Question about Poulan Garden
Need to know carb settings for a 2008 poulan pro ppb4218 42cc
Need the settings for the H L & T adjustment screws on the carb
  • 9 Answers
SOURCE: poulan pro 260
Clearance from coil to flywheel should be around .010
Posted on Oct 26, 2008
  • 14 Answers
SOURCE: 2375 ''wild thing'' poulan saw hard starting after carb rebuild
Through trial and error on fairly new Poulin Pro, found that the usual 3-half turns for both high and low was too much (flooded) (Used to be good starting point on weed eaters years ago. So, turned both all the way in, and only backed out 1-full turn. (2-halves) Saw fired up perfectly, and ran wide open just fine. Try that.
Posted on Nov 19, 2008
  • 597 Answers
SOURCE: how to adjust Zama carb on poulan pro
You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Posted on Jun 28, 2009
SOURCE: Husqvarna Model 141 Chainsaw Carb adjustment
The tool you need is available from Randy's Engine Repair, on his E-Bay store. The price is about $10., plus $3. shipping. Phone for Randy's is (937) 927-5665. It is usually busy.
Ebay item number is: 390025452838. Buy it online. I got mine about a week after I ordered it.
Posted on Sep 11, 2009
  • 4088 Answers
SOURCE: My poulan wild thing 2375 bogs out when throttle
Make sure that the air cleaner and muffler are not plugged. Check the carburetor screws and nuts for tightness. After turning both needles CW to stops (lightly), back them out CCW 1-1/2 turns each. Start the engine and allow to warm up. Open the throttle and adjust the H needle CW somewhat until the engine speeds up, but is 4-stroking. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW till the engine runs fairly smoothly, but allows the engine to 'follow the throttle'. Set the idle speed screw so that the chain doesn't turn, but the engine keeps running. Hope this helps!
Posted on Apr 17, 2010
Chainsaw won't idle- runs fast only
Gently Tighten the carb adjustment screw fully tight then adjust it out 360 (full turn) then again a further 180 ( half a turn) and your idle speed should be set correctly. Let me know how you get on
Oct 02, 2014 | Oregon Poulan/Poulan Pro 10" Chain Saw...
Poulan p2500 carb adjustment
Carb not set correctly. Screw down idle an fast run screws an then reset. Sometimes fuel gets clogged an needs adjusting
Jul 04, 2014 | Poulan 25cc 2-Cycle Gas Powered String...
I bought a Poulan Pro 42cc chainsaw July 3rd. It will crank/fire but cuts out and cuts off even when I try to play with the gas. it is new and prob had thrown away stuff to where the store won't take...
This sounds more like basic carb settings, you will probably need the special tool to adjust thge jet screws if that do not have a slot in them Part no. 530035560, the carb is set up in the factory for the best emmissions, not the best running, you need to richen the mixture up on the L screw by unscrewing it a little bit at a time until it picks up clean, you may then have to increase the idle on the T screw.
Jul 08, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Pro 42CC 2 Cycle Chainsaw, 18": i can't figure out how to adjust hi low settings d...
They are called "tamper proof" or "tamper resistant adjusters. Amazon has a pretty good set for a reasonable price. Search on Tamper Proof Tool. It's nice the have a set around as you never know what you will run into.
For the Poulan, go to eBay and search on "Poulan Craftsman Walbro carb adjusting tool". You will find what you need there. I hope this helps.
May 16, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
Apr 15, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro 295 won't keep running.
pull the black dust cap on top there are three screws going down, the idle screw is on the left side (if you were holding the saw) near the top of the carb it has a spring around it. the 2 weird screws under that are the mixture screws hi and low rpm you really shouldn't mess with those unless your sure of what your doing. if that doesn't work there is a really small hole ( and I mean small) in the bottom of the carb for a diaphragm if that gets clogged it runs bad, also vibration can loosen the cylinder bolt turn the saw upside down and there are (or should be 4 bolts) make sure they are tight if one already rattled out take the one kitty corner to Lowe's or a hardware store and get a replacement.
Mar 04, 2010 | Poulan Pro Chain Saw 46cc 20"
Carb. settings for poulan 3400
set both of them at 1 1/2 turns out and then fine tune it from there if necessary. This setting is usually right on. Hope this helps you, Jeepfxr
Jan 27, 2010 | Poulan Pro Chain Saw 46cc 20"
Base adjust. on carb high and low needles on carb polen 42 18" thanks
The standard setting on needles is to screw them in all the way and then back them out 1 and a half turns.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. turn the low adjustment screw out. You will notice that the rpms should start increasing. keep turning it out until the rpms start to drop then turn it back in a quarter of a turn. You may need to readjust the idle speed so the chain doesn't turn during idle. Do the same for the high adjustment screw.
Oct 01, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
54 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
