Question about Frigidaire GLWS1233A Top Load Washer
Brake shoe on frigidaire washer
Squeak or groan when end of each spin cycle
  • 10 Answers
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Posted on Dec 15, 2007
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
Nicesuit
  • 61 Answers
SOURCE: Washer does not spin at the end of the cycle
check that you do not have the crease gaurd or rinse hold button depressed? does it spin at all can you put it on a spin cycle with clothes in and no clothes in?
Posted on Jul 23, 2009
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
SOURCE: ATF6000ES front load washer won't spin during regular cycle.
clogged filter will cause this error code. I have the same washer and the filter located inside the rubber boot attached to the pump was full of junk. there was enough room for water to get thru but not enough for full volume. clean it out and it should work. note : its a pain to get the boot back on so be ready and take it slow. this worked for me.
Posted on Aug 30, 2009
Washer spins to a stop.
the brake engages the clutch and no it does not stop right away.
Mar 23, 2014 | Frigidaire FEX831CS Top Load Stacked...
The washer fills and agitates, and spins, but when it is stopping the spin cycle it makes a really loud groaning noise and my tenant says there is a rubber smell.
The brake shoes are not grabbing like they should, the rubber smell is the motor coupling. This is putting a load on that coupling and will soon cause it to fail.
Nov 18, 2010 | Frigidaire GLWS1233A Top Load Washer
Kenmore 90 series , Brake doesn't engage basket after spin
This assumes that you have a basic Sears / Kenmore / Whirlpool top load, direct drive washer.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the Sears diagram or the following Whirlpool Service manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The washer uses a brake system to stop the basket at the end of the spin cycle.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
It sounds as if your brake shoes are worn / damaged.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
I'd pull the drive tube and check the springs, shoes and plastic cam that hooks onto the clutch spring.
Although Sears sells a complete drive tube assembly, you can probably get only the parts you need (shoes) from Whirlpool.
Mar 04, 2010 | Kenmore Washing Machines
Frigidaire (glws1439fs1) top load washer
If your machine is old means may be brake shoe might be very closes joined make adjustment and correct it otherwise it is a bearing noise kindly replace the bearing along with washer
Dec 24, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Series 70 makes noise at the end of spin cycle when the brake sets it makes aloud rumbling noise.
KENMORE top load, direct drive, neutral drain washers are made by Whirlpool.
A way to solve this (that I tried and it works) is to pull the basket tube / brake assembly and if the brake shoes look OK, spray a small amount of silicone spray on the inside of the brake drum.
Nov 16, 2009 | Kenmore Washing Machines
My washer, Frigidaire #CWS3600AS0, is smoking and squeaking when it's in spin cycle. Any idea what could cause this and is it fixable?
You need to replace the drive belt at the bottom of your machine. It has become stretched and worn from use. Fairly easy repair.
Nov 03, 2009 | Frigidaire CWS3600AS Top Load Washer
After spin cycle washer stops abrubtly causing it to shift.
You have dragging brake shoes. This will cause the motor to draw excessive current. Nedd to take apart and pull down spin tube to access the brake shoes
May 31, 2007 | Whirlpool LSQ9600L Top Load Washer
Frigidaire GLWS1233A Top Load Washer Logo
15 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
