Question about Directed Electronics OHD800B 8.5 in. Car Monitor
I need a replacement fuse for a Directed Video RVM700 Monitor.
No power at the unit all of a sudden
the fuses for the roof monitors are normally in the wiring behind the monitor although if you have had it a long time and use it regularly the ribbon may have broken in the hinge.
Jan 01, 2011 | Directed OHD1021 Car Video Player
Where can I change the fuse on my car dvd player?
Mine is wired directly to my main fuse box, and you should be able to clearly see the extra wires going into your fusebox depending on who wired it and how. There are supposedly monitor fuse in addition, but I am searching for them myself. What makes you think it is the fuse?
Dec 27, 2010 | Directed OHD1021 Car Video Player
I can not get the sound to go through the radio
Turn on FM modulator in OH monitor from the menu screen. Set station on screen, tune stereo to station.
Sep 24, 2010 | Directed DEI AutoMate OHD1021 Overhead LCD...
Directed Video OHD800B will not power on...Please help?
Check the yellow wire, it has a 3 amp inline fuse. I have found that the inline fuse holder itself was defected and I replaced the whole fuse holder. You can find one at Radio Shack, Part # 270-1238.
Aug 02, 2010 | Directed Electronics OHD800B 8.5 in. Car...
Just stop working. No Lights
check fuses, there could be a fuse at the unit
Apr 22, 2010 | Directed Electronics OHD1020B Car Video...
My directed d1200 amp blew a fuse i replaced it and the power light is green. However im not getting any sound out of the sub and the esp indicator light is on. what does it all mean.
Hello, first the ESP is for communicating with Directed security systems. If your fuse blew then your amp may have a security feature that disables the amp. The new Directed amps have these features. You need to read your manual or see if you can download one. You should be able to take care of it that way. If you do get it unlocked cause of a security feature and it still does not work, then you are having some internal component problems. I do amp repairs for a living. I own a car audio installation and amp repair shop. I'm the cheapest amp repair you will find anywhere. So if it turns out to be more than you can handle I can repair it for you if interested.
Aug 13, 2009 | Directed D1200 Car Audio Amplifier
Black Screen
The first thing I would do after turning the computer on is check to see if the video output is being directed to the LCD screen. The output can be directed using the Fn key along with the key with the picture of the 2 monitors on the Function keys at the top of the keyboard. Hold down the Fn key and tap the other key once or twice,
Next, hook the computer up to an external monitor. Do the same thing with the Fn key to see if it's the LCD screen.
If the external monitor works, then you haven't correctly hooked up the LCD screen or it's bad.
Feb 05, 2009 | Averatec 3200 Notebook
Compaq 1501 15" LCD Monitor ( Blinking Display)
Hi BOY! :P
Check if there is anything wrong with the video input cable to the monitor. If not then you should move ahead with the replacement of the ceramic fuses. There should be around 6 of them in most monitors i have fixed. They will look like this(click here) They should cost you around 1$ each.
If none of these work then your monitor's inverter board is probably screwed and needs to be replaced. should cost you around 30-60$.
Aug 30, 2008 | HP Compaq 1501 15" LCD Monitor
Directed Electronics OHD800B 8.5 in. Car Monitor Logo
47 people viewed this question
Top Directed Electronics Car Audio & Video Experts
xxxxxx xxx
Are you a Directed Electronics Car Audio and Video Expert? Answer questions, earn points and help others
