Question about Toto Home
Toto toilet seat
The lid came off the seat. can i put it back on?
  • 659 Answers
SOURCE: I have a Toto saftclose toilet seat but it doesnt close softly!!!
If it is something you can adjust, there will be an area on the hing. There also may be a small cover over the adjustment screw.
Posted on Apr 01, 2009
  • 659 Answers
SOURCE: Toto C100 Toilet Washlet Seat
There are two types of bowls as far as toilets are concerned...elongated and round front. The seats are interchangable as long as there isn't anything different in the way the seat is mounted to the toilet. As far as I know and my experiance with both brands, I can't see any reason why it would not work.
Posted on Apr 08, 2009
olddewsons
  • 38 Answers
SOURCE: flush problem with toto toilet
If your hooked to city water it can be cause of the high water pressure comes across and keeps flapper from seating rite. Take a empty plastic bottle,cut it in half long ways. flush toilet then place plastic bottle between fill valve and flapper,trying to devert water away from where flapper seats. good luck.
Posted on Jul 24, 2009
  • 54 Answers
SOURCE: loose Toto toilet seat
Lift up plastic caps located on ends of hindge behind seat. use flat screw driver and hold the nut under the outside toilet rim with your fingers or a pair of pliers. Do not over tighten or might crack the bowl.
Posted on Sep 14, 2009
SOURCE: hello - my toto toilet seat broke where the bolt
buy another
Posted on Nov 09, 2009
How to remove the lid seat from the toilet TOTO
The seat is held into place by two screws going into a rubber insert. Loosen the screws and work/wiggle the seat upwards to remove the rubber inserts.
Nov 15, 2017 | Toto Home
The toilet see is not tight. How can I tighten the seat? I have an elongated seat with the soft closing lid.
Right behind the bowl on the underside there is a nut on either side that holds the seat on...tighten those nuts and it will tighten down the seat...
heatman101
Aug 29, 2010 | Toto Aquia II Dual Flush Toilet
Cannot remove the lid
Hi and Wlecome to FixYa. I am Kelly
Unscrew the flush plunger assembly on the very top of the tank. It unscrews counter clockwise and then lifts out. Then you can lift off the tank lid.
When you go to put the top back you will have to align the flush pin gears in the slot.
If your talking about the seat.... then there are 2 nuts underneath the water closet at the back that must be removed.
Thanks for using FixYa.
Kelly
May 06, 2010 | Toto Aquia II Dual Flush Toilet
Toilet seat cover became loose on one side
I have a Toto Dorian 1.6 Gpf where the right side of the cover separated from the seat frame. I fixed it by removing the seat from the toilet base and driving the stainless steel shaft back into the cover hibge holes.
To remove the toilet seat, use a large phillips head screw drive and unscrew the two long screws that hole the seat to the base.
Then you will see the two steel rods about 1/4 inch in diameter that have worked there way out of the seat hinge. Use a hammer and a screw driver to drive these two hinge pins back out into the toilet seat cover hinge holes.
Replace the toilet seat and screw in the two seat screws being careful to not over tighten them. The seat should now work correctly.
Apr 02, 2010 | Toto Promenade, 1.6 GPF, Elongated...
The Toto elongated seat is shifting from left to right--
They are designed to have a little movement to prevent breakage if it is a lot then replace they is no way to adjust
Nov 01, 2009 | Toto Carlyle 1-piece Elongated Bowl Toilet
Loose Toto toilet seat
Sep 06, 2009 | Home
Hello - my toto toilet seat broke where the bolt holds the seat to the toilet
well you can go to home depot and get your self new seat with bolt or you can buy the screws for it
Aug 10, 2009 | Toto Lloyd 1pc. E/F Toilet w/Maple Seat ...
How does one replace the seat on a Toto Washlet model SW824?
two screw if you look in frent botim of tank that you flush normally plastic open and the seat will come off and you put back the new one the same way back
Aug 05, 2009 | Toto Washlet S400 for Power Gravity...
Flush problem with toto toilet
Jul 23, 2009 | Toto Dartmouth 2pc. E/F Toilet ...
Apr 05, 2009 | Toto Elongated Washlet C100 Toilet Seat -...
Home Logo
29 people viewed this question
Top Toto Home Experts
john h
Robert McCall
Robert McCall
Mike
Are you a Toto Home Expert? Answer questions, earn points and help others
