Question about Catnapper Champion Power Lift Chair
The remote is locked and I don't know how it unlocks
Memorex mt2024 bought used w/o remote. Need to reset back to original settings. There is a parental control on a couple of channels and I don't know the password. Here's the BIG ISSUE, though: ...
To unlock all its locked functions, you must have its original remote control A universal remote control won't go. Try to get its original one. Don't waste more money by buying a universal remote control.
Jul 14, 2013 | Televison & Video
I changed battery in the remote with a cr2032. The remote lights up but the doors still don't unlock. any suggestions ?
read qowners manual for exact number of times... but put key in ignition turn on and off between 7 and ten times..... locks will actuate! hit lock button on remote... remote is then set
Jan 29, 2013 | 2005 Chevrolet Equinox LS
Locked out front control panel while in menu. Now I can't unlock front control panel and I don't have original remote control or owners Manual. Help me please. The front panel is all I use for DVD pla
Hi there, if you know what model it is you can do a google search for the owners manual. There should be a sequence of buttons you can push or hold to reset to factory/default settings.
Jan 25, 2013 | Televison & Video
Suddenly, my automatic door unlock button on remote for my 2005 Chevrolet Equinox will not unlock doors and alarms goes off if I manually open driver's door and don't start car right away. Wh
I tried replacing battery in my remote. Sometimes it work and sometimes it doesn't. I think it could be a wiring problem in the remote. I know it's a major paun having to hurry up and put key in ignition befofr alarm starts going off.
Oct 30, 2012 | 2005 Chevrolet Equinox
My akai tv is locked,don't know the code
Most TVs have a parental control lock that can be set to prevent children from watching specific television shows. In order to activate or deactivate the controls, you need to know the four digit security code or parental lock control password. If you forget the number you chose or if the lock gets set accidentally, it is still possible to unlock the TV.
Instructions
Turn on the TV and grab the remote. In most cases, you will need the original remote to unlock the TV if you aren't sure of the unlock code. If you don't have the original remote, you will need to purchase one.
Look at the screen. If you see a blank screen with a red key on the bottom of the screen, press 'Function' and 'Mute' at the same time. This should unlock the channel. This is an option for people who want the TV to stay locked but, want to be able to bypass the lock to watch a certain show or channel. All other channels will remain locked and the TV will fully lock when it is turned off.
Unlock all of the channels on the TV by entering the factory reset code. There are three main reset codes that TV manufacturers set. These are 0711, 6688 and 3308. Try each one until you find the one that works. This will reset the TV to original factory settings. When you do this, you will loose any information that you have stored in the TV, such as favorite channels, automatic timers and the clock. You will have to go through the full initial set up.
Call the technical support service number in your owner's manual if none of those codes work. A technician can help you troubleshoot the television because the problem may not be the locking control. When you call, make sure that you have the model number and serial number of the TV.
Take your television to a TV repair shop. In some cases, a professional who access to wiring diagrams for your television set may have to rewire certain components in order for the television to unlock. This is usually the case when the TV locks by itself while it is on.
Sep 13, 2012 | Jensen Q2749J 27" TV
I bought i used thinner tacker but i don't know the password used to unlock it ?
you will need to take it to the retailer to have them unlock it unless you have an app that allows you to remotely unlock and lock your phone from any computer
Jul 29, 2012 | Cell Phones
SIM is lock
Using remote unlocking method you can solve this problem .........
Get the unlock process for your iphone here Mobile-unlocker.com , it gives easy instructions for getting the unlock for your mobile at a safe way........
Dec 11, 2011 | Apple iPhone Computers & Internet
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
My iphone is locked
It locked to security or passcode means go to nearest store and restore it or reset it...If it locked to Network means You need to specify the Network and Country it locked now,you can get the remote I-Phone Unlock service from here
Theunlockspot.com and Unlock it from Network Lock.
Aug 06, 2011 | Apple iPhone 3G
Reprogram keyless entry
It took me a few attempts to program a new keyless remote for my 2002 Chevy Blazer.
Insert key into ignition but don' turn it yet. While holding down the UNLOCK switch on the door, the trick is to cycle the ignition ON OFF ON OFF as quickly as possible then release the UNLOCK switch. If done correctly the door locks will cycle 1x to acknowledge. Then hold both the unlock and lock buttons down on the remote for about 15 seconds. The locks should cycle again to confirm...Hope this helps.
Mar 19, 2009 | 2002 Chevrolet Blazer
Catnapper Champion Power Lift Chair Logo
48 people viewed this question
Top Catnapper Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Catnapper Furniture Expert? Answer questions, earn points and help others
