Question about Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White
Spa2go display LU code - Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White
Circulating pump works no digital display and no air pump
if voltage from transformer to board bad board if no voltage transformer
Oct 11, 2017 | Comfort Line Products Spa2Go Inflatable 4...
GWL 15 fisher & paykel. Fault code 240. Replaced the rps and the motor control board. Regular wash goes through till the spin cycle. Then the fault code activates and stops the machine. If you turn...
Hi Lu here.Did you replace the rps sensor with the same one as you removed? Did you check for corrosion on the plug you attached to the new sensor ? And finally did you get the correct control module? By the way there are different models of RPS sensors.Sorry for the questions but I need to know what has been done.Please reply for further help.Regards LU
Jun 14, 2014 | Washing Machines
Can I use salt instead of chemicals to keep my spa2go clean and sanitized?
Salt is not recommended in Portable Spas as it can be extremely corrosive to metal parts inside of the Power Pack, as well as drying out the vinyl parts, covers, etc, which can cause them to fail very quickly. The recommended sanitizer is Bromine. Make sure you are using quality chemicals if you are having problems balancing your water.
The manufacturer recommended chemicals are available from Oceantis, the only authorized service provider for all of Comfortline Products spas in North America. They can be contacted at (855) 772-6269
Portable Spas Accessories Parts and Chemicals Oceantis Oceantis Cape...
Sep 26, 2013 | Comfort Line SPA2GO INFLATABLE 4 PERSON...
I am attempting to program the atomic masses of the elements into my Ti-86 using the Store feature and Capital and lowercase letters, (ie. 54.938>Mn) and I got all the way to Lu, when it gave me an...
There is a built-in function called LU (for LU-decomposition of a matrix). You cannot have a variable with the same name as a function, regardless of case. You'll have to find a different name to use.
Nov 22, 2010 | Texas Instruments TI-86 Calculator
We have a maytag neptune washer and it is suddenly not working and displaying a code of LU it kinda looks like>?
perhaps and lr??? LR--- means locked rotor assy. you will need to replace your motor control board and motor assy, comes as a kit not a bad repair (NEPTUNE REPAIR KIT) if thats indeed the issue you seeing that is
Oct 09, 2010 | Maytag Neptune Washer
I need the service ,manual for juki LU-1508 sewing machine
hi there
please email me i can send engenieer's manual for LU-1508 - LU 1510 by PDF
best regards
aabozid@hotmail.com
Sep 24, 2010 | Kitchen Ranges
What does LU mean? i tried to wash a samll load and LU comes on after a few beeps.
HI. this is a Imbalance error
Possible causes
  • The load is too small
  • The appliance is tilted
  • Laundry is gathered to one side
  • Non-distributed things are put into the drum
Aug 01, 2009 | LG WM1812C Front Load Washer
Puk code for lg lu cu920
call ur mobile service customer care number and ask ur puk code from them...they will ask ur last 4digit sim card number...give tat number to them...they will give puk code ...use tat code and continue ur operation
Jul 22, 2009 | LG Vu CU920 Cellular Phone
Comfort Line Spa 2 Go Portable Spa with Micro Jets - Blue/White  Logo
24 people viewed this question
Top Comfort Line Pool & Spa Experts
Jay Finke
Jay Finke
john h
Bill Boyd
Are you a Comfort Line Pool and Spa Expert? Answer questions, earn points and help others
