Question about LG Televison & Video
LG an-mr400q not working
The red light won't go off. Cant reset remote by pressing ok and back buttons simultaneously.
SOURCE: lg plasma 50px4d-eb keeps going into standby mode
good grief - my TV just did the same thing - its locked in standby mode - I disconnected power several times - each time i reconnect the green light comes on for about a minute 9nothing happens on the screen) and then returns to the stanby mode
Posted on May 18, 2008
SOURCE: MY LG DVD/VHS DC593W SHOWS A RED KEY I CANT PRESS ANY OTHER BUTTONS ON IT BESIDES USING THE REMOTE,,,PLEASE HELP
Simple solution.
Press the C.Lock key on the remote.
This key tunrs on and off the child lock feature.
cheers.
Posted on Jun 26, 2008
SOURCE: remote control
I had the same problem.  The problem is strange and seems to be with the receiver in the TV and not the remote control.  The reason I say this is that when this first happened my Samsung brand DVD could actually control the TV.  This then also failed, but still works fine with the DVD player.
Anyway there is an even more bizarre fix to all this......
- Remove the batteries from your TV remote. - Press and hold the red (ON/OFF) button for at least 1 min. - Replace the batteries and hey presto!!
I know seems far fetched but I found it on the Samsung website and it does work.
Posted on Mar 30, 2009
  • 75 Answers
SOURCE: Hampton Bay 60" Brookedale fan remote not working
The Remote (TRANSMITTER) control AND the RECEIVER must both be set to the same CODE in order for the REMOTE to operate the fan.
!!WARNING!! YOU ARE ABOUT TO ENTER HIGH VOLTAGE ELECTRICITY ZONE!!
The RECEIVER is located in the CANOPY, the part of the fan assembly next to the ceiling which is also called the Hanger Bracket.
At the bottom of the Canopy you will see what looks like a large flat washer. Rotate the washer counter-clock wise to release it.
Then rotate the Canopy counter-clock wise to release and lower it. You will see the RECEIVER, which will have a short antenna at one end, tucked in among the electrical wire and bracket. Simply pull the RECEIVER out and you will see the CODE switches. Remember to set both devices to the same CODE.
Good luck. :)
Posted on Apr 26, 2009
  • 115 Answers
SOURCE: microsoft wireless optical desktop 1000.....keyboard wont type
then it is the problem of driver so reintall the it
and you can check the batteries for replacement
Posted on Sep 11, 2009
My LG tv model number M2762DL will not show a picture. On the screen shows a code V3.14.0. What is the problem?
Somehow, you have gotten to a firmware information screen. Try pressing OK and Exit simultaneously on the LG remote. (Note: this doesn't work if you use a generic or other universal remote.) If you don't have the remote, you can try pressing Menu and OK on the TV. (These are the second and third buttons from the left.) I've only seen the remote method work.
If that works, you'll probably need to open the input list and change the current input. Press Input on the remote or on the TV (the leftmost button).
I hope this helps.
Jan 16, 2015 | LG Electronics M2262D 22" LCD Monitor
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
Hi i need to find a sky plus code 47lh300-za for this LG TV can you help?
Hello
Setup codes for LG TV with Sky are:
065 244 405 318 037 398 191 459 245 389 060 275
065
742
743
726
508
584
Follow the steps below
1* Select any channel on the TV.
2* Point your Sky+ remote control away from the TV and press the tv button.
3* Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4*Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5* Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
OK.
Jul 21, 2011 | LG 47LH3000 LCD TV
Sky remote control code needed for lg tv - model 37lk450
Hello
Setup codes for LG TV with Sky remote are:
065
742
743
726
508
584
1*Select any channel on the TV.
2*Point your Sky+ remote control away from the TV and press the tv button.
3*Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button. If this works try the other TV functions.
Please note:- in der to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
Jul 16, 2011 | Televison & Video
Sky remote code ????
Hello
Check these codes.
742
743
726
508
584
4* Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5*
OK.
Jul 04, 2011 | LG 47LC7DF 47 in. LCD HDTV
I had a projection bulb go out and after replacing it, i went to turn it on it clicks once, and the orange light starts blinking, then it clicks again and the light goes to red. this light does not blink...
Refer to mlapres' tips, pls. noavatar.png mlapres
  • Rank: Wiz
  • Rating: 84%, 330 Votes
What you need is to have the lamp timer reset. To do so, perform the following;
You will need two hands.
With the remote, press and hold down the "mute" button.
Simultaneously press and hold down the "enter" button on the front of the TV.
After about 5 seconds, a box will appear that shows the total number of hours on the lamp. To reset these hours, press the right arrow button on the remote. After doing so, another box will appear with a confirmation question and an icon for which button on the remote to press to reset the lamp hours.
Jan 09, 2011 | LG RU-60SZ30 60" Rear Projection...
I have an lg projection tv model #RU-48SZ40. I needed to change the lamp, when I was done and turned the tv back on...the orange warning light was still lit. I then tried unplugging the tv, pulled the lamp...
Dec 15, 2010 | LG Televison & Video
Hi i have a 52sz8r-tb and i have to change the bulb in it from when we did it the first time as i recall you have to reset the television can you tell me how to do this again cheers Petrina
1. Press the OK or enter button on the front panel and MUTE
button on the remote control simultaneously (About 5 seconds).
2. Press the VOLUME ( G) button.
3. Press the OK or enter button.
Lamp time will be reset.
Sep 28, 2010 | LG DU-62SY20D 62" Rear Projection HDTV
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
How to reset the lamp timer count on a LG rear projection TV
2. Press the VOLUME (>) button.
Jun 15, 2009 | LG Televison & Video
Televison & Video Logo
722 people viewed this question
Computer Repairing
Computer Repairing
