Question about Proview PL913S 19" Flat Panel LCD Monitor
Not turning on
First i tried to fix the problem myself but i think i made it worse. First the screen was lighting up but there was no video so i took it apart and put it back together now nothing is showing and it wont turn on. Solutions would be great.
  • 4,889 Answers
Using a flashlight shine it at an angle to the screen and see if you see a computer screen showing under the beam of the flashlight. If you see a picture then the backlight or its circuit is not working. Check to see that the 4 cables going to the LCD display are plugged in all of the way. There are plugs on each of the cables with 2 wires to each plug. However if you are not technicaaly sound i suggest you take it to qualified technician...or you might worsen the situation!
Posted on Oct 09, 2007
Hi my Sony KDF-E50A10 has a yellow blob in middle of the screen. Tried changing the bulb and yellow blob was worse. any suggestions?
Your Optic blog has failed. The bulb will not fix that. There was a class aciton lawsuit against Sony about this a few years ago. The Optic block must be replaced(only posibble fix) Sony Rear Projection LCD TV
To fix it out of pocket would be ridiculously expensive($800+). Return the lamp or use it until the image is too bad to watch. Then treat yourself to a new TV.
I am well versed on this issue and would not recommend fixing this
Jan 10, 2018 | Sony Televison & Video
How to fix my samsung tv touch screen playing up?
In this case, it will be best to contact the authorized service center. Electro help
Jun 09, 2014 | Televison & Video
TV turns on, but the screen is very dark, almost completely black.
It sounds like your backlight is out or barely functioning. Try replacing the inverter board(s). Since you can see a picture, the T-Con board is probably okay.
Apr 20, 2017 | Polaroid 2611-TLXB TV
My computer is stuck on a black screen. It is turned on but will not do anything.
to remove u r ram and re-insert to another slot in moterboard
Dec 27, 2011 | HP W2007 LCD Monitor
The laptop screen flickersand turns grey, it also get hard to see. It gets worse the longer the laptop is on. The fan seems to be running much more and a load grinding noise came from the fan a few months...
You could try using compressed air to clear out the fan, but most likely your system is overheating and the longer you go without fixing it the worse and more permanent issues it will cause
Nov 16, 2017 | Toshiba Satellite A105-S4004 Notebook
I was playing my xbox and it froze now the green power light is flashing and the disc tray wont open is this something i can fix myself or will i need to send it away to be fixed.
This is a drive error , The console thinks the drive is half open/
or closed . Or the drive board has a error and your console
can't identify it or find it . There are several possibility so it's
hard to say with out testing it. Yes you will have to send
it in to Microsoft for this specific type of drive error since
they have the tool to restore recode corrupt drive errors.
And a repair shop could make maters worse .So in this
rare instance I recommend you send it to Microsoft.
Also do you here the drive motor when you press eject?
Try turning off your console and then press eject and see
if that turn your console back on .
I'll give it some thought.
Rob
Sep 08, 2010 | Microsoft Xbox 360 Console
When I turn on the console red lights appear on
red ring of death is what im thinking? upgrade to a 360.
Apr 09, 2010 | Microsoft Xbox Console
B;inking lamp light and tv wont turn on
Usually when light continues blinking the main board is OK but, your video boards or other boards may have an IC problem. I've seen where some have tried to fix these problems themselves only to make problems worse. I think you'll be better off having a Service Tech fix it. They will have your TV operating in no time at all.
Oct 26, 2009 | Hitachi Televison & Video
Problem with philips dlp tv
This sounds like one if not both of your cooling fans are not functioning properly. Therefore, you'll need to replace a fan more than likely.
Apr 16, 2017 | Televison & Video
Screen
Sounds like a hardware problem with the screen. Try switching the video driver temporarily to one of the Microsoft standard drivers (like VGA STANDARD) and check if the problem is any different. If it is, then it is a software driver problem. If the problem is the same, switch the driver back and try this.
These solutions may damage your machine, so do so at your own risk.
Get the machine running normally and then try the following tests, watching for the static on the screen to change (get better, get worse).
- Tap lightly on the sides of the screen unit
- Open and close the screen unit lid to the full extent in both direction
- *Very lightly* twist the base of the computer one way and another - lightly, just enough to put a little pressure on the case
- *Very lightly* twist the screen unit slightly by the corners - lightly, just enough to put a little pressure on the case
- Tap on the corners of the computer's base unit like knocking lightly on a door
If any of these physical tests change the static on the screen significantly, you have hardware troubles. If this is the case, either take it for professional repair, or, at your own risk, try this.
It is very likely that you either have an electrical short or that the ribbon cable connecting the screen to the motherboard has come partially unseated. Find a friend who knows about taking things apart, tell him you think this might be the problem, and ask him or her to help you lovingly disassemble the machine looking for possible hardware problems. Remember to do anything like this with the machine completely unplugged and the battery out, and as a last resort on a machine you need but cannot afford to fix.
Final hint: if tapping or twisting the screen lightly changes the static, you probably have a ribbon cable or other hardware problem *in the screen unit*, while if you have changes in the screen when you knock on the base unit, it is likely where the video signal cabling enters the motherboard.
Good luck.
Nov 16, 2007 | Toshiba Satellite M115-S1061 Notebook
Proview PL913S 19" Flat Panel LCD Monitor Logo
35 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
