Question about Icm 175 Bypass Timer
Bypass tmax timer on tanning bed - Icm 175 Bypass Timer
I got a tanning bed off someone it worked good moved it to my house i wont come on
These days tanning beds are considered potentially as dangerous as sunbathing. Much has been written about them and it would be wise to do some research before you start using it.
Modern tanning beds might include some electronics but originally they were simply a collection of fluorescent lamps, a timer and a selector switch and probably at least one safety device such as a fuse or a thermal breaker.
The circuit should be fairly straightforward and easy to follow and check which will be the only way to discover the fault using a multimeter to verify the supply and discover where the current flow stops.
May 29, 2017 | Health & Beauty
I have a mark i tanning bed with a token timer need wiring diagram please for tanning bed
tanning beds are no longer acceptable because they are a proven source of melanoma cancers with a high death rate of users
They concentrate UV rays that are the main cause of the cancer
Now that you still want to promote your own demise from cancer, have a electrician check the wiring out as you are not qualified to do that and simply put the power wire in to the time on to the power put wire to the timer and feel free to burn your self to death
In this country tanning beds are declared illegal and they cannot be sold , modified or imported because of the extreme problem with cancers . All tanning salons have thrown them in the junk heap
Feb 25, 2016 | Health & Beauty
We just opened up a tanning salon. The beds are on individual timers and we were trying to hook up the timers to a main computer in order to be more efficicient. The timer locked up when we entered the...
is there a key lock? if so, locate the key lock at the front left of the timer and then insert the key, turn it clockwise and hold it for 5 seconds. other timers have a card to scan to unlock.
Mar 03, 2013 | Health & Beauty
Are tanning beds safer than tanning in the sun?
Although tanning beds are more controlled than tanning outside in the sun, ultimately all exposure to UV rays is potentially dangerous to the skin and can put you at risk of skin cancer and premature aging. For a safer way of tanning - look for sunless tanning products rather than using tanning beds or laying on the beach for hours.
Feb 18, 2013 | Health & Beauty
What is a tanning bed?
A tanning bed is a type of bed (with a top and bottom part to it) that tans the user through ultraviolet radiation. There are tanning beds in salons but also home tanning beds which tend to have less lamps and use less watts.
Jan 10, 2013 | Health & Beauty
I have a sunvision 24 tanning bed and it isn't coming on what do i do
Have a trained technician to: Check main breaker, check that bed is getting power to it, check for bad fuse on back of bed, check for burned out wiring inside of bed at main relay, check that the timer is good.
Aug 28, 2012 | Wolff Sunvision Pro 24S Tanning Bed
Tanning bed
what???????
May 28, 2008 | Cameras
Tanning bed setup
HI a bought a tanning bed last night from a tanning salon it was hooked threw a phone line or something like that my hubby brought it home and hooked it up here .now i cant get it to work ,will i ever see it work and how can i get it to work for me.
Apr 01, 2008 | Cameras
Icm 175 Bypass Timer Logo
165 people viewed this question
Top Icm Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Icm Hardware and Accessory Expert? Answer questions, earn points and help others
