Question about Clarion Cz102 In Dash Car Cd Player W Radio Receiver Head Unit Aux Input
Setting the time for Clarion cz102 radio
Cannot correct the time on the radio
2 Suggested Answers
SOURCE: Need to know how to set the correct time on the
I have to search for this every time too. This product has an incredibly non-intuitive button inetrface. From the instruction manual (which can be found at http://www.devicemanuals.com/guide/Car%20Audio/Clarion/Clarion-DB245-CD-Installation-Manual-TkRZeU5qVT.html):
Posted on Apr 12, 2010
Testimonial: "After playing with the radio for a number of days, this solution finally helped me set the clock. Thanks for the assistance."
Tip
Procedure For Setting Time Zones For Emerson Clock Radios
Setting The Time, The First Time
IMPORTANT: The first time you connect your new SmartSet® clock radio to
the AC outlet the internal computer will automatically set the time correctly for
the Eastern Time Zone, which is the initial default setting. The display will
scan for a few seconds and then show the correct Day and Time in the Eastern
zone. If you live in the Eastern Time zone, there’s nothing else to do. Your
clock is set correctly and running.
If you do not live in the Eastern Time zone you must change the default zone
display to your own zone. You only do this one time and the SmartSet® will remember
the new default zone setting and will always return to that setting after a power
interruption.
There are 7 time zones programmed into your SmartSet® clock radio as follows:
ZONE 1 — Atlantic Time
ZONE 2 — Eastern Time (Default Setting)
ZONE 3 — Central Time
ZONE 4 — Mountain Time
ZONE 5 — Pacific Time
ZONE 6 — Yukon Time
ZONE 7 — Hawaiian Time
To change the default time zone display, depress the Time Zone button.
The number “02” will appear on the display
indicating that the default zone is ZONE 2,
Eastern Time
on Jun 12, 2009 | Emerson Smartset Clock Radio
Tip
Manually Setting the Time
Slide the switch with a lock, wake 1, wake 2 and clock to the clock position. Using the backwards and forwards buttons get time to the correct time. When correct time is reached, slide the switch to the lock position. Time will now be set.
on Jul 14, 2008 | RCA RP5430 Clock Radio
How do I set the time on Timex T231 clock radio?
Setting The Time of T231
NOTE: The time can only be adjusted when the clock radio is in the OFF mode. If the radio is playing, press and hold the MODE/ALM RESET button until the display briefly shows 'OFF' and then reverts to the time.
1. If the display is flashing, press the HOUR / REV button to advance the display to the correct hour. If the display is not flashing press and hold the CLOCK button until the display begins to flash, then press the HOUR / REV button to advance the display to the correct hour. Observe the PM indicator to confirm that you have set the hour correctly. If the PM indicator is 'On' the hour on the display is PM. If the PM indicator does not appear the hour on the display is AM.
2. Press the MIN / FF button to advance the display to the correct minute.
3. When the correct time is flashing on the display press the CLOCK / PRESET button once more. The display stops flashing and the clock begins to run.
Oct 01, 2014 | Timex Audio Players & Recorders
Timex number t235 clock radio, how do I set the time
easiest way to set clock time. Remove AA battery's if installed.
Unplug Clock from AC. Wait a few seconds. Then replug clock into AC power. Clock will now flash 12:00. Press hours button until correct time is set PM has led on AM has Led off. Set minutes to correct minutes. Then press alarm reset / power/mode button. Wait a few seconds and display will show correct time. Now you can put the AA batteries back in.
Apr 30, 2014 | Timex T065s Solar Powered- Radio...
How can one enter security code of clarion car stereo
you use the numbers on the radio preset buttons to enter the code.
Aug 18, 2013 | Clarion Cz102 In-dash Cd/mp3 Car Stereo...
How do you set the clock on a 2004 gmc ykon
According with the Owners Manual:
* Setting the Time for Radios without Radio Data Systems (RDS)
Press and hold the HR or MIN arrow for two seconds. Then press HR until the correct hour appears on the display. Press and hold MIN until the correct minute appears on the display. The time may be set with the ignition on or off.
* Setting the Time for Radios with Radio Data Systems (RDS)
Your radio may have a button marked with an H or HR to represent hours and an M or MN to represent minutes.
Press and hold the hour button until the correct hour appears on the display. Press and hold the minute button until the correct minute appears on the display. The time may be set with the ignition on or off.
To synchronize the time with an FM station broadcasting Radio Data System (RDS) information, press and hold the hour and minute buttons at the same time until RDS TIME appears on the display. To accept this time, press and hold the hour and minute buttons, at the same time, for another 2 seconds. If the time is not available from the station, NO UPDAT will appear on the display.
RDS time is broadcast once a minute. Once you have tuned to an RDS broadcast station, it may take a few minutes for your time to update.
Hope this helps.
Mar 29, 2011 | GMC Yukon Cars & Trucks
Clarion Cz102 In Dash Car Cd Player W Radio Receiver Head Unit Aux Input Logo
73 people viewed this question
Top Clarion Audio Players & Recorders Experts
xxxxxx xxx
 Mikey
Mikey
Robert Rankin
Are you a Clarion Audio Player and Recorder Expert? Answer questions, earn points and help others
