Question about Home
Slow hot water from HWTF1 hot tap - Home
4 Suggested Answers
  • 713 Answers
SOURCE: Cold Water extremely slow to fill. Had same
sounds like both valves r faulty .try cleaning inlet hose filters and if that doest work must b valves. buy and change cold first to save u money,if u dont use warm often.please reply 4 more help.p/s turn off power b4 working on unit dont want any acciedents.
Posted on Apr 09, 2010
  • 111 Answers
SOURCE: when drawing hot water,it keeps going hot and
must be a self tempering valve gone bad or fill tube in water heater broken.water goes into water heater then goes about 3/4 s of the way down threw a plastic pipe,if that pipe was hanging loose,it could go hot then luke warm.is this only happening on one faucet?if so,forget heater,and change cartridge in faucet.go to local home center and get one, it will have instructions on how to take appart
Posted on Jan 12, 2011
  • 349 Answers
SOURCE: only warm, not hot water from our tap unless I
Warm water indicates a element is probally in need of replacement. For warm water only more than likely the top element is bad. If you get a burst of hot water for a little while then your bottom one is probally gone bad. Best to replace both elements when changing one out due to not being to exspensive and you have to drain it down anyway.
To change out shut water of and turn power of to water heater open hot side on a faucet to allow heater to drain down so you can change out element.
Posted on Jul 28, 2011
Can I clean the valve to remove sediment?
when this problem presents I consider that the problem is in the weak tap stopper /seat
they can break down ,become enlarged and not move of the tap seat to allow full flow
that is the first check I would be doing
Mar 02, 2015 | Grundfos Pumps Grundfos Comfort System...
Cold water filling is very slow despite good water pressure and taps fully turned on
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Sep 03, 2011 | Hoover Washing Machines
Water inlet flow is too slow,it seems lock is not working What to do?
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
Have the lock checked at the same time.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jul 31, 2011 | Samsung Washing Machines
Only warm, not hot water from our tap unless I slow the tap down.
Jul 27, 2011 | Water Heaters
Water fills really slow. When you push button to change water temperature the water comes out better for a tick better then back to slow. Is there anything to fix this?
Hi just read your posting.1st turn the taps off and remove the cold water hose from the tap and machine ends.Check the little filters at the ends of the hose for blockages.Also check the machine end where the hose attaches for a blocked filter in the water valve.Now once the filters are clean put the hose on the tap end and the other end of the hose into a bucket.Now turn the tap on and check to see if you have good water pressure.If you do then replace the hose to the machine.Now repeat on the hot hose.If you are still getting low water pressure into the machine and your water pressure is good from the taps then your water valve or valves are faulty.Please reply on how you got on.Looking forward to your reply.
Sep 26, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Slow water flow
first check that there are no kinks in the hoses if they are alright it is either a blocked restrictor in the tap or a fault with a tempering valve this valve will be located away from the tap and is what mixes hot and cold water together so that the hot water isn't too hot, in the inlets to the valve are strainers that get blocked clean them out and see how you go
Jul 14, 2010 | Grohe Classic Kitchen/Bar Faucet ...
Cold Water extremely slow to fill. Had same problem with hot water some time ago and I have turned hot water off at tap and always choose cold water. Now I have turned hot water tap back on and use warm...
Apr 08, 2010 | Fisher and Paykel (IWL12)
When I turn on the cold water tap in the Bathroom Sink the water comes out in a very slow drip or not at all, the CW bath tap is ok
Confirm that the shut-off valve under the sink is open all the way. If it is, then close it and remove the cold water tap. If this is a single handle tap you will of course have to turn off the hot water shut off under the sink too.
With the tap removed and a bucket and towel handy, open the cold water shutoff just a little bit. If water comes rushing out, the problem is obviously with the tap. You may be able to clean or repair it, or you may have to replace it.
Mar 19, 2010 | Home
My GWL10 fills really slowly. It starts fine with the hot water, then slows to a trickle when it switches to cold but it doesn't seem to affect it if I change the temperature selection. I normally leave it...
sounds like you have a restriction on the cold water water pipe kinked or a blockage turn off cold water and remove pipe from cold tap then turn tap on and see if water is coming through fast enough if it is then the restriction is in the hose or valve on washing machine if not then the restriction is in the cold water tap
Jul 14, 2009 | Fisher and Paykel GWL11 Top Load Washer
Slow running tap
If you have recently turned off your water supply you may have disturbed some sediment in the water lines causing this problem.....Unscrew the airator at the end of the faucet and there is a screen inside( take note how this screen is in place). This should give you water pressure back!
Dec 18, 2008 | Plumbing
Home Logo
60 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
