Question about KitchenAid 24 In. White Dishwasher - KUDC10IXWH
Kudc10ixwh Shuts off mid cycle, switches to CANCEL/DRAIN. Shuts off after drain.
jsrock516
  • 5911 Answers
SOURCE: kitchenaid dishwasher just quit mid cycle?
Check your thermal fuse. The fuse is located inside the control panel on or near the main control board. It will be a bullet shaped component mounted with a white plastic clip with two wires leading from it. The fuse should read a short if good. Now...keep in mind, if the fuse blew it is usually for a reason. Replacing it may or may not correct your problem. In some model dishwashers there was a thermal fuse kit that was required to be installed which involved cutting the wires and using a wire splice to connect the new fuse. It seems that there was a design flaw where the gauge wire used in manufacturing would cause the thermal fuse to blow prematurely due the wire overheating. I can't remember if this applies to KitchenAid, but I believe it does. You may inquire about this at your local parts store. I hope this helps you.
Posted on Aug 15, 2007
the dr
  • 447 Answers
SOURCE: cancel / drain
Sounds like the membrane switches have failed-- very common for the new computer controlled appliances. I believe it will be sold as a whole new top console available at all appliance parts retailers or www3.sears.com
Posted on Oct 15, 2007
  • 784 Answers
SOURCE: dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Posted on Sep 13, 2009
  • 949 Answers
SOURCE: Help - dishwasher won't start when I push the
Here are couple things that might help, let me know if they do or not.
-The door must be closed within 3 seconds of pushing the start button.
-There is a part in the right front corner of the tub that you should be able to see with the lower rack out, it looks like a hat. This is the float, it will not let water enter the machine if it is stuck up, look to see if something has fallen under it. It should move up and down about 1/4" freely.
- Make sure someone has not turned the water off to the dishwasher, the valve is usually under the kitchen sink
If these do not help let me know if you have any blinking lights when you push a button or try to start it.
Posted on Apr 25, 2010
heatman101
  • 43501 Answers
SOURCE: water will not drain out. do not have a drain
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Posted on Mar 29, 2011
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
F2 Code???
Probably blockage in pump or sump
Jun 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My Bosch dishwasher is driving me crazy! When it finishes a wash cycle it beeps twice every 10 minutes until the door is opened. We can't run the dishwasher at night after dinner unless we're SURE we...
Hello there,
It would help to know the model number of the dishwasher, but on many Bosch dishwashers, you can switch the cycle cycle completion signal off as follows:
1. While holding the right-hand CANCEL/DRAIN button, also press and hold the ON/OFF button
2. When the LED above the CANCEL/DRAIN button illuminates and the beeping starts, release both buttons
3. Press the right CANCEL/DRAIN button repeatedly until the beeping tone is at the desired volume, i.e. silent!
4. Press the "ON/OFF" button again to set the volume.
On models with the wash cycle buttons on the top edge of the door, the CANCEL/DRAIN buttons aren't always explicitly labelled CANCEL/DRAIN. These buttons are also labelled RESET on some models.
On models with 3 and 4 wash cycle buttons, the right CANCEL/DRAIN button is the third button when reading from left to right. On models with 5 wash cycle buttons, the right CANCEL/DRAIN button is the fourth button when reading from left to right.
Please try the above then let me know if you need further assistance. Please state the model number or series (i.e. Integra) of your washer if/when replying.
Hope this helps.
Regards,
BElectric
Mar 16, 2011 | Bosch Dishwashers
Water in bottom of dishwasher, how do i drain & reset?
Ok so your dishwasher won't do anything... it justs sits there and "Hums" you can't make it respond to any controls, and the ONLY way to Stop it. is to unplug the unit, replugging back in it simply "Hums" again and will do nothing.
Now this happens because, the STOP Button, is pressed and the "Door Opened", during the Wash Cycle. This should NOT be done. You shouldNEVER TURN IT OFF MID-CYCLE. you should instead, Simply, pull on the handle, to Open the door, the system will take care of everything, after, you close it,and pick up where it left off. The turning OFF, makes the machine "Think" that a New Cycle, is going to be done, before the old one is finished, and resets itself to do it all again. But it still has water, that's not meant to be there so it must dump it out.
Now, the FIX. Take the Dishwasher, out, and tip over on it's side, tip to about a 45' angle. Water will come out from underneath, this is from a small "Overflow" reservoir. this reservoir has an "Anti-Flood" switch. The removing of this water will "Reset" this Switch, and allow the dishwasher to work again.
So what happens, is this, when the STOP button is pressed Mid-Cycle, the machine must "Dump" whatever water is still in the machine, into the "Overflow Reservoir". This water then causes the Anti-flood switch to jam, and this stops the machine, until it is reset,by the above method.
Apr 04, 2010 | Dishwashers
Stopped in mid cycle.
The timer went bad. If you move the timer manually to spin will it pump the water out? if it works that way then the timer is bad for sure
Nov 12, 2009 | Maytag Bravos MTW6600T Top Load Washer
Need to get in and take clothes out mid cycle
Press stop/cancel.
The timer will advance to the end of the cycle and drain the water so you can open the door.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 29, 2009 | Kenmore 44102 Front Load Washer
I need to cancel a washing cycle in the middle of the cycle.
usually pressing PAUSE/CANCEL twice cancels the cycle and shuts it off allowing you to then re-start the cycle. If not try unplugging it and see if it resets to allow you to start cycle again.
Dec 07, 2008 | Kenmore Elite 45986 Front Load Washer
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
KitchenAid 24 In. White Dishwasher - KUDC10IXWH Logo
56 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
