Question about Samsung Refrigerators
Soda stream regulator leaks
It suddenly stopped carbonating the water and it's only 3 months old can they just get clogged up ?
See our list of the best soda maker reviews for 2016. Read our best soda maker machine reviews and tips for maximum performance without wasting time Top Ranked Home Soda Maker
Jan 15, 2016 | Sodastream Soda Stream Home Soda Maker...
Soda stream
fit a new gas bulb as they are only good for a couple of bottles
Jan 11, 2016 | Home
I press the lever down on Soda Stream and no carbonating stream, the three levels of light come on. Machine is a year old and tried 2 new canisters with no luck.
Put a finger up into the hole the CO2 canister screws into while you repeatedly push down on the carbonation button and up against the seat of the CO2 socket. You should feel a plunger moving up and down against the pressures of your finger and the button. If you don't feel this plunger, the SodaStream valve is either stuck or faulty. Make sure the CO2 cylinders are screwed up at least finger tight against the top of the socket.
Jun 06, 2015 | Sodastream Soda Stream Home Soda Maker...
Disassemble a sodastream?
why ?
take back cover off and unscrew co gas bulb tank may be clockwise to unscrew.
Dec 27, 2014 | Sodastream Soda Stream Home Soda Maker...
Soda stream won't carbonate
See our list of the best soda maker reviews for 2016. Read our best soda maker machine reviews and tips for maximum performance without wasting time. Top Ranked Home Soda Maker
Dec 26, 2011 | Kitchen Appliances - Others
Soda stream not carbonating
I called soda stream about the same thing. They said it could be a plugged valve or a broke machine. To unplug the valve, you take the washer out, then carefully put the canister in without the washer until you hear gas escape for 2 seconds.. then you take the canister back out and put the washer back in. If that doesn't work, it's a broken machine and they have to send you a new one.
Dec 26, 2011 | Refrigerators
I have an unmarked first stage reg. thats leaking air through the back side through the two small holes
Depending on the model, some regulators (such as Sherwood) always leak a very small stream of fine bubbles as part of the depth compensating mechanism. By this, the regulator adjusts the air flow from the first stage to compensate for increased depth.
As a regulator technician, I would have to see the first stage to make any educated comment or recommendation.
Feb 20, 2010 | Dacor Scuba Diving & Snorkeling
Refrigerators Logo
59 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
