Question about Philips 42PFL6704D 42 in. LCD TV
Phillips Model 42PFL6704D/F7 code12
Try to turn on but red led shows code 12
3 Suggested Answers
  • 35 Answers
SOURCE: wont turn on
Could be Bad caps on PSB causing the set to go into protection. If you are out of Warranty and want to try and DIY. You can email me. gysgt2u1@yahoo I'll give you some instruction and some pics of what to look for. If your'e set was scambling the top/bottom half it may be YSUS and the buffers Upper and lower that work in unison with it, or could be SSB. Can try the easy one first. It works about 90% of the time and cost a few bucks and some soldering. SSB replacing consist of just plug new one in. The board itself doesn't cost all that much. If you have to replace the YSUS and YB upper and lower its about 200.00
Try to help you while I search for solutioin to my probelm. I am becoming very familair with the insides of these sets and the bad boards that come with them. LOL
Semper Fi
Posted on Mar 02, 2009
gopakumarg43
  • 74887 Answers
SOURCE: i need a manual for Phillips TV Model 22pfl4507/F7
Click here to download the user manual.
Posted on Jul 16, 2012
I can not fine my manual and I need the codes for the tv so I can set up me cable remote. I have model 42pfl5907/f7
The manual for your Phillips TV is at: https://www.manualslib.com/products/Philips-42pfl5907-F7-1711566.html
Dec 02, 2017 | Televison & Video
My phillips flat panel model #42PFL6704D/F7 won't turn on with remote or power button. It turned off while watching tv
Probably the power board capacitors if you are confident remove the back and look for blown capacitors on power board they ate round cylinder shape with silver tops usually are they black colouration or bulging replace the with exact same parts and it should be fine. it would be the one the power cable is attached to if you are competent you can do for a few pounds /dollars good luck
Apr 03, 2015 | Televison & Video
I have a 42" LCD
Some of these TV were equipped with very short connections from the infared board to the small signal board. Remove some of the shrink tubing from the wires of the IR cable to relieve stress on the individual wires. Trim the other end of the cable as well. We are talking about one half to three quarters of an inch.If this does not help you will need to order a new IR cable. Please show this info to an authorized Philips dealer and have them do this for you. Thanks for asking and show a few hands of support.
Feb 19, 2011 | Philips 42PFL5332D 42 in. LCD Television
Need code for living solutions jumbo remote
The codes for a Phillips TV are: 003, 004, 006, 008, 062, 068, 069, 074, 075, 077, 086, 087, 089, 163, 183, 184, 205, 206, 207, 208, 212, & 213.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Nov 05, 2009 | Universal Remote Control Remote Control
Will a Phillips Universal operate a Samsung DVD-2000, and what ar
YES! if you have a universal remote look in its manual and program the code for your samsung into it. there are some buttons like SET and TV1 2 etc Select TV1 and SET buttons a red LED comes on, enter the code (eg: 013) the red LED goes out Press set aain and then press power on remote TV shoulod turn off if it doesn;t try anothyer code until you have control of the TV
Aug 11, 2009 | Samsung Televison & Video
I need the code for phillips tv i got the jumbo remote
The codes for your Jumbo Universal Remote to control a Philips television are 003, 004, 006, 008, 062, 068, 069, 074, 075, 077, 086, 087, 089, 163, 183, 184, 205, 206, 207, 208, 212, and 213.
  1. Turn on your TV.
I hope that helps.
Jul 30, 2009 | Innovage Jumbo Remote Control
Code 12
code 12 means all clear it flashes that then it pulls up a trouble code if thats all u got then nothings wrong
Mar 17, 2009 | 1987 Pontiac 6000
Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
Philips 42PFL6704D 42 in. LCD TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
