click on that and you should see your desktop on the TV in a few seconds. If it does not work the first time...get your movie or whatever you want to show up and ready and go thru these steps again...stupidly complicated aye? when it should automatically detect and show...are other TVs like this?
Posted on Dec 07, 2010
  • 4 Answers
SOURCE: Hello My, just bought Sony KDL
I have one of these. It is probably set up for some other program like the HDMI or Input 1 through 5.
You can press your INPUT button, then scroll to the TV function, which should show up on the top.
Posted on Jan 09, 2011
  • 5427 Answers
SOURCE: I clicked a button by
What input is the cable connected to? (Coax antenna In, component video, composite video)
Look on the remote or the TV itself for a button marked Source or Input. Press this. For some TVs, use the up/down arrows to select the input to which your cable is connected. (TV = coax) On other models, you may need to press the Source button several times to advance between inputs. (I'm assuming you have a remote that works for this feature on the TV; otherwise, use the TV button.)
I hope this helps.
(common modern TV setup: VCR on AV1, DVD player on Component 1, PC to the HDMI/DVI and coax to the antenna in. The source button is needed.)
Posted on Apr 26, 2011
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
Unable to view my prima Ty , when I turn it on I have only a light blue screen , no sound and on the top right corner it reads...cable mono. 3...
With no input signal that would be what you would see. Check your input connections. Do you have cable, antenna, or satellite ? Do you have a digital decoder box ? You're definitely not getting a signal from your normal signal source.
May 16, 2011 | Televison & Video
My Sony Bravia tv has a problem with the screen getting dark on the right side. Sometimes the screen is normal, and then sometimes it goes dark and/or red. There is a small square (2 inches) that has a...
This tv have a problems with a board that call T-CON decodering board.This T-CON decodering board sit at the bottom in the middle of the LCD screen panel.This T-CON decodering board,decodering the tv incomming broadcasting tv signal before it go into the tv LCD screen panel to produce pictures.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decodering board for the replacement.
Apr 23, 2011 | Televison & Video
The tv can plug in on 220 power voltage
If you have your owners manual check the specs, however most Sony Bravia units have universal power supplies (120V-240V 50/60Hz). If the TV was built for North American use the tuner may not be able to decode the signals in Europe or Asia, they will need to be converted to standard HD signals (1080i, 720p etc.connected with HDMI or Component inputs) to be displayed.
Dec 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony BRAVIA volume problem
I had this same issue, and solved it by putting the TV in "Theater Mode', which can be acheived by hitting the "Theater" button on the remote.
Sep 07, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Completely lost the picture and sound. All that
You didn't mention from where your signal originates and that clue screen is common to many sets and means it is seeing no input signal.
The set would seem to be functional, otherwise you wouldn't be seeing the input selection menu.
While it is possible that the RF section/tuner (that handles the signal coming in) has failed, these are pretty solid.
If you have another set or can borrow one to connect to whatever source you have (antenna, cable, satellite) to see if a signal is, in fact, there.  As an alternative, you could connect your own signal source; VCR, DVD player, or, as it offers, HDMI or a PC and set it to whichever input you have supplied with signal.
Mar 30, 2009 | Toshiba 23HLV86 23 in. LCD TV/DVD Combo
No signal
you have to take the remote, find the input button, push the input button untill your picture comes back, you should see the input go from cable/antenna, to vid 1--vid2---vid3---if pushing the button a couple of times dont change it, you will have to hit the input button, then arrow down, and select the nexy one, do that untill you find the picture
Jan 10, 2009 | Sony KDF-E42A10 42 in. LCD Television
Toshiba Model 42HM66 DLP Projection TV
I strongly doubt it's the lamp assy since you can actually see the blue screen. If the lamp failed, you would not see anything on the screen. This blue screen indicates to me that either the tuner is no longer decoding the signal, in improper input has been selected (ie: input 1 is selected while actual signal is on composite 1), or something of that nature. If you are getting audio then the input is selected properly but the video decoder has failed.
If your cable signal is going through a VCR or DVD, disconnect it from there and go directly to the TV (ie: bypass the VCR/DVD). If your picture comes back, there's some kind of problem with your VCR/DVD player.
If you have multiple inputs, try connecting an input signal to another input (ie: video 1, or aux from a dvd player) and see if you get a picture there. If you do get a picture, the whatever input you're currently using has malfunctioned.
Mar 08, 2008 | Televison & Video
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
