Question about Ricoh new aficio sp 5200dn laser printer 406722 tnib
Makes noises when in standby - Ricoh new aficio sp 5200dn laser printer 406722 tnib
Is it normal for a microwave to make crackling noises when standing and not in use but plugged in ?
A microwave in standby mode should not crackle. There might be a slight humming sound from a transformer, but that should be all the noise it makes. You could have a transformer or control panel component that is failing.
Oct 28, 2016 | In Microwave Ovens
Sony Trinitron tv wont turn on no picture just makes clicking noise
Short circuited component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Feb 09, 2014 | Televison & Video
Projector will not turn on from standby
Hi, did you ever get an answer to your question? I have an ET20 which, after several months of non-use, has now stopped working. The standby light is on, it makes a startup 'noise' but then does nothing. None of the other buttons are illuminated. Is this similar to your problem?
Dec 29, 2013 | Toshiba TDP-ET10 DLP Projector
Sony dvd player makes noise when turn it off
It is in the standby portion of the power supply which runs 7/24 if the unit is plugged into power.
Dec 06, 2012 | Sony Televison & Video
After a gig last night we tried our Marshall JCM 2000 DSL401and it had developed two noises without anything plugged in. The first is a transformer hum that I'd never noticed before and when standby is...
Likely the filter capacitors have a problem. Best to take this in for repair... it is ODD that there is noise with the standby switch is in standby... That makes no sense... In standby it appears that power is removed from the power amp high voltage so nothing should come through the speaker... Unles maybe one off the power tubes had a total meltdown which should have blown the fuse.
Sep 10, 2011 | Marshall Amplification Marshall Cover For...
I have dell 3300mp,when I turn the power on it makes a very loud noise. It does not make the sound in standby or cool down. It does work and display a signal okay, but it is very loud. Sound like a fan?,...
The main fan that cools the lamp is mostly high speed when the unit is running. when it shuts down it slows the fan down, until it stops in standby. So the noise is only really loud when it is showing a picture.
try setting the fan to eco mode (slower running) and see if the noise is acceptable. If it is still too loud then you will have to replace it. Have a look at the fan and see if any of the plastic blades are missing.
Mar 26, 2011 | Dell 3300MP Multimedia Projector
ESD noise (fluorescent lamp power-on) also wakes the computer from standby
Make sure Wake on function turned off, Wake on LAN, modem ring...(Bios Setup)
Use a surge protector anyway!!!
Conect the lamp to a difrent place away from the computer.
You can buy expensive filters too or just buy a new lamp.
If you can try the lamp with another computer, make sure whats the real problem!
Nov 11, 2007 | Gigabyte GA-7VRX Motherboard
Sony KP-46S17
does the standby light blink?
Nov 09, 2007 | Sony KP-41T65 41" Rear Projection...
Sony DCR-HC42 makes a buzzing sound
I had the same problem with my TRV460 and the HC-40. It seems it's a motor noise that is 'normal'
Sep 14, 2005 | Sony Handycam DCR-HC42 Mini DV Digital...
Ricoh new aficio sp 5200dn laser printer 406722 tnib Logo
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
