Question about Kitchen Ranges
How to replace gas burners on a plastimo neptune 2000 stove?
  • 15 Answers
SOURCE: looking stove sealed burner replacement
try this phone number from mexico 52 27 10 00. Or try this website out for more information. www.serviplus.com.mx
Posted on Jul 18, 2007
gwshaw71
  • 83 Answers
SOURCE: gas stove top burners
Make sure nothing is blocking burner tubes and burner tops. All holes need to be free and clear. If that dont work replace your inlet valve were your gas lin goes in.
Posted on Dec 08, 2007
dmathwizard
  • 113 Answers
SOURCE: replacement burners
I could not find your model on new world appliances but here is the website: http://www.newworldappliances.com
call them and ask them where you can get the burners.
Posted on Mar 03, 2008
jumptrout51
  • 3361 Answers
SOURCE: Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Posted on Apr 23, 2009
  • 3600 Answers
SOURCE: Installed stove, no flames on burners?
It may still have air in the system, turn on one burner on and allow the gas to flow with a lighter in the path of the gas see if the gas lights of at least explodes I mean until it goes Poof, once it does that if it does not light then pull the top off the stove and adjust the vents on the pipes to focus the flames and how much air is blended in with the gas, also turn the burner so that the holes are half way open, I am not sue about your stove but most have an adjustment by turning the burner 1/4 of a turn to change the flame characteristics. if this does not help post here and I will see what else I can find out on your stove. I need the modle of the stove and the regulator number where the gas hooks up.
Posted on Jul 23, 2009
Neptune Gas dryer burner will not continue to fire
There's a good chance you need to replace the igniter. Careful, they are brittle !!!
Sep 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Jul 23, 2009 | Kitchen Ranges
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Gas stove top burners
Nov 26, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
There is nothing fancy about how the gas controls work on this unit. Do all burners give you the same problem? If so, it could be a kinked service hose or a service valve that has been partly shut. If it is limited to a single burner or two, the valve may be gummed up and should be replaced.
Nov 13, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Kitchen Ranges Logo
125 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
