Question about Black Diamond Apollo Lantern
Bulb replacement Have an older model Black Diamond Apollo... Replaced batteries but still won't light...might it be the bulb? If so how do you replace bulb and with what? Thanks
2 Suggested Answers
  • 14 Answers
SOURCE: Where can I purchase replacement Black Diamond
GearX.com sells them for $6.50. Hope this helps ! Matthew
Posted on Jan 22, 2011
No. Where can I order a battery pack?
from a battery shop
from the manufacturer on line
from e-bay
Oct 06, 2015 | Black Diamond Apollo Lantern
Battery Packs available? Where.
where di you buy the lantern? that is where I would look first .
Replacement bulb for Apollo Horizon 2 Projector
ebay or divine lighting dot com has the cheapest bulbs and best selection
Jan 13, 2014 | Apollo Office Equipment & Supplies
Left turn signals won't flash, Right side works fine. Replaced front and rear turn bulbs (rear was burned out). Bulbs come on fine on the left side, they just won't flash.
Gday mate, we had a problem with another late model vehicle similar to that, the bulb that was put into the reverse light was not exact brand product ( ohmage was slightly wrong ) and fowled up computer, correct bulb in place and disconnect battery to reset K A M ( keep alive memory) problem solved, BEWARE, some vehicles cannot have KAM reset except for dealer computer tethered reboot , just try putting the factory correct bulb(s) in and see how it goes, geoff. hope this helped.
Feb 11, 2012 | 1998 Buick LeSabre
I need to fix Dash air vent light -Left side - that goes on and off- How due I remove the bulb and check the wiring?
Check out the "Instrument Cluster Light Bulbs" section below:
2002 Volkswagen Passat - Repair Manual - Chassis Electrical (excerpt)
Dome/Map/Cargo Light
  1. Disconnect the negative battery cable.
  2. Remove the bulb from its retaining clip contacts. If the bulb has tapered ends, gently depress the spring clip/metal contact and disengage the light bulb, then pull it free of the two metal contacts.
To install:
  1. Before installing the light bulb into the metal contacts, ensure that all electrical conducting surfaces are free of corrosion or dirt.
  2. Insert the bulb into the holder. If the contacts have small holes, be sure that the tapered ends of the bulb are situated in them.
  3. To ensure that the replacement bulb functions properly, activate the applicable switch to illuminate the bulb which was just replaced. If the replacement light bulb does not illuminate, either it is faulty or there is a problem in the bulb circuit or switch. Correct as necessary.
  4. Install the cover until its retaining tabs are properly engaged.
  5. Connect the negative battery cable.
The instrument clusters installed on these models are one of 2 types and distinguished by the instrument lighting color, either green or blue.
On models with green instrumentation, only the control light bulbs are replaceable. Should any other failure occur, the instrument cluster must be replaced.
On models with blue instrumentation, none of the components are replaceable. Should a failure occur, the instrument cluster must be replaced.
Map Lights
  2. Remove the bulb from its electrical connector.
  3. Installation is the reverse of removal.
Feb 19, 2011 | 2002 Volkswagen Passat
Where can I purchase replacement Black Diamond Bright Bulbs?
Jan 20, 2011 | Black Diamond Bright Bulb
Apollo vp835 projector,poor quality. Replaced bulb, didn't help
you have at least 2 issues with your optical engine. both are due to excessive dust and heat. the fly-eye (diffuser) lens is fried, as is the light filter on one of the lcd panels. unfortunately, you cannot purchase individual parts for the optical engine. you'll have to replace the whole thing.
Oct 23, 2009 | Office Equipment & Supplies
Parts for New Braunfels Black Diamond Smoker
i need replacement grilling grates for my black diamond smoker can someone help?
Apr 09, 2009 | New Braunfels Black Diamond Smoker...
Black Diamond Apollo Lantern Logo
177 people viewed this question
Top Black Diamond Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Black Diamond Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
