Question about Samsung ML 1710 Laser Printer
Samsung ml-3471nd door open error - Samsung ML 1710 Laser Printer
4 Suggested Answers
SOURCE: Samsung ML-3051ND is giving Fuser door open error,
fuser door problem
Posted on Jun 28, 2010
caroldon
  • 17129 Answers
SOURCE: Sumsung ML-3471ND Paper jam 0 problem
This seems to be fault in the transport of the paper in the rollers. So if you have used any adhesive sticker printing, it is possible that some glue has got clogged into the rollers. If not there can be some jammed paper in the rollers or the mechanism.
So start this work only if you are mechanically able with the right tools.
Remove the covers to get access to the mechanism . Remove the motor drive assembly , the fitting of the motor to the mechanism. Once this is removed the rollers can be turned manually so that you will be able to feed a paper to see the progress of the movement while studying if there is any obstruction or damage to the paper.
There is a in-detect sensor, usually an opto-coupler , make sure this is not clogged or dirty as this IR detection feeds the signal to the processor for starting the motor drive feed.
Reassemble but make sure the rollers are aligned to be in equal gap to feed the paper without a side pull. Now you must print and see if the fault has changed. If not repeat the above work to confirm the area of obstruction.
Posted on Oct 28, 2010
  • 84 Answers
SOURCE: I have a Samsung ML-3471ND
Hi. Thank you for using fixya. This problem is the result of the toner drum being dirty. To resolve:Take the toner out of the printer.
Turn the toner over. You will see a green roller. It should be dirty by your description.
Use a clean soft cloth/towel/tissue and wipe it lightly.
Spin the roller.
Clean again until you have done the entire roller. (estimate that you have covered it)
Wipe imside the printer with the cloth.
Reinsert the ptoner.
Printing should be normal now.
Thank you. Hope this solves your problem.
Keep me posted.
Posted on May 24, 2011
Low Heat Or Open Heat
Dear
low heat error means the temp. of fusser assy. was not achieved during the specified time. some times occur during low voltage supply and reset after s/w OFF-ON.
Open heat error means there is no electrical connection to the heater heater of the fusser assy. It has tob either repaired or replaced with new one. mostly the thermostat is responsible.
Thanks.
Aug 18, 2014 | Samsung ML-3471ND Network Mono Laser...
Resetter of samsung Ml3470 laser printer resetter
Try this...
1 Press Menu until System Setup appears on the bottom line of the
display and press OK.
2 Press the scroll buttons until Maintenance appears and press OK.
3 Press the scroll buttons until CLR Empty MSG. appears and press
OK.
4 Select On and press OK.
5 Now the Toner Low Replace Toner message does not appear but
the Replace Toner message will remain for reminding you that the
new cartridge needs to be installed for quality.
The User Manual (ver. 6.00) is available at...http://www.samsung.com/us/support/owners/product/ML-3471ND/XAA
Jun 08, 2014 | Samsung ML-3470 Series
All door closed but give error door open
CHECK THE ALL DOR SENSER &CLOSSE THE ALL DOOR PUSH STRONGLY
Apr 01, 2014 | Samsung ML3471ND, SASML3471ND - ML-3471ND...
Show the photo of paper pickup assy of samsung ml 3471nd
Hi, what is the problem you face? Always has paper jammed?
Dec 17, 2013 | Samsung ML-3471ND Network Mono Laser...
Samsung open heat
how and where is it stored. is there plenty of clearance around the printer and what is it stored on, a metal shelf can conduct heat or being to close to a radiator/heater can cause problems.
Apr 05, 2012 | Samsung ML-3471ND Network Mono Laser...
I have a Samsung ML-3471ND Laser printer. It has started to leave black marks down each page and them about the 3rd page, writing appears from the roller?
You may want to try changing the transfer roller, or your toner could even be malfunctioning. If that doesn't solve your problem you could have a bad fuser. If that is nothing you can do yourself, I'd recommend taking it to your nearest printer repair shop for maintenance.
May 24, 2011 | Samsung ML-3471ND Network Mono Laser...
Samsung ML 1710 Laser Printer Logo
42 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
