Question about Baby Gear
I can not get the gate to adjust to the smaller size at the bottom of the gate
2 Suggested Answers
myob247
  • 1342 Answers
SOURCE: Can't adjust size of display.
Right click on your computer's desktop and select Properties, Settings. Slide the slider bar to the right to make the desktop smaller.
Posted on Jun 21, 2008
WHY DID MY VIORE SCREEN RESIZE TO SMALLER SCREEN
Screen size depends on the broadcast signals aspect ratio, the TV adjusts for that automatically, the picture can have no bands or be banded top and bottom or on both sides.
Jan 07, 2017 | Viore Televison & Video
I have problem with christie projector roadster x9
If your's is the "s" model there is no keystone adjustment provided. Otherwise the keystone adjustment is found under MENU then 1, Size and Position and under MENU 2, Image Settings. Also, refer to this excerpt from the manual:
NOTE: This function is not available in "S" models.
Adjust the keystone control if images appears non-rectangular or keystoned in shape-that is, smaller at either the top or bottom edge. The effect of keystone adjustment is similar to
physically tilting the projector forward or backward in relation to the screen, and it affects all sources.
NOTES: 1) Keystone is enabled for a source only if Size is 1000 and Size x Vertical Stretch is 1,000,000.
2) Keystone adjustment is not available in "S"
models. 3) Avoid using Keystone with Blanking.
Nov 19, 2014 | Office Equipment & Supplies
1996 nissan pickup v belt size
The tensioner adjustment bolt for the alternator has a lot of adjustment. Are you sure you ran it to the limits with both belts?
For instance, Gates makes belts in 1/2 inch increment lengths from 2 inches shorter to 2 inches longer than the size listed for your application. I am sure your adjuster covers more than 1/2 inch difference.
Feb 26, 2018 | Nissan Pickup Cars & Trucks
How do you adjust the size [eg, make it larger] of a scanned print,for a final print,for a Umax Astra 1220U
Scanner will scan actual size only. If you need smaller or big sized print, select appropriate size and use 'fit' command before printing. With Raster Editing software, you can create another Image which is smaller or bigger.
S. Mohan
Sep 03, 2010 | Office Equipment & Supplies
Hello i have a lexmark t630 and when it prints out of tray 2 it says change tray two and beeps. It will work normal if you hit the select button. What could it be?
the printer is telling you that the tray is reporting the wrong size paper. print the network menu from tray 2 if it prints out smaller than the page it will be reporting smaller than letter. if the bottom line of the outline is missing its reporting legal size paper. if you are running lettersize paper in the tray check on the left side of the tray half way down the drawer you will see a plastic snap in plate with 3 fingers the bottom 2 should be sticking out for letter size paper. you only have to be one of the small adjust teeth off to make the third finger stick out and report the wrong size paper this is a very common issue. look at the metal fingers that stick out of the frame of the options tray to make sure they are uniform and straight. if the fingers are set right and not damaged then the logic board in the tray assembly will have to be replaced
May 14, 2010 | Lexmark T630 Laser Printer
Jet adjustment where are are jet adjust screws?
There is no way to adjust the jets on these carbs, fuel metering is done by a fixed sized main jet. If you need to adjust you must replace the jets with either a larger or smaller size jet.
Dec 30, 2009 | 1985 kawasaki ZL 900 A1 Eliminator
The view on my monitor is very truncated - about two inches top and bottom are not filled
Press the MENU button on the monitor and adjust the width and height of the picture to full screen.
Oct 10, 2009 | LG Computers & Internet
Ice Maker problem
remove the cover on the frount of the icemaker and on the right side of the module there is a little and i mean little white adjusting screw, turn it clockwise 1/2 half of a turn clockwise and this is what adjusts the fill time of the ice maker, you may need to adjest back and forth to get the desired size of cubes but do not go more that one complet turn of the screw to get the size
if you can not get it by doing this then the frount module will ned to be replaced
Apr 19, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Baby Gear Logo
88 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
