Question about Whirlpool Duet GHW9150P Front Load Washer
Bush wm1260tve how to cancel setting
On wash for 2 hrs and 52 mins way to long wanna cancell and do a quicker wash
4 Suggested Answers
SOURCE: Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Posted on Sep 24, 2009
SOURCE: my calypso is stuck on express wash 7 mins will
my calypso is stuck on express wash 7 mins will not respond to any button but cancel. called local repair man for 35.00 charged just to look and diagnose the problem and told me the control board is bad. and he had to order parts that cost 155.00. I order parts and that it didnt work. same problem.
Posted on Jan 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: Washing machine displays an LF error code.
LF = Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
Is water supply connected and turned on?
Are hose screens plugged?
Is water entering the tub? If so check pressure hose connection to machine/motor control.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 07, 2010
Testimonial: "We followed your suggestion and disconnected the hoses and they had "gunk" in them. We flushed them out, reconnected and everything seems to be fine."
How do I cancel my membership?
888-638-3549
Press 0 at each prompt.
Average Wait: 5 mins - 24 hours, 7 days
OR
Netflix Calls You Instead
Feb 06, 2015 | Netflix
Hotpoint DC28 not washing
1.press cancel button
2.check if the door closes securely.
3.since there is water in d/w try running a short cycle.If it works, clean the inside thoroughly to ensure no clogs.
Jan 12, 2014 | Hotpoint 18 in. DC28 Slim-Line Built-in...
The program was interrupted, now the washer is stuck on wash. How do you preform a reset please?
if you turn off at the main switch and leave off for 2 hrs this sometimes will reset on its own but if you hold the cancel button in for a few secs that will empty it and reset
Nov 07, 2011 | EuroTech EWF272EL-W
I wanna cancel zendough but cannot find anything i wanna cancel my membership now
To cancel your subscription please contact their Customer Service Team.
For contact information and hours of customer service click here.
Apr 12, 2011 | zendough.com
How to do manual setting for Panasonic Washer NA-F701GS
I keep program to normal, water level 51 and wash,rinse & spin but half way the washing machine go to reserve button (9 hrs).
how do i cancel the reserve button?
Nov 28, 2010 | Panasonic Washing Machines
How to unlock the oven?
Hello there:
If you unplug the oven for at least 1 to 2 hrs this will allow the self reset feature to take over and reset the lock mechanism then once you plug it in wait for 5 min and it should automatically unlock itself or if you have the cancel feature press this after 5 min ok
Please keep me posted on how this is going
Best regards Michael
Jul 02, 2010 | Kenmore 30169 Electric Single Oven
Clean button is flashing
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Whirlpool 24 in. GU2500 XTP Built-in...
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Reset wash cycle
Changing Cycles, Options and Modifiers
Not all Options and Modifiers are available with all cycles. Cycles,
Options and Modifiers can be changed anytime before HOLD TO
START is selected.
Options and Modifiers can be changed anytime after HOLD TO
START is selected and before the start of the selected Option or
Modifier.
To cancel a cycle and select a new cycle
1.
Select PAUSE/CANCEL twice.
2. Select desired cycle.
3. Select the desired OPTIONS.
4. Select HOLD TO START (for approximately 1 second) to
restart the washer at the beginning of the new cycle.
To cancel a cycle
1.
2. The washer powers down, the door unlocks, and clothes can
be removed.
NOTE: If the water level or the temperature is too high, the
washer will drain automatically before the door unlocks.
To change Options or Modifiers after the cycle has started
1.
Select PAUSE/CANCEL.
2. Select the desired OPTIONS or MODIFIERS.
3. Select HOLD TO START (for approximately 1 second) to
continue the cycle.
To drain the washer manually
1.
2. Select DRAIN/SPIN.
begin the drain.
4. When the spin is complete, the door unlocks. Items can be
removed from the washer.
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
