Question about American Standard Heating & Cooling
Frozen pump american standard 2A6B3060-SF-1A
The heat pump is frozen and I can't get it to defrost the LED light is flashing 3 times I did jumped the defrost board and it stop the fan and went to defrost but didn't go on long enough to defrost?
3 Suggested Answers
co7196
  • 3433 Answers
SOURCE: HEAT PUMP PROBLEMS
Defrost cycle is to allow frosy or ice to melt down and not restrict the output air. The thermostat is set too low and in high humidity ice forms quickly restricting the air flow. tur up the thermostat and let the room cool gradually.
Posted on May 27, 2009
james3751
  • 614 Answers
SOURCE: LED on defrost control board is blinking 3 times
Does not initiate defrost on ots own. Loose sensor. If sensor is not loose replace defrost board and sensor. Russ
Posted on Mar 25, 2010
BUZZING NOISE FROM MY HEAT PUMP
Take a look at this YouTube page that explains with good videos what are some of the common problems with heat pump noise. The one that seems dominant is the defrost cycle a heat pump goes thru when it melts ice off the evaporative coils. In defrost cycle, The compressor runs but the cooling fan does not, so you will hear a loud buzzing sound and the unit sounds like it is stalled...because only the compressor is running to generate heat to melt coil ice.
https://www.youtube.com/results?search_query=American+Standard+5000+Heat+Pump+makes+a+buzzing+noise
Defrost cycle noise video:
https://www.youtube.com/watch?v=wudLk0WoIVo
Mar 06, 2015 | American Standard 5000 Heat Pump Unit
Rheem heat pump not coming on in heat mode. Control board has two LED lights # 1 solid, #2 blinking. What does this mean?
Usually wen the led lights are blinking it means there is a problem. If you look on the door or the cover there should be a code that tells you what the blinking represents.
Example - one blink per second - compressor, two blinks - fan motor, etc. The other thing you can do is look up the model number on line for the installation manual and it should have all the info you need.
Jan 08, 2015 | Ruud Defrost Control Board 47-102684-08...
American Standard heat pump troubleshooting
If the compressor is not frozen, then it is most likely one of the starting capacitors on either the compressor or the fan motor. These can fail without warning and without any outward indication. They are shaped like small cans or oblong cans and have 2 or more wires that attach to them with terminals. If you are going to remove one or check them, Make sure the power is off first.
Aug 11, 2014 | American Standard 282999 4" Heat Pump Snow...
Water leak in condensing furnace
Several problems can be associated with this problem
If running heat it is likely a drain hose or Drain connection that is plugged up. Simply blowing these lines out can solve your problem.
If running AC it is likely a Drain from the coil to the Drain line that is plugged up, or you have frozen the unit up. Check the unit outside, if the big copper line or compressor is frozen, turn system off immediately and call a service company to check the system out.
I also recommend changing your air filter every 3 months if you haven't done so.
Mar 06, 2014 | American Standard Heating & Cooling
Daewoo FR 4501 W fan and defroster not working
Have you checked the defrost thermostat if when frozen it is not closed than it is bad always unplug appliance before servicing
Dec 23, 2013 | Daewoo Refrigerators
Coils are frozen on my standard electric heating system. It is not a heat pump
The most common cause of coils, lines or components freezing over are low refrigerant charge, lack of airflow across coil or a blockage of the condensate drain. If the outdoor coil is frozen over then the defrost mechanism may not be working properly.
Nov 23, 2013 | Heating & Cooling
Mhu75ng stopped lighting after about a year. Fan starts, but burner doesn't light. Fan stops after about a minute. LED code is 3 flashes. Gas supply should be good, heater in another room ups
3 flashes could be the pressure switch ,jump it out see if it lights or clean the flame sensor or check the snap dice's 1 for high temp and 1 for low temp ..
Apr 12, 2013 | Mr. Heater MHU75NG
My sister has a Ruud Achiever High efficency heat pump Model UPLA-049JAZ Serial #6408-M389910353 they just moved into this house in ND and have no information on this system..Over the winter it was...
There are 3 possiblites
1. you have a bad defrost board or defrost sensor.
2. Your low on Freon.
3. Your coils and/or your Filter is dirty.
May 01, 2011 | Heating & Cooling
Heating & Cooling Logo
Top American Standard Heating & Cooling Experts
Craig Butler
Craig Butler
Tim Whalen
Mack Baxter
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
