Question about Akai PT4799HD Rear Projection Television
My model kp-53v35 turn off as soon as it turn on. why?
Flashing hdtv
sold one for 425.00 seven years ago.....starting point anyway.......good success, meder's tv service
Nov 10, 2013 | Sony KP-53V35 53" Rear Projection...
Wony turn on
If its blinking check the site www.TvRepairKits.com for a Sony blinking light repair kit.
Apr 19, 2013 | Sony KP-53V35 53" Rear Projection...
My sony kp-53v35 keeps immediately shutting itself off
Older model---it should when you try to turn it on have the red light blink for several seconds (set is checking things inside) and if comes on and shuts off that light should blink a specific sequence of blinks----5 blinks and repeat it endlessly---
I have a stupid question: when it first failed did you hear a small pop or smell a faint odor of something burning?
Mar 22, 2012 | Sony KP-53V35 53" Rear Projection...
Need a remote control for a sony rear projection tv model KP-53V35
Sony KP-53V35 tv is an old model so a generic remote control is available here for $35
Substitute remote is available in remotes.com
Hope these info will help you.
Thanks.
Feb 02, 2011 | Televison & Video
I'm working on my 1996 model KP-53v35 Sony. The problem is that I plug it in and it tries to come on and the red LED flashes and it shuts off.
If the lamp light is blinking, then lamp needs to be replaced. If the standby light is blinking, the try resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then the service may be required.
Jul 26, 2010 | Sony KP-53V35 53" Rear Projection...
No image on sony rear projection tv (model KP-53V35) for 20 minut
sony has a circuit than balances the 3 crt's. it needs a screen adjustment which is located in the front of tv behind speaker grill. easy repair
Oct 22, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
ELETRIC SCHEME KP-53V35
Service manual pdf file of KP-53V35 is available in Manual Zone for small fee.
Mar 27, 2009 | Sony KP-53V35 53" Rear Projection...
Screen turns red
Looks like a waste of time to get my email address? You will be spam in that case.
Apr 14, 2008 | Sony KP-53V35 53" Rear Projection...
Television powers up then shuts off Kp-53v35
You likely have an open fuse caused by bad convergence ouptut ic's type #STK392-560 sony part #8-749-014-67. There are 2 in the set and i recommend replacing both at the same time.
Dec 17, 2007 | Sony KP-53V35 53" Rear Projection...
Akai PT4799HD Rear Projection Television Logo
16 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
