Question about VetTrust Antibacterial Antifungal Spray for Dogs & Cats, 4 fl oz
Can I use this product in my dogs ears for ear infection?
What are side effects for apoquel
http://petdermatologyclinic.com/apoquel-information/
Side Effects:
Other drugs in the same **** class as Apoquel include drugs for humans for rheumatoid arthritis, psoriasis, and cancer. In humans, the side effects of drugs in the JAK inhibitor class of drugs include: neutropenia, anemia, thrombocytopenia, increased liver values, increased cholesterol, UTI, weight gain, HPV zoster.
Apoquel side effects listed for dogs in the product insert include: vomiting, diarrhea, lethargy, anorexia, SQ or dermal masses (unspecified), decreased leukocytes, decreased globulins, and increased cholesterol and lipase. Low numbers of dogs in the studies developed demodicosis, neoplasia, pneumonia, ****** diarrhea, skin and ear infections, UTIs, and histiocytomas. Interestingly, a few dogs developed polydipsia, increased appetite, and aggression, similar to what may be seen with steroids.
Oct 31, 2016 | Health & Beauty
Can I give my dog an antibiotic that was prescribed to me to treat his ear infection
Some human medications can be used by dogs but not all of them, if you love your animal, you should consult a vet and ask if the medication will not make your dog sick or worst.
Nov 04, 2014 | Dogs
What can I do to help prevent my dog from getting an ear infection? I clean his ears regularly; however he still seems to be getting infections.
I found a great natural remedy that works in preventing ear infections in dogs. I use it for my dogs and they have been ok for almost a year now.
THE FOLLOWING ALL NATURAL REMEDY
PREVENTS EAR INFECTIONS! This recipe is not meant to be used with Zymox. This should only be used once the ears are completely healed.
Keep in mind that it "will not" cure an existing ear infection.
Once you get your dog's ears to a healthy state either by using Zymox like we recommended or with the help of an antibiotic from your veterinarian, start using the following remedy weekly to prevent future infections. This works by raising the Ph level in the dogs ears.
Purchase an eye dropper bottle and the following ingredients
from your local pharmacy.
2 Tablespoons of Boric Acid
4 ounces of Rubbing Alcohol
1 Tablespoon of Glycerine
Shake the bottle before each use to thoroughly mix. Place a small eyedropper full into each ear. Cup the dog's ear and massage gently. Allow the dog to shake his head and gently blot dry any excess on the outside of the ear.
Do this weekly.
If ANY IRRITATION occurs - STOP using the recipe immediately!
Aug 15, 2012 | Pets - Others
I need to buy a good cleaning product for my dogs ears. Can someone recommend a product that they trust?
We have 3 dogs and use the Epi-Otic ear cleanser made by Virbac. I found you a great site that compares pricing of this product for you.
http://about.pricegrabber.com/search.php?form_keyword=epi-otic&mode=about_dogs
Are pig ears a healthy treat?
Although they are quite delicious for dogs, pig ears contain a lot of fat. So if your dog suffers from obesity, do not give it pig ears.
Aug 13, 2012 | Dogs
Should I give my dog pigs ears?
I have read a lot of forums about this and it seems as though they are not that popular among dog owners. A lot of them say that the pigs' ears make their dogs sick with loose stools and others say that their vets have told them that pigs' ears are crawling with bacteria. So I wouldn't advise you to give them. Check out this forum: http://www.dogforums.com/dog-food-forum/951-pigs-ears-bad.html
May 13, 2012 | Dogs
Need to get the agitator off
that's funny [feed dogs]they are called, dog ears but you do now have to feed the dogs because their not working.lol.hey you will have to get those parts on-line or at an appliance store.lowes wont carry those that i know.anyway if you pop the cap of the agitator you will see a piece that has a small handle.pull up and remove that piece.then you will see the bolt to remove to pull the agaitator[its a 7/16]take a good look at how its together before you take apart.......ok now that the agitator is out place on floor,put feet on the bottom piece and pull up on the top piece til comes off.then dump out the piece in the top w/dog ears in it........install new ears in that piece and reinstall upside down,inthe top piece of the agitator.then apply pressure on the dog ear retainer and place over the bottom piece of the agitate aligning the two little tabs sticking up on the bottom piece of the agitator with the little cut outs in the dog ear retainer....now take your socket to place bolt back on,put some plastic wrapper or package from dogs in the socket and push the bolt into it.then place the bolt in the hole of the dog ear retainer .now lift agitator up and place onto transmission shaft and tighten bolt and place cover back on................boy that was a lot of words.that should do it for you God bless you Tiffany ,from tom
Jan 24, 2009 | GE WBSR3140DW Top Load Washer
I want cheat codes of sims 2 pets
  • Cheat Gnome While at home or on a lot, press L1(2), R1, X(2), Up. Then, enter one of the following codes to activate the corresponding cheat function:
      10,000 additional Simoleons Enable the "Cheat Gnome" code, then press Up, Left, Down, Right, R1 while playing the game. An option to advance time by six hours will now appear on the Cheat Gnome. Select the Cheat Gnome, then cancel the selection. Press Up, Left, Down, Right, R1 again. A "Give Sim Simoleons" option should now appear.
      Pet Points Enable the "Cheat Gnome" code, then press Triangle, Circle, X, Square, L1, R1 while playing the game. A "Pet Points" option will now appear on the Cheat Gnome.
      Pet Emporium fully upgraded Enable the "Cheat Gnome" code, then press Right, Down, Right, Up, Right, Down, Right, Up while playing the game.
      Advance time by 6 hours Enable the "Cheat Gnome" code, then press Up, Left, Down, Right, R1 while playing the game. An option to advance time by six hours will now appear on the Cheat Gnome.
  • Alternate opening sequence At the EA logo, press X, Circle, Triangle.
  • View developers At the credits screen, press Right, Left, Up, Right, Down, Right, Down, Right.
  • Bonuses At the codes screen under the "Game Options" menu, enter one of the following codes to activate the corresponding cheat function:
    Result Code
    Collars
    Black Dot Cats ZZZ11ZZZ9Q11Q91ZB1A or EEGJ2YRZQQ1IQ9QHA64 Black Dot Dogs ZZZ11ZZQHZ11Q91ZB1A or EEGJ2YRQZZ1IQ9QHA64 Black Smiley Cats ZZZ11ZZQ9Z1AQ91ZB1A or EEGJ2YRQQZ1RQ9QHA64 Black Smiley Dogs ZZZ11ZZZ9QAAQ91ZB1A or EEGJ2YRZQQARQ9QHA64 Blue Bones Cats ZZZ11ZZQHZAAQ91ZB1A or EEGJ2YRQZZARQ9QHA64 Blue Bones Dogs ZZZ11ZZZHZ11Z91ZB1A or EEGJ2YRZZZ1IZ9QHA64 Blue Camouflage Cats ZZZ11ZZZHQ11Q91ZB1A or EEGJ2YRZZQ1IQ9QHA64 Blue Camouflage Dogs ZZZ11ZZZHZ1AQ91ZB1A or EEGJ2YRZZZ1RQ9QHA64 Blue Star Cats ZZZ11ZZQ9Z11Z91ZB1A or EEGJ2YRQQZ1IZ9QHA64 Blue Star Dogs ZZZ11ZZQHQ11Q91ZB1A or EEGJ2YRQZQ1IQ9QHA64 Green Flower Cats ZZZ11ZZZ9ZA1Q91ZB1A or EEGJ2YRZQZAIQ9QHA64 Green Flower Dogs ZZZ11ZZQHZ1AQ91ZB1A or EEGJ2YRQZZ1RQ9QHA64 Navy Hearts Cats ZZZ11ZZZ9Z11Q91ZB1A or EEGJ2YRZQZ1IQ9QHA64 Navy Hearts Dogs ZZZ11ZZQ9Z11Q91ZB1A or EEGJ2YRQQZ1IQ9QHA64 Orange Diagonal Cats ZZZ11ZZQ9ZA1Q91ZB1A or EEGJ2YRQQZAIQ9QHA64 Orange Diagonal Dogs ZZZ11ZZZ9Z11Z91ZB1A or EEGJ2YRZQZ1IZ9QHA64 Pink Vertical Strip Cats ZZZ11ZZQ9QAAQ91ZB1A or EEGJ2YRQQQARQ9QHA6 Pink Vertical Strip Dogs ZZZ11ZZZHZA1Q91ZB1A or EEGJ2YRZZZAIQ9QHA64 White Paws Cats ZZZ11ZZQ9Q1AQ91ZB1A or EEGJ2YRQQQ1RQ9QHA64 White Paws Dogs ZZZ11ZZZ9Q11Z91ZB1A or EEGJ2YRZQQ1IZ9QHA64 White Zebra Stripe Cats ZZZ11ZZZHQ11Z91ZB1A or EEGJ2YRZZQ1IZ9QHA6 White Zebra Stripe Dogs ZZZ11ZZZHZ11Q91ZB1A or EEGJ2YRZZZ1IQ9QHA64
    Fur colors
    Blue Cats ZZZ11ZZQHZA1Q91ZB1A or EEGJ2YRQZZAIQ9QHA64 Blue Dogs ZZZ11ZZQ9Q11Z91ZB1A or EEGJ2YRQQQ1IZ9QHA64 Deep Red Cats ZZZ11ZZQ9QA1Q91ZB1A or EEGJ2YRQQQAIQ9QHA64 ° Deep Red Dogs ZZZ11ZZQHQ1AQ91ZB1A or EEGJ2YRQZQ1RQ9QHA64 Goofy Cats ZZZ11ZZQHQ11Z91ZB1A or EEGJ2YRQZQ1IZ9QHA64 Goofy Dogs ZZZ11ZZZHZAAQ91ZB1A or EEGJ2YRZZZARQ9QHA64 Green Cats ZZZ11ZZZ9QA1Z91ZB1A or EEGJ2YRZQQAIZ9QHA64 Green Dogs ZZZ11ZZQHQA1Q91ZB1A or EEGJ2YRQZQAIQ9QHA64 Light Green Cats ZZZ11ZZZHQ1AQ91ZB1A or EEGJ2YRZZQ1RQ9QHA64 Light Green Dogs ZZZ11ZZZ9Q1AQ91ZB1A or EEGJ2YRZQQ1RQ9QHA64 Neon Green Cats ZZZ11ZZZHQA1Q91ZB1A or EEGJ2YRZZQAIQ9QHA64 Neon Green Dogs ZZZ11ZZZ9QA1Q91ZB1A or EEGJ2YRZQQAIQ9QHA64 Neon Yellow Cats ZZZ11ZZZHQAAQ91ZB1A or EEGJ2YRZZQARQ9QHA64 Neon Yellow Dogs ZZZ11ZZQ9QA1Z91ZB1A or EEGJ2YRQQQAIZ9QHA64 Pink Cats ZZZ11ZZQHZ11Z91ZB1A or EEGJ2YRQZZ1IZ9QHA64 Pink Dogs ZZZ11ZZZ9Z1AQ91ZB1A or EEGJ2YRZQZ1RQ9QHA64 Purple Cats ZZZ11ZZQ9ZAAQ91ZB1A or EEGJ2YRQQZARQ9QHA64 Purple Dogs ZZZ11ZZQ9ZA1Z91ZB1A or EEGJ2YRQQZAIZ9QHA64
    Fur patterns
    Bandit Mask Cats ZZZ11ZZQHZA1Z91ZB1A, TB6IPB1IAFDMRIQT6DG, or EEGJ2YRQZZAIZ9QHA64 Bandit Mask Dogs ZZZ11ZZQHQAAQ91ZB1A or EEGJ2YRQZQARQ9QHA64 Panda Cats ZZZ11ZZQHQA1Z91ZB1A or EEGJ2YRQZQAIZ9QHA6 Star Cats ZZZ11ZZZ9ZAAQ91ZB1A or EEGJ2YRZQZARQ9QHA6 Star Dogs ZZZ11ZZZ9ZA1Z91ZB1A or EEGJ2YRZQZAIZ9QHA64 Zebra Stripes Dogs ZZZ11ZZZHQA1Z91ZB1A or EEGJ2YRZZQAIZ9QHA64
  • Dec 21, 2008 | Sony PlayStation 2 (PS2) Console
    VetTrust Antibacterial Antifungal Spray for Dogs & Cats, 4 fl oz Logo
    529 people viewed this question
    Top VetTrust Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a VetTrust Health and Beauty Expert? Answer questions, earn points and help others
