Question about XPLOSIV Turning Point: Fall Of Liberty for Windows
Turning point black screen
1/2 the tv screen is black when first turned on
the vertical pump stage has defect.check the leaky and puffed capacitors and transistors and also the ic`s dc accross to pin test points
Jan 29, 2014 | Televison & Video
Black screen
Does anything ever show up on the screen at ANY point? If you shine a bright light at the screen when the computer is turned on can you see a faint image or writing?
Jan 05, 2014 | Toshiba satellite c660
Screen stays black when I turn it on
My point of view RAM section direct connect to display so first you check RAM.Then check processor Fan proper working or not. and finally power connection in screen.
Thanks..
May 08, 2013 | HP Pavilion ze4935wm PC Notebook
My touch screen will not function. It seems to start okay but the touch screen wont work from that point. I have reset. Garmin NUVI
Turn off the device.
Press and hold the upper-left corner of the screen and turn the power on.
Keep holding the screen and release the power button when the screen is on. Keep holding the screen for next 30 secs and u will see a "press button" on the screen.
at that point release the screen from upper-left corner and touch the press black point on the screen to calibarate it.
should be fine after that.
thanks
Jul 29, 2010 | Garmin Nuvi 660 GPS Receiver
Do not start up, black screen
I'll asume something for this one it might help. Make sure your laptop is completely turned off [No fans turn, screen black, no hard drive light]. When you then press the power button, immediately keep pressing the F8 button on your keyboard. It should then actually display two options after a while :
*Delete restore/resume point and start windows
*Resume restore/resume point
Select 'Delete restore point' and the unit should boot up fine again.
I had a unit that was basically turbo-booting into windows, but the restore point was corrupt and it always seemed it had a 'blank screen' problem.
You can also try to access the BIOS by pressing F2 as soon as the unit starts up to see if you can actually access the BIOS.
If that all doesn't help I suggest reseating RAM.
May 23, 2010 | Acer Aspire 9800 Notebook
When I turn my computer on just a black screen and beeps
the prob is with your RAM only just chang your RAM it will be fine
May 05, 2010 | Apple Computers & Internet
Cannon Powershot A-620 black screen can't review
Did you accidentally press the DISP or DISPLAY button on the back of your camera? This manually turns the screen on and off to save batteries. You would then use the optical viewfinder to take pictures. To turn the screen back on, just press this button one more time.
Jul 23, 2009 | Canon Cameras
Screen turns black and stays black.
This is a manufacturing default that Canon will fix for free regardless of the status/age of your warranty.  Get their 1-800 number and call them.  They'll tell you where the nearest Canon service centre is.  You just take your camera there and they will fix free of charge.
Feb 19, 2009 | Canon ZR70MC Mini DV Digital Camcorder
Gateway flat screen monitor goes black when turned on
open monitor and look at the PC Board to locate some kind of DRY SOLDER or burn point , specially where a transformer is located , check re solder any solder point that looks suspicious , and try again , hope this helps
May 03, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Open Questions:
See all XPLOSIV Turning Point: Fall Of Liberty for Windows Questions
XPLOSIV Turning Point: Fall Of Liberty for Windows Logo
24 people viewed this question
Top XPLOSIV Video Game Consoles & Games Experts
Vernon Taylor
Lawrence Oravetz
james laughton
james laughton
Are you a XPLOSIV Video Game Console and Game Expert? Answer questions, earn points and help others
