Question about Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902
C 1029 di 450 - Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902
My konica monilta di 450 is giving error code c-13fa please help and give me its solvation?
The problem is the print head that is were the LASER is located open close the front door to reset if it comes back replace the print head
Feb 01, 2014 | Minolta DI-2010F Copier
Di 450 earer coad c13f8
Print Head error. The print head is what houses the LASER for printing/copying. Open Close front door to reset. IF not replace the Print head. Worse case the image control board is bad. Also check all connections between the print head and the image control board.
Sep 14, 2013 | Minolta DI-2010F Copier
PRINT HEAD failure that is the unit the LASER is in. try open close front door, check connection between print head and image control board if not need a new print head.
Dec 28, 2011 | Minolta DI-2010F Copier
The National Bank of Scotland pays 5% compound interest per annum. How much interest would be received after three years on a deposit of £980 in the bank?
First year: 5% from 980£ is 49. So after the first year you have 980+49=1029
Second year: 5% from 1029£ is 51,45. So after the second year you will have 1029+51,45=1080,45
Third year: 5% from 1080,45 is 54,02. So after the second year you will have 1080,45+54,02=1134,47.
In three years you have 154,47=54,02+51,45+49
If you need further assistance, just leave a comment. Cheers
May 16, 2010 | Mathsoft StudyWorks! Mathematics Deluxe...
Does it work verizon wireless un175 usb on dir-450?>
yes...you must change the D Link IP address and disable the DHCP server...use the IP add within the range of verizon dhcp server..192.168.1.1 is your verizons IP..to chANGE your di link IP connect to Dlink wired and not connected to any routers...type 192.168.1.1 to access configuration menu and you can change the setting
Apr 06, 2009 | D-Link DIR-450 Router (DIR450)
DI 450 KONICA MINOLTA ERROR CODE C0070 AND C0F24
if it;s not the bottle home position it may be you toner happer motor...clean it and try to take the bottle our and close the door and than put bottle back in
hope that help
Feb 25, 2009 | Konica Minolta DiALTA Di200 Copier
Konica Minolta Minolta Di450 Di470 Di550 Copier Mt Toner 502a 8936-902 Logo
49 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
