Question about Sewing Machines
Singer curvy my needle is hitting the bottom of the bobbin cartridge. I've made sure the needle is in correctly.
  • 980 Answers
SOURCE: my singer curvy is not pulling the thread from the
Providing you have a new needle in the correct way round if it does not pick up the tread you will need to take it in to get retimed.
Posted on Nov 05, 2009
bugoy31
  • 1238 Answers
SOURCE: my singer curvy 8780 has
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Posted on Jun 06, 2011
SOURCE: SINGER CURVY: It jammed while sewing felt. Taking
the thread keeps gathering in big bunches under the material~i adjusted the tension but still gathers~Im wondering if there is something stuck wonder the plate~THanks
Posted on Jun 22, 2011
  • 166 Answers
SOURCE: Bernina Activa 130 I was sewing
You can check whether the alignment/timing has been affected fairly simply, as follows: Put a new needle in. Adjust the position of the needle fully to the left and try a straight sew-off ... if this works OK, but not when the needle is at centre, the timing is probably out. Drop the bobbin door and take the bobbin/bobbin case out. Turn the handwheel until the needle goes down into the stitch plate and just starts to come back up ... stop there. Carefully push the needle/needle-bar all the way to the right, so that the needle is nearly against the right-hand side of the slot in the stitch-plate. Lean the machine slightly back so that you can see clearly into the hook/shuttle area through the bobbin door. Release the hook/shuttle retainer by pressing the metal lever to the top-left side of the bobbin door. The black plastic hook/shuttle retainer should pop-open and you can carefully drop it down on its hinge to rest on the bobbin door. You can now see the hook/shuttle in its hook race and the pointed part of the hook should be to the left of the needle. Now, slowly rotate the handwheel so that the point of the hook continues to rotate clockwise until it just passes behind the needle. Look very carefully - the point of the hook/shuttle should be just above the top of the thread hole in the needle .... if it's below, or significantly above, the timing on your machine has been thrown-out by the needle breakage and will have to be professionally adjusted.
Posted on Oct 14, 2011
SOURCE: My Singer 6160's needle is hitting the bobbin plate.
first change the needle--flat side to the back of the machine, make sure the needle is inserted all the way up into the needle holder
make sure it's the correct needle for the machine
if the needle keeps hitting the bobbin plate then the machine may be out of time & would have to be take to a sewing machine shop for retiming.
Posted on May 04, 2012
I have a singer curvy 8763 and the needle id dragging in the bobbin wheel. Tried changing the needle and making stitch adjustment.
insert the needle all the way up. if it is not a timing issue, try to lift the needle shaft
Aug 09, 2014 | Singer 8763 Curvy
My Singer Curvy sewing machine tension is not working. No matter what setting I set the dial to the tension never changes. There is none. My machines stitches look ok on top of the fabric, but bunch up...
try a new needle
make sure the bobbin is turned the right way in the bobbin case
rethread the machine top and bobbin
if these suggestions don't help, then the machine needs to be checked
Oct 20, 2013 | Singer Curvy 8770 Electronic Sewing...
I have a singer confidence 7469 quilter, the upper thread keeps bunching up in the bobbin case. I've tried re threading numerous times with no luck.
try changing the needle
make sure the bobbin is turned the correct way in the bobbin case
make sure the thread has not come off the thread take up lever
clean under the needle plate and in the bobbin area for lint
Jan 29, 2013 | Singer Confidence 7469 Mechanical Sewing...
Needle wont catch bobbin thread. Think timing is out.
First change your needle... it's probably bent and make sure you are using a needle FOR Denim in a size 18. Hand run the machine... if you still feel it hitting something... it is out of time. Take it in for repair.
Oct 05, 2012 | Singer 8763 Curvy
Singer confidence 7463 all lights flashing
try
rethreading the machine top & bobbin
clean under the needle plate & in the bobbin area for lint or thread
make sure bobbin is inserted correctly & that it's not damaged
May 20, 2012 | Singer Confidence 7463 Computerized Sewing...
May 03, 2012 | Singer Sewing Machines
I have Singer Curvy 8763. It seems that the foot control stopped to work. The machine does not sew, its impossible to wind the bobbin. It is possible however to sew backwards with the help of reverse...
I be s 8763 was sewing beautifuly, took off pressure foot to make a buttonhole read the manual followed directions button holer kept gumming up with thread and the alarm kept going off, then got flustrated, put back on the sewing pressure foot now it is like the needle is out of line will not pick up bobbin, and is definately hitting something by the bobbin, will not sew
Nov 04, 2010 | Singer 8763 Curvy
SINGER CURVY: It jammed while sewing felt. Taking apart the bobbin area, I can see that the needle hits the bottom of the "floor". The bobbin is not catching or moving.
I think that your should try a new needle, it may be bent or have burr on it. It problem persists call Singer at 1-800-4singer, good luck
Sep 12, 2010 | Singer Curvy 8770 Electronic Sewing...
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
