Question about Refrigerators
Frost free block
Water leak
5 Suggested Answers
woodchuck789
  • 4070 Answers
SOURCE: Zanussi frost free fridge freezer leaking
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Jul 01, 2009
  • 572 Answers
SOURCE: leaking water in the freezer side from the vent at the bottom
ur drain is clogged. defrost unit and open panel from freezer and unclogg hole
Posted on Feb 09, 2010
BMT60
  • 126 Answers
SOURCE: Westinghouse Silhouette Frige 522 frost free is
UNPLUGGED FOR 24 HOURS AND LET IT TOTALLY DEFROST.
Posted on Apr 24, 2010
heatman101
  • 43501 Answers
SOURCE: Have Frigidaire upright frost free
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 12, 2010
Water leaking with icing formation below veg tray. can see flow of water from middle section of the refrigerator,water flowing out of the refrigirator.Model no-RT60KZRIH1
Frost free fridges will periodically allow frost build up to melt and run down the back of the fridge to a small hole which leads the water out and on to the compressor behind the fridge. The water is then evaporated by the heat of the compressor. The hole can get blocked and this leads to the water overflowing and running down to the bottom of the fridge. Clean out the drainage hole regularly.
Jan 30, 2015 | Refrigerators
I've just bought a Fiat Palio 1.2mpi EL 2002 model with a water leak at the bottom of the engine where it couples onto the gearbox, water gushes out, hoses and radiator seem ok. Any advice out there...
It may be a leaking frost plug. Some engine blocks have holes needed for the casting of the block or for machining. These are then plugged with cup shaped plugs called frost plugs . These can sometimes corrode and start leaking. Check to see if this is the case and replace plugs if needed. Hope this helps
Jan 12, 2014 | Cars & Trucks
Water leaks inside
It's due to wrong temp setting and malfunction of defrost cycling. Keep thermostat setting at 5 degree or little less. And don't keep it in minus,as defrost cycle will take longer time. And also you will get less cooling in fridge compartment and also water leaks.Check drain line hose may freezed. And also freezer tray get blocked due to over frosting around freezer. Defrost manually by unplug your fridge and after defrost all ices, plug again and keep correct temp setting. Thanks.
Feb 01, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Dirty water leaking
sound like the drain pipe that lets water go down to the compresor heater is blocked,,,it need to be cleared out yucky job
Jun 24, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have whirlpool refrigerator. it is a frost free double door model. Recently I have found water is dripping from the top of the fridge portion. It directle falls on the vegetable drawer and water is...
It is over charged with gas. but that will probably leak out again in a few months don't worry. The leaking water are most probably because the drain hole inside the refrigerator is blocked with algae growth.
Sep 30, 2017 | Whirlpool 24 7 cu ft Frost Free Upright...
Water leaking from bottom of unit
Because the fridge by it's nature is classed as "Frost Free" it has a device called a condenser, this catches water into a tray at the back of the unit. Look inside the fridge and somewhere you will find a small drain hole, depending on make & model, it could be in several places, but this is probably blocked. Also check the tray at the rear of the appliance, this could also have a blocked drain in it.
May 01, 2009 | Kenmore Refrigerators
Lickage of water from frost free fridge
actually a frost free fridge should leak water but it should not make it to your floor. every frost free fridge goes into defrost every 8 hours for 15 minutes where it will melt the ice off the coils. there is a pan underneath the fridge to catch this water. it should evaporate before the next defrost cycle there is not much water that comes out. you may want to pull the front cover and look under the fridge make sure the pan is in place and there is not a crack in it
Apr 27, 2009 | Refrigerators
I have an electrolux Aeg santo fridge freezer. Frost free. There seems to be water leaking from the bottom.
remove back plate inside freezer. there is a drain tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely. check drain tray heater is ok as well
Oct 08, 2008 | Electrolux Refrigerators
LARGE WATER LEAK ON FLOOR
the reason is probably that the drain hole in the freezer (i assume this is a frost-free type) is blocked. take off the rear panel of the freezer and you will probably see a block of ice at the bottom. melt off with a hairdryer and free the drain with hot water making sure that water flows freely away
May 06, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
21 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
