Question about Pets - Others
Model mo16902
What amperage does the charger use
Wall charger replacemnt
Go to amazon.com and search "Trio Stealth G2 charger"
or, if you can't wait
check the OUTPUT voltage and amperage on the old charger (for example, it could say: "5.0 VDC --- 1000 mA" (that means 5 volts, 1000 milliAmp), and find a standard charger with same voltage, and same or higher amperage.
Dec 21, 2015 | Trio Stealth G2 7 inch Tablet with 8GB...
Recharge Coby 707 mp3 player. Can I use recharger wall adapter input 90v-240v output dc 4v-8v? Is there a limit how log it can be recharged?
If you use a recharger other than the original, make sure that the voltage and polarity of unit is the same to one being replaced. Try to use one with a similar amperage as the original. Look for amperage rating of your batteries and then divide that by the amperage out on your charger to determine a safe charge time since you do not know if the replacement charger has an auto shut off - u do not want to overcharge the batteries and damage them.
Aug 31, 2015 | Coby Televison & Video
I need a charger for my Samsung jgh-s125g(gp)
Please read the specs on the original charger and get any charger with similar specs. Actually any charger with same connector will do but if the amperage is different then the charging time will be different too. All phones are the same voltage, only the amperage differs.
Oct 28, 2013 | Samsung Tracfone Sgh T105g Cell Phone...
Targus charger wont charge laptop when laptop on?
The laptop does not recognize the charger due to a different wattage/ amperage or is not powerful enough to charge the laptop while the machine is powered. I have seen many problems with hps/compaqs and the Targus Universal Charger and recommend the HP universal charger for those models instead.
May 23, 2011 | HP Compaq nw9440 Notebook
HOW DO I RECHARGE SPECIFICE CHARGER OR BY COMPUTER
By computer so that you will obtain the specific charger that you need.
plankw,
What laptop is it? Manufacturer name, and Model Number.
(Bottom of laptop)
Also,.....on the Bottom of the laptop is stated the Input, and Output voltage.
Your concern is the input Voltage, not so much about the Amperage.
(V = Voltage, A = Amperage)
Example;
Input: 12V2A (Sometimes printed as 12V~2A)
12 Volts at 2 Amperes.
The AC adapter (Charger) must also have the correct plug to fit the laptop's DC Power Jack.
(DC IN)
Regards,
joecoolvette
Apr 21, 2011 | Computers & Internet
I need to purchase a new charger for my Gateway CX2724 laptop. Will any charger for a Gateway laptop do, or do I need to look for one for my model specifically?
there are different voltage outputs and amperage ratings on different chargers. as long as the plug fits, and the numbers are the same, you'll be fine. I would try to get a charger meant for your unit though.
Mar 27, 2011 | Gateway CX2724 Laptop Charger...
I have a Kingavon 1 million cp spotlight (model SL1000EB ) I also have a lot of unidentified chargers. Does anyone know what charger fits the spotlight?
I will assume that your light has rechargable NiCad batteries. Use the following advice ONLY if you are sure this is true. If the light is more than a couple of years old, this is probably true. Of the plug has to fit, but it must also have the correct Polarity, Voltage, and Amperage. The spotlight should be labeled where you plug the charger into it with these three critical parameters. They will also be indicated on the chargers. POLARITY --- If it takes a round plug, the polarity is indicated by a symbol that looks like a C, usually with a plus sign inside of it (this indicates that the center contact is positive). VOLTAGE --- this will be expressed as VDC input on the light, and VDC output on the charger. The voltages only need to match within about 10%. AMPERAGE ---- this will be expressed as mA (milliamps, which is thousandths of amps) or as A (which is Amps). 1000 mA = 1 A. This doesn't need to match precisely either. But if it's too low, the charge will take a while and you might burn up the charger (possibly literally burning it). If the amperage on the charger is high, that's OK, so long as the voltage is not high as well.
I hope this helps, Thanks for using FixYa. Al Kupchella
Apr 29, 2010 | Safe International Digital Electronic Safe...
I lost the charger for the 18v PSO1800 Type cordless drill
Replacement parts in USA from
http://www.ereplacementparts.com/charger-p-100122.html?osCsid=cv3pj4ntur724eevbt3vhfeor4
does not appear to be a UK model.
Nov 17, 2009 | Drills
Replacement phone charger arrived, i plug it in and it says invalid charger. original charger broken.
Do the output values on both chargers match? Voltage and Amperage? Are both chargers of the same model #?
Jun 16, 2008 | Lands Phones
Pets - Others Logo
Top Pets - Others Experts
Ross Keen
Tom Chichester
Ruth summersides
Are you a Pets - Other Expert? Answer questions, earn points and help others
